Results 1 to 17 of 17
Thread: Rancilio Silvia Naked Portafilter
    Jun 2011
    57
    Firstly sorry if this is an old topic, I looked and could not find it else where.
    I just got a Rancilio Silvia, we are slowly getting to know each other better.
    My only issue with it is that it is about 2 inches to low, most mugs i have dont fit. I have it on a block for the texturing jug.
    I was talking with someone and they thought a Naked Portafilter would fix this issue.
    What are peoples thoughts I like the idea of them. Are there any big down sides.
    Peace.
    Senior Member David8's Avatar
    Oct 2011
    Annerley, QLD
    560
    Re: Rancilio Silvia Naked Portafilter
    Quote Originally Posted by 4B464B5A5D481918290 link=1333022794/0#0 date=1333022794
    Peace.
    You cant use a double to pour into two separate cups? I love my naked pf. It does mean you can see every flaw in the shot. Even the little evidences of channelling that dont really affect the taste of the shot. But on the plus side. It encourages you to perfect your technique. =)
    Oct 2011
    Annerley, QLD
    560
    Check this out: http://www.home-barista.com/naked-extraction-common-problems.html
    Jun 2011
    57
    Thanks David
    I dont use the 2 separate cups very often and i figure that I will still have my other one if need be.
    Do you only use the NP?
    Jun 2011
    57
    Quote Originally Posted by 7C594E515C00380 link=1333022794/2#2 date=1333024084
    Wow awesome site thanks.
    This looks sweet
    Oct 2011
    Annerley, QLD
    560
    Quote Originally Posted by 5E535E4F485D0C0D3C0 link=1333022794/3#3 date=1333025455
    Thanks David
    I converted my single spout handle to a double. I still have the double, but it currently has a blind basket in it. So yeah, I only use my naked pf. And just take the coffee strong. =)
    Oct 2011
    Gold Coast
    223
    Hmmm dont think you mean two inches bobsta1. Thats a big distance for most most coffee machines* unless your jug block is on the drip tray and your mugs are on the block too.
    Ive got some very big mugs and they are 8-10mm too high to just slide under.
    Naked will give you lots more space and theoretically allow you to improve your pour. Ive archived mine for now as my wife doesnt care for it and using multiple pfs on a single group is problematic.
    Here are some suggestions while you decide on a naked or not.
    You could remove the pf* spouts. Maybe replace with short spouts if you want two cups to pour or like the look. Spoutless pfs arent as pretty.
    Or tilt your mug. If you are steaming milk you presumably arent drinkng long blacks. Even then tilting works for me and long blacks in a mug.
    Or remove the drip tray grate, sit the mug in the drip tray, wipe the mugs bum when done. Ive been using this method because its easy to clean the drip tray every coffee/set of coffees. Ive made it part if my routine. Sometimes I hold the mug above any mess if Im feeling fussy. It is only 30sec or so. Mind you two mugs at once could be a challenge.
    Ive used all these methods but settled on the simplest (I* think). Wife favours a simple tilt.
    Apr 2010
    26
    Quote Originally Posted by 7A777A6B6C792829180 link=1333022794/0#0 date=1333022794
    Peace.
    Well just measured mine the height on mine with standard PF 87mm* with naked PF 120mm. Fits a mug nicely.
    Jun 2011
    57
    Thanks Dabbler,
    I currently have the machine on a fat chopping board (about 2cm think) this helps a lot with the texturing. The wand seems a little short, but then again its probably more the case that my jug is to big for 1 coffee and i should invest in a smaller jug.
    I am currently doing as you are with taking the drip tray out, it is a good reminder to keep it clean and seems to be working well.
    And you are right 2 inches is a lot i think 2 cm is far more what i am after.
    Thanks for the info cruza, good to know!!
    I think I am still going to go with the Naked PF, I like that it will help me pour better shots and make sure Im not getting lazy.
    Keep the thoughts coming tho.
    Oct 2011
    Annerley, QLD
    560
    Just for the record:
    Quote Originally Posted by 5F5A5959575E493B0 link=1333022794/6#6 date=1333027555
    I disagree. I much prefer naked pfs. Or maybe I prefer the look of shots from a naked pf. Either way, I think npfs look better. But thats just my opinion.
    You could always buy a naked pf direct, that way you keep your double and single and solve all problems? :) See bottom of page: http://www.coffeeparts.com.au/domestic-parts/machines/rancilio-silvia-09-baskets
    Oct 2011
    Gold Coast
    223
    Quote Originally Posted by 0B2E39262B774F0 link=1333022794/9#9 date=1333067531
    Ha David8. Not quite what I meant. Should have said pfs with spouts removed compared to untouched pfs.... (as in the context of the para).
    Seriously though - can less chrome actually be better ? I think youre just into the pours.
    Oct 2011
    Annerley, QLD
    560
    Quote Originally Posted by 656063636D6473010 link=1333022794/10#10 date=1333069405
    Ah I see. That makes a lot more sense, and I agree with you now. And yes, I am into the pours. But with pours like reply #156 and #160 here: coffeesnobs.com.au/YaBB.pl?num=1197068083/150. Can you really blame me? The fifth photo from reply #156 is actually my iphone background. :p
    David
    Jun 2011
    57
    The look of the crema pouring out of the Naked PF is a thing of beauty that is for sure!
    Oct 2011
    Annerley, QLD
    560
    Quote Originally Posted by 030E031215005150610 link=1333022794/12#12 date=1333077312
    Sure is.
    Another benefit of the naked pf that I dont think has been mentioned is how easy it is to keep clean. The spouts dont get all gunky will coffee oils. Which can contaminate your shot...
    Even more reasons to go with a naked pf. :)
    Jun 2011
    57
    David Good point looks like im sold on it unless someone want to talk me out of it??
    Jun 2011
    57
    I got it boys and it is AWESOME
    Oct 2011
    Annerley, QLD
    560
    Quote Originally Posted by 5C515C4D4A5F0E0F3E0 link=1333022794/15#15 date=1333541010
    So glad you like it. Will we be seeing some lovely naked pour porn from you any time soon?
  1. Replies: 7
    Last Post: 10th October 2012, 01:41 PM
  2. Replies: 4
    Last Post: 23rd June 2012, 05:09 PM
  3. Replies: 2
    Last Post: 1st January 2012, 11:31 PM
