Results 1 to 4 of 4
Thread: Beans and brewing tempereature
    Aug 2012
    76
    Hi Guys,
    As being a new coffee snob, I am still in my early stages of learning... Actually, still trying to get the best shot, but with the help from other snobs in this forum, doing a lot of progress!
    I have one question though, and its regarding the brewing temperature.
    I heard that the brewing temperature should be set to the profile of the beans... I use Veneziano Forza but I have idea what would be the ideal temperature.
    Any guidance?
    Cheers!
    Mar 2004
    Internet
    16,688
    Blog Entries
    1
    Hi Cherni,
    the guys at Veneziano should be able to help you with that but as a guide try 94C +/- first crack and see what you like best.
    The temperature readings of your machine and theirs might differ too. I've seen commercial competition machines that had nearly second crack difference between the groups on the same machine so brewing temperature is at best a good starting point.
    Tweak to taste!
    Senior Member David8's Avatar
    Oct 2011
    Annerley, QLD
    559
    I would also not worry too much about temperature until all other problems have been sorted out. You don't want to be playing with two or three variables at the same time.
    Aug 2012
    76
    Quote Originally Posted by David8 View Post
    Yeah... That is true! Just curious about the temp stuff.
  1. Help with my brewing....
    By mgrobins in forum General Coffee Related...
    Last Post: 24th June 2011, 02:10 PM
  2. Beans Beans Beans French Press, Filter or Espresso
    By summercrema in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th January 2011, 08:56 PM
  3. Beans and brewing temps
    By Monti in forum Cup Tasting Room
    Last Post: 14th August 2007, 09:05 PM
  4. The new brewing beast .....
    By ajhclarke in forum Brewing Equipment (non-machine specific)
    Last Post: 4th August 2006, 11:23 PM
