Results 1 to 3 of 3
Thread: Different pours from double and single spouts.
    Nov 2008
    9
    Hi all slight issue I cant nut out,grinder kony electronic machine linea, baskets 22g vst and 15g vst.Grind set with 22g basket double spout pouring just how I want it,single dose set to 15g basket same grind much faster extraction? still tastes fine but not ideal any ideas or suggestions?
    Senior Member David8's Avatar
    Oct 2011
    Annerley, QLD
    559
    Re: Different pours from double and single spouts.
    Quote Originally Posted by 2F2B212920272E2E237371420 link=1341352269/0#0 date=1341352269
    This forum is full of comments about the differences between singles and doubles. Check put gregs post for one. http://coffeesnobs.com.au/YaBB.pl?num=1341197814/9#9. The big long one by Pullman Espresso towards the bottom. The baskets are constructed differently and have different quantities of grinds in them. So yes they behave differently. Suggestions? Updose the single, if possible. Preferably use a second grider for singles.
    Mar 2012
    1,275
    Quote Originally Posted by 64606A626B6C656568383A090 link=1341352269/0#0 date=1341352269
    ..What is .."much faster extraction" ??
    Are we talking a 10sec pour ?.. or a 25 sec pour .? ( assuming your "Normal" is about 30 sec ?)
    * If the taste is good, why worry ?
    Otherwise,* what would you normally do to adjust the extraction time on any basket ?..
    .... :o..grind* adjustment !* ;)
  1. Single vs Double on EM6910
    By Senator in forum General Coffee Related...
    Last Post: 25th September 2008, 11:34 AM
  2. Silvia Double Spout and uneven pours - again
    By nikkikirks in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th March 2008, 07:14 PM
  3. Question on single shot vs double
    By liquid_gold in forum General Coffee Related...
    Last Post: 13th June 2006, 05:38 PM
