Results 1 to 3 of 3
Thread: How to identify processing method for Beanbay Greens?
    Dec 2011
    PRL
    2,586
    This might sound like a silly question, but assuming that it is not explicitly stated in the bean 'name' (origins/bean/estate etc), or in Andy's description on BeanBay, how does one determine whether a particular bean is dry-processed or wet-processed? Are they wet-processed (semi wet-processed) unless explicitly stated that they are dry or pulped natural? Or am I hopelessly optimistic?
    I'm trying to do Italian blend that has a base containing dry and wet processed Brazils, and have used the 2 green Brazils presently available. Should I assume that the Brazil Yellow Bourbon is wet-processed?
    BOSW
    (Mods please move to different sub-forum if more appropriate there).
    Mar 2004
    Internet
    16,678
    Blog Entries
    1
    Typically everything in BeanBay is washed unless I've stated that it's dry processed, wet hulled or pulped natural.
    Your guess was correct, that Yellow Bourbon is fully washed.
    I would also suggest not getting too hung-up on the processing. It's far better to ty it as a single origin and think how it would work in a blend. Generic "you need dry and wet process" is doomed to fail if the body, flavours and acidity are not what the blend component needs.
    When you make notes on a single origin roast include what the dominant attribute was. That will help you long term find the right bean to lift, fill-out or fruit-up a blend.
    Dec 2011
    PRL
    2,586
    Thanks Andy. Very helpful. And yeh I try everything as a SO first. This is basically an experiment to see whether a blend that I've made a few times using either of the Brazils as the base tastes substantively different using a 50/50 mix of the 2 (I'm guessing the answer is no....but no harm trying). Really like both of the Brazils in blends (and they were one of the last beans I tried.....stupid prejudice based on the lower end of Brazilian production).
  1. Chocky and processing it
    By Dennis in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 2nd September 2013, 03:08 PM
  2. !!!GONE!!! - 20kg of Beanbay greens
    By JJJ in forum Paid Forward - Taken
    Last Post: 16th March 2012, 12:39 PM
  3. Processing the bean
    By Presso in forum General Coffee Related...
    Last Post: 4th October 2006, 01:59 AM
