Results 1 to 21 of 21
Thread: How many grams for double shot are most people using?
    Jul 2012
    36
    I am curious as to how much in grams are most people putting in their portafilter for a double shot.
    I have been playing around with brew pressure (set at 9.5 bar) tamping pressure, bean type, grind and temperature and am consistent in each aspect now and i get a pretty good shot, however i feel like its not amazing and it could be improved. I then decided to weigh out the amount I am using and i found that i have been using 21 grams for my double shots. Maybe this is one reason why my shots arent at their best. I have a 51mm single wall basket and I am going to try different amounts to see what tastes better.
    But as a guideline, I was wondering how many grams most people are using for their double shots?? I know it depends on the individuals taste, but im just asking as a guideline to help adjust my dosing.
    Jun 2012
    Melbourne, Vic, Aust.
    1,025
    Re: How many grams for double shot are most people using?
    Quote Originally Posted by 3F3526380B66646664540 link=1341443707/0#0 date=1341443707
    When using a Sunbeam EM3800 we use around 18 grams in a Breville 2 cup single wall filter.
    10,496
    I too found I was using 21g when I started to expwrimate with weighing the beans. I went as low as 16g before settling on 18g in a Synesso basket for my Expobar Leva.
    Senior Member David8's Avatar
    Oct 2011
    Annerley, QLD
    559
    Ive been using 21g in an 18g VST basket to good results. Id like to head towards a 19g or 20g dose. But for now 21g is suiting me well. So why change? Maybe we could add a poll to this?
    Jul 2012
    36
    Thanks for the input. Im just about to try a few shots myself starting at 16 and then 18g.
    Do you find a difference in the kick you get from a lower dose. At the moment im liking the kick i get from the 21g and thinking that I will get less from a 16g double shot, or is the amount of caffiene for both the same and just the flavours change, or is the difference not noticable?
    Nov 2011
    25
    I use 18g in an 18g VST basket (or thats what I try and hit each time). For me I find that getting a good distribution and even tamp is probably more important than the dose. Using a naked portafilter really highlighted that for me. If your distribution is not even so that the extraction isnt even I think that will mess with the flavor much more than a few grams one way or another (with off-setting grind adjustment of course).
    Jul 2007
    2,286
    I try and get the same **volume** in the basket.
    As it differs between bean densities, the weight varies between 18.5 and 20 gm in the 53mm(?) Izzo basket.
    Jul 2012
    36
    Ive experimented with shots and found the 18g was best and was more full bodied, and tasted better than the 21g with no bitterness..!!
    Senior Member NakiChap's Avatar
    Apr 2011
    Perth , WA , Australia
    352
    I am currently using a triple basket I picked up from my local roaster, Im not sure of the baskets rating but I find 24-25g suits
    I split the shot in two, one 60ml AFC (short black for me) and one 210ml cup for my wifes flat white
    This gives me a nice rich espresso and also strong enough to cut through the milk in the other [smiley=thumbsup.gif]
    Jul 2007
    2,286
    Quote Originally Posted by 5952574A5D563E0 link=1341443707/7#7 date=1341487212
    Quote Originally Posted by 63564143734B5649454840240 link=1341443707/6#6 date=1341480473
    Thats interesting, its a very high dose for a Lever machine. and high dosing for most other machines.
    Are you using very light roasts? ( I only ask because overdosing has been a trait of 3rd wave style, light roast acidic coffee.)
    I personally have settled into the range of 14-14.5g - but I do prefer the traditional style of espresso.
    I drink a doppio ristretto either black or with an equal amount of steamed milk.
    I roast to CS 9-10, just before or on the first snaps of 2nd crack--so definitely not light.
    I use that dose cause it fits the "5 cent test" or just below. I never see a shower screen imprint on the puck while knocking it out, so while it might seem high it is well within the capacity of the machine, and less than I have used on E61 machines--but only by a gram or two. Besides, I like the taste. :)
    Remember, the Izzo Pompei is a **large** professional machine. It is not scaled down for domestic use in any way.
    Member Muscles's Avatar
    Feb 2011
    83
    For me and mine, 19.5g or thereabouts in a VST 18g basket
    Senior Member mwcalder05's Avatar
    Jan 2012
    Sunshine Coast
    437
    I use 22.5g at work in VST baskets on a Linear.
    May 2010
    80
    I'm a fan of double ristretto - so I go for 20g for a 50ml extraction between 28-30 seconds.
    Apr 2012
    WA, perth
    247
    i use 15g with a double basket on an expobar. i liked to idea of sticking to traditions at first with 14g doses but found it alot harder to level off nicely - especially when i switch to beans with not as much volume
    im pretty new to the site so please go easy on me... newbie question, but what is the 5 cent test?
    Oct 2011
    Annerley, QLD
    559
    Quote Originally Posted by timdimdom View Post
    It's a test to determine the ideal dose for your basket/tamp/machine combo. Dose and tamp normally. Place a 5c coin on top of the puck. Lock it into the group head. Then remove it, there should be a slight imprint of the 5c. This suggests there is less than the 5c's width between the puck and the showerscreen. This is ideal.
    Feb 2008
    308
    Quote Originally Posted by David8 View Post
    It's a test to determine the ideal dose for your basket/tamp/machine combo)
    Really? I dont think its a test to determine the "ideal dose", I suspect its a test that developed to allow for the maximum level of dosing for a given combination. Whether ths is 'ideal' is highly debatable!
    Oct 2011
    Annerley, QLD
    559
    Quote Originally Posted by galumay View Post
    Well. I find that if I under or over dose around this point. Especially with my finicky vst basket, I encounter problems... So I consider it ideal... But i do agree with your wording there. =)
    Apr 2012
    WA, perth
    247
    haha. which brings us back to the question asked earlier...
    Quote Originally Posted by glitch View Post
    I am just personally interested in what motivates the move away from the traditions of espresso and why there is such a common practice of very high dosing these days.
    Nov 2006
    979
    I have a number of theories.
    - Firstly, the switch to on demand dosing meant that we needed a way of measuring the amount of coffee. Filling the basket and then levelling became a popular way of doing this. It results in a high dose.
    - Specialty coffee, roasted lightly, high grown, high quality hard beans weigh more.
    - People want stronger tasting lattes. More coffee in bigger baskets result in pours that take longer to blonde
    - Its a trend, the coffee establishments given the press and cudos were using very high doses. This seems to be changing though.
    - More coffee in a basket results in more body, this is growing more popular for a few reasons.
    - there is no robusta in our coffee, this used to add body to our blends.
    - Pump machines result in less body then lever machines
    - its a trend
    Well thats what I reckon anyway.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,808
    !8 grams plus or minus .5 gram, depending on the age of the beans, in an 18g La Marzocco basket.
    Works well for me.
    16,681
    I never get 'hung-up' on the weight of beans to pull either a single or a double shot (mostly drink doubles, for what it's worth)...
    Rather, I dose by volume of coffee in the basket after tamping and since I hardly ever roast the same blend in a 6 month roasting cycle, it is not practical to use weight as the criteria since this varies quite a bit depending on the bean, roast profile, etc. With the same volume of coffee after tamping with the same degree of force, the resistance offered against the brew water pressure is quite consistent and results in consistently lovely coffee.
    Of course, just for the heck of it I always vary the dose slightly with any new beans, just to ensure there isn't a better 'sweet spot' for that particular batch. Often enough, an alternative sweet spot is found that encourages me to continue experimenting. Never be shy to change your dose quantity around a little from time to time - You may surprise yourself...
  1. 14 Grams of coffee in a single shot
    By pepsi in forum General Coffee Related...
    Last Post: 25th September 2016, 01:11 PM
  2. how many grams for a double shot?
    By acid_rider in forum General Coffee Related...
    Last Post: 28th February 2013, 05:41 PM
  3. How many grams in a double basket?
    By Billy-o in forum General Coffee Related...
    Last Post: 14th May 2010, 08:28 AM
