Results 1 to 35 of 35
Like Tree9Likes
  • 2 Post By blend52
  • 1 Post By Brett81
  • 2 Post By dans1982
  • 3 Post By dans1982
  • 1 Post By dans1982
Thread: Mobile Coffee Cart Help Required Pls
    Aug 2012
    10
    Hey Guys & Girls i'm new to the forum but have been having a look around the place trying to get some information.
    I'm moving oversea's at the end of the year and will be setting up a small pedal driven (electrically assisted) coffee bike that I am starting to fabricate as we speak. My question to you is the obvious one.... power!
    Let me break down what equipment I am going to be using and if you have some opinions I would appreciate it greatly.
    Machine - Expobar Megacrem 2 group compact
    Grinder - Compak K8-Silenzio
    the hot water unit for the sink and the fridge & lights are accounted for my big thing is what size generator to use. I have seen many conflicting opinions on what size gene to use.
    Honda 2kva or 3kva? I have heard of some people using a 2kva to power that exact coffee machine with no issues yet from reading the specs on the coffee machine it draws 10amp but the 2kva only provides roughly 8amps.
    I'm scratching my head trying to figure out what to do, anybody running a mobile system that can offer some advice?
    Thanks so much for your time.
    Brett
    Hart's Coffee Cart
    May 2012
    1
    Hi Brett
    I run a mobile coffee cart and have had the same problem over time with different equipment, amperage, 10, 15, 20 amp etc.... The main thing to consider is when each piece of equipment is warming up ( machine, Fridge etc... ) it draws a lot of power on start up. It pays to turn one device on, let it power up fully before turning the next item on and so on. Electricians have given me the best advice of adding up the power requirements of all your appliances together and double it for the required gene then your covered in the most extreme circumstances, you don't want your grinder to stop working because the machine and fridge have maxed out your gene! for the sake of adding an additional 1/2kva! to be safe.
    hope this helps, feel free to contact me if you want to chat
    Jason.
    Hart's Coffee Cart
    Jan 2012
    113
    I'd suggest you go for the 3KVA.
    It's probable that at times you'll have both the boiler and the grinder running simultaneously which puts you way beyond the 2KVA gen.
    Imo last through you want is brownouts. They lead to an irregular AC sine wave and can trigger spikes - it's the same reason you don't over-drive a an audio amp on the premise that the speakers are way higher spec, they can still be damaged.
    Nov 2008
    22
    Hi Brett I run a small coffee trailer on gas and battery. It is a 2 group machine with a similar sized grinder to the K8. The battery runs 2 small draw fridges, grinder, water pump, espresso pump and optionally the element in the boiler. I can run on battery alone if necessary but I don't know how this would effect the long term life of the battery if I did it regularly. I have two 9kg gas bottles to run the burners under the boiler but only go through one every now and again so if I was aiming to reduce weight it could be much smaller and still run for days on end. I realise that you are looking at generators just thought I'd throw in an alternate possibility.
    Aug 2012
    10
    Thanks for the responses guys this has been killing my brain trying to come up with solutions
    Due to being a trike being pedal driven, electrically assisted tho I need to keep the weight down and obviously im looking at making it as cost effective as possible at the same time. Unfortunately the difference in a 2kva and 3va honda gene is about $2200 extra! but obviously if its what needs to be done then I have no choice. (Also weight then becomes a factor).
    robbogshs I was actually looking into this option due to the bike being electrically assisted I was going to try and run the fridge lights and grinder off the batteries (upgraded and with an inverter) and have the coffee machine and pump running off the gene. I think what I am going to do is just get the machine and grinder, put a watt meter on it to get a true indication of the actual output at FULL load to see what I will be up against. I believe at WORST a 3kva should cover me and at best a combo of 2kva with batteries running some of the gear.
    Harts I will PM you mate thanks
    AtomicGrog sound advice mate I do think I will end up having to go for the 3kva
    Mar 2012
    1,275
    So why have you dismissed a gas (propoane) fueled coffe machine and fridge ?
    Ideally a commercial lever machine for even less power demand.
    The weight of a 2 group machine and 3 kva genny will stop you pedaling that trike far ..even with elec assist
    Burnsy and Berrynicetomeetyou like this.
    Aug 2012
    10
    I haven't dismissed it but I haven't done any research on that option, so in short I would need to do some reading but from what i understand there isn't a great deal of gas powered machines on the market? (I could be completely wrong tho). If you could even point me in the direction to where I should be looking for gas powered machines I would really appreciate it.
    I have done all the weight calc's and once the trike arrives I will be running a series of tests and if the electric assist fails I will be upgrading to a petrol motor.
    Mar 2012
    1,275
    Many commercial machine makers do gas fired or dual powered boilers, and lever machines are particularly favored by the "cart" espresso stalls because of their low power and customer pulling appearance.
    Espresso on the go
    gas-fired boiler in a dual-lever Astoria 'Gloria.'
    Or for something simpler look at the Futurmat Palanca lever machine
    Aug 2012
    10
    ok new doors have opened to me!
    I have definitively looked at the lever option, I would have to undergo more training as I have never used a lever machine I have watched many video's but am keen to get some training under my belt and give it a go.
    but wow you have been really helpful I have some reading to this weekend
    Mar 2004
    Internet
    16,685
    Blog Entries
    1
    Quote Originally Posted by Brett81 View Post
    ...I would have to undergo more training as I have never used a lever machine...
    Training? Assuming you know how to make espresso now you would be pulling great shots after a kilo or two of coffee.
    Grind, dose, tamp pull the lever, let go, coffee comes out. ;-)
    I did see some great bike/trike mobile coffee setups in England a couple of years ago so worth trying to find those too.
    Also... check the local health regulations before you get too deep. You would have a lot of trouble in my council area getting anything approved without a hot water service and electronic taps.
    Aug 2012
    10
    Yes I have looked into it thanks Andy. They require a sink with hot/cold water which I have accounted for using caravan equipment.
    Yes I can pull coffee's well just never before on a lever machine. I am very green with lever machines though so I guess the big question would be how efficient could I be using a 2 group lever machine (ie at capacity how many cups would you expect to pull?)
    Yes Bikecaffe do an awesome machine set up I am a big fan of that set up. Mine will be similar but using a trike instead of the dutch cargo quad bikes.
    Dec 2004
    Earth!
    15,463
    LP fridges need to have the freezer plate level when sitting still. The further from level it is the less efficient the cooling is and if it's too far off level it will self-destruct. When in motion being level is not an issue as the rocking will keep the fluid circulating.
    It sounds obvious but many people forget about it. Remember to add in the weight of the water you'll be carrying. At a kilo per litre it quickly adds up!
    Java "Things to think about" phile
    Toys! I must have new toys!!!
    Aug 2012
    10
    Oh for sure I have taken into account the water weight, it wont be a factor on the way home but on the way to location i will be having 50kg extra weight!.
    I'm trying to keep the whole set up under 350kg.
    I am extremely keen on the battery/gas power option now so I am ever so grateful to Blend52 for pointing me in the right direction in respect to that. Im just working out my max draw of all the equipment so I can work out the correct battery set up.
    mcoccia likes this.
    Mar 2012
    1,275
    ...how efficient could I be using a 2 group lever machine (ie at capacity how many cups would you expect to pull?)
    Fracino claim that their 2 group lever can produce 360 shots per hour !!...but i guess you wont plan on that many straight away !
    Batterys:-- you are on a trike, so one word of advice...do not use any lead battery's ! the weight will stop you dead.
    research the newer battery chemistry's, Lifepo4 , LiCo, NMC, etc. or a few power modules from a Toyota Prius !
    The ideal for you would be some A123 20Ahr lifepo4 pouch cells...very light and very powerful..but rare as hens teeth
    2nd best is probably CalB modules...http://www.thunderstruck-ev.com/calb-180ah.html
    If you are not already a member , this site is the best source of battery info..Endless-sphere.com • View forum - Battery Technology
    Aug 2012
    10
    Again thanks so much Blend52
    I have made some calls about a Fracino & Diamond dual fuel machine just waiting on some feedback.
    I have also looked at the battery set up and again super helpful. I think my best option will be a 200ahr option from the thunderstruck website seems to be the best bang for buck. I work for a group of companies that has a solar division so we have designed a small solar panel system that will keep the batteries reasonably charged (of course weather pending) but will help for sure.
    Have you had any experience with the gas fridges Blend? i was looking at Gasmate 35L (I really only need to keep small amounts of milk and my milk jugs in there). But I haven't heard great reviews about gas fridges (they take a long time to cool etc). Most people are telling me to stick with an Engel 12v fridge which i'm leaning towards at this stage.
    Thanks so much for your time and help you have really changed the dynamic of my cart design.
    14,665
    Hi Brett,
    Gas powered levers do really well on mobile carts. Here are a couple of pix of a machine we supplied late last year for a solar powered coffee cart on a trike. They run a Kony and an inverter and are happy with the results and performance.
    Senior Member sidewayss's Avatar
    Jun 2010
    Perth, Western Australia.
    1,434
    Good luck with your venture Brett.
    Not sure if you had a look at this one?
    Coffee Bike, Barista Trike | Coffee Latino - The Market Leader in Mobile Coffee Vans
    Mar 2012
    1,275
    Just another inspiration for you..
    The Velopresso.
    Pedal powered grinder
    Manual lever machine
    Boiler fueled by spent coffee grounds
    Velo Presso : Pedal Powered off grid quality espresso COMING SOON
    Aug 2012
    10
    now that is cool!
    Sorry I've been off the grid for awhile BUT a few developments since last I posted. I have purchased a Fracino Contempo 2 Group Gas Powered machine with a K6 Silencio Grinder.
    I have managed to find a baby camping hot water unit (gas powered) to provide my heated water for the sink/tap and an Engel 12v fridge (40L) for refrigeration. Everything (including the bike) are in transit currently so i'm eager to get it all and begin fabrication. I will be running a custom 200w solar panel on the roof too which can provide up to 6a/hr which is great as I have calculated the loads and if everything was running at full capacity i would struggle to be over 8amps, so with a bank of batteries and an inverter i'm confident I will be ok.
    Weight is really my only concern but the bike motor is rated for 350kg of load on the tray so i'm hopeful it will do the trick if not its upgrade time!
    anyways I shall keep you up to date on the developments!
    Aug 2012
    10
    Whoops long time I forgot to post progress of my little project (which is now complete)
    anyways this is the finished product of 3 months blood sweat and tears!
    Jun 2010
    1,434
    Looks great Brett
    Looks like a great piece of kit to fit in a tight space at a saturday/sunday market.
    My only concern is back up stock unless it's only for small scale occasions. For larger events you would need another fridge.
    Another conversion I can recommend is a electric or petrol powered motor retrofitted to the bike if you need to travel a fair distance with that load on the back.
    In my neck of the woods, the powered bikes are very popular and not too expensive.
    Aug 2012
    10
    the fridge holds 12 x 2L milk containers and I have enough storage for 10kg beans and cups, plus all the other little ancillary items. Should be ok for the size of the operation but yeah the electric motor seems to be working well.
  23. #23
    Apr 2013
    24
    Hi Brett81. Any update on your business?
  24. #24
    Sep 2014
    1
    Hi, I started a coffee bike as well in Belgium and I have the same problem, how to power the coffee machine. I will buy a 2 group Facino espressomachine so I can use LPG/butane and electricity. I would also like to put a solar panel on the roof of the bike so the battery is being charged when I'm on the go. The problem is that I do not have any technical background at all. Can sobody explain me what is the best way to approach this. I understand the concept, but to adapt to my bike, is a whole other story. All help and tips are welcome.
    Thank you
  25. #25
    Nov 2014
    1
    Great read and ideas. What size gas hot water unit did you use Brett81.
  26. #26
    Oct 2013
    139
    I'm converting a cargo bike for some clients as we speak. ive used light weight form ply as the structure and a solid timber top with solid steel edges. Internally I've added 2 x 20l water storage containers + a container for drainage. There is enough room for about 20kg of beans and all the gear you need. I'm mounting a La Marzocco GS3 on top with a Kony e and I find the more weight I add the better it rides and feels more stable on the road. I'm going to mount a 5kva pure sine inverter generator to the back to run the show. It was only $700 brand new with 12 months warranty and runs everything with ease. The only thing we don't have yet is a water supply to rinse the jugs but I'll think of something. I'll post picks on Saturday when it's all finished.
    Draeger and Simplyhuman like this.
  27. #27
    Oct 2013
    139
    image.jpgCargo bike coffee cart photos as promised! Hope you like.image.jpgAttachment 8043image.jpg
  28. #28
    STS
    STS is offline
    Senior Member STS's Avatar
    Feb 2013
    103
    Great job. Looks fantastic.
    Sean
  29. #29
    Jun 2008
    78
    Dan's what's the secret to keeping the GS3 and Kony from falling off when your ate riding along?
  30. #30
    Oct 2013
    139
    The kony is strapped in underneath the bike in the storage area when riding along and I made custom steel brackets that bolt to the GS3 to brace the frame and strengthen it. Then bolt down to the bench. I used nylon washers to avoid any friction. One my way to fit them now so Hopefully all goes well as the subframe on GS3's are pretty lousy.
  31. #31
    Sep 2011
    Brisbane
    170
    Could you explain the whole power setup and water setup?
  32. #32
    Oct 2013
    139
    Underneath We have set up 40l of water storage and 20l drainage. Running filtered water from a Brita kit to fill the storage containers. There is a a 5kva generator that will sit on a custom platform on the back of the bike. This also helps to balance the ride. There is enough storage underneath for about 20kg of beans, knock tube, jugs ect and a 16l esky. It is literally a self sufficient mobile unit and it all works amazingly well. Very happy with the results.
    thebookfreak58 likes this.
  33. #33
    Jun 2017
    3
    What is the costs to set one of these little beauties up?
  34. #34
    Jun 2017
    3
    Have you seen the price of these things! $17,000 aud before shipping and import duty!
    Has anyone in Australia purchased one that you know of?
  35. #35
    Member lindsayward's Avatar
    Nov 2016
    Townsville, QLD
    30
    Quote Originally Posted by JTsilavis View Post
    I assume you're talking about the price of the Velopresso from Britain...
    I would also be keen to hear setup costs for anyone's trikes. Anyone happy to share?
  1. Replies: 11
    Last Post: 31st May 2011, 04:28 AM
  2. Mobile Coffee Cart
    By Trizo in forum General Coffee Related...
    Last Post: 11th April 2011, 07:42 PM
  3. Home Coffee Cart, mobile
    By koligi in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 9th February 2011, 08:44 PM
  4. Tassie mobile coffee set-ups ...
    By GrindOnDemand in forum General Coffee Related...
    Last Post: 2nd July 2008, 03:28 PM
