Results 1 to 4 of 4
Thread: Roast/Grind/Dose Variables
    May 2012
    18
    Just got my new machine and grinder and had it for a few weeks now, its been so much fun entering into a new world of discovery.
    I have been playing around with a few different roasts and trying to extract the flavours of the coffee. I noticed when I went from a medium roast to a french dark roast that if I kept the grind the same the coffee tasted really bitter and too strong. So after a bit of playing with the dark roast I found that grinding much coarser, over dosing and tamping heavily to stop any gushing produced really great and tasty results!
    Likewise I have noticed that with my favorite medium roast if I grind finer and pull back on the dose I get super smooth flavour with lots of chocolate and caramel tones.
    It seems getting the best out of a certain roast and blend depends heavily on grind/dose and tamp?
    Andrew
    Senior Member David8's Avatar
    Oct 2011
    Annerley, QLD
    559
    Quote Originally Posted by jaffa777 View Post
    Sure does. I usually find that most of my roasts like a similar grind with not much variation. But this is probably because I roast to a similar level every time.
    Senior Member insomnispresso's Avatar
    Dec 2011
    136
    @Andrew, there are some amazing articles over at HB on this topic under the title of.. "mano" something. Anyway its all about how you can change your dose/shot time to push the flavors in different directions, your example with the dose is echoed in that it says lower dose leans to caramels while higher is acids and bitters (not bad ones!).
    Another one is that making the grind coarser to get your 1.5-2oz shot out in less time, maybe 20-25 seconds bumps up the brightness. I think you can increase the strength of the bitters going in the other direction but I don't often do it =)
    Matt
    Dec 2011
    PRL
    2,588
    Quote Originally Posted by insomnispresso View Post
    They certainly are worth a read...though some of the participants are pretty high maintenance.
    I'm very much in a learning phase, but I do find that I enjoy the taste of some beans (partic. Centrals) with a lower dose / finer grind (16g in my double basket, as opposed to a normal 18-19g.....). This is sort of consistent with David8s remarks above, coz I tend to roast those beans a bit lighter.
  1. Do I have a roast or grind problem?
    By eaglemick in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 22nd January 2013, 09:29 AM
  2. Variables to a good Espresso
    By iaindb in forum General Coffee Related...
    Last Post: 28th October 2010, 10:32 PM
  3. Pour speed changes with constant dose and grind.
    By headingwest in forum General Coffee Related...
    Last Post: 10th August 2010, 06:34 PM
  4. Playing with variables - its important! duh!
    By WSullivan in forum General Coffee Related...
    Last Post: 5th September 2009, 04:15 PM
  5. city roast to dark roastne grind just for espresso
    By stanbrow in forum General Coffee Related...
    Last Post: 28th December 2008, 09:16 PM
