Results 1 to 12 of 12
Thread: Milk drawn into boiler
    Senior Member FineGrind's Avatar
    Jul 2012
    121
    How easy or hard is it to get milk sucked up into the boiler if you forget to purge the steam wand before and after steaming milk? It worries me.
    Senior Member Bernsbrew's Avatar
    Jun 2012
    Lane Cove, Sydney
    142
    I can't see how this would be possible with positive pressure in the boiler, can a boiler develop a vacuum?
    Senior Member Vinitasse's Avatar
    Aug 2010
    Mornington Peninsula VIC
    1,251
    Wouldn't negative pressure develop as the boiler cools? And, if there happened to be a bit of milk inside the steam wand, isn't it possible it could be drawn into the boiler as it cools after shutdown?
    Jun 2012
    Lane Cove, Sydney
    142
    You've got me worried now. Where are the engineers and physicists when you need them?
    Jun 2011
    684
    Very unlikely, unless your anti-vac valve is stuck, the machine cools down and you leave the wand sitting in a jug of milk all day, then open the steam valve (yes, I've seen it done).
    Jun 2012
    Lane Cove, Sydney
    142
    Anti-vac valve, is that what is sometimes referred to as a downstream valve? Also, if this valve does stick, wouldn't the boiler implode, since a boiler is only designed to withstand positive internal pressure?
    Aug 2010
    1,251
    Quote Originally Posted by Bernsbrew View Post
    Boilers do implode every once in a while. Rapid cooling without pressure equalization (i.e. opening up the steam valve) has lead to the loss of more than a few boilers over the years. Although, this does not seem to be as much of an issue with newer machines. Superior boiler design perhaps?
    Senior Member Pavoniboy's Avatar
    Jan 2009
    Minnamurra NSW
    693
    I would imagine not very difficult once the anti-vac valve is stuck. I say this as I bought an old commercial HX which had milk taint in the boiler. I had seen the owner use it and leaving wand in jug of milk etc was not what he did, however purging wasn't done either. Once home and and the machine properly assessed, the anti-vac valve was stuck and the steam coming out of the boiler was foul - very 'off-milk' taint to it which made any steamed milk undrinkable.
    I am confident that this machine became tainted due to anti-vac being stuck for some time and the wand not being purged so all it takes is someone to open the steam valve when cold, or the steam valve not sealing properly and that milk makes its way back to the boiler.
    I not only purge the wand religiously, but I also listen as my machine comes to boil to make sure that anti-vac valve is still working.
    Jul 2012
    722
    Would be more related to machine malfunction than user error on a newer machine.
    Nov 2009
    Altona, Melbourne
    1,584
    There are fairly regular threads where people have milk taint in their boilers. I always make sure that I clean and purge the steam wand whenever I make a milk drink, it's just good hygiene
    Jul 2012
    164
    Do you guys steam a jug of water after each use? I was told to do this. It only takes about 15 seconds and you see all the milk particles in the water even after purging. If anyone didn't steam the jug of water that would become stuck inside the steam wand and eventually go off..
    This would also avoid someone leaving the wand in a jug of milk etc. It's just a habbit I now obtain and I guess it just works.
    Aug 2010
    1,251
    Quote Originally Posted by neofelis View Post
    Steaming a jug of water is more about cleaning the outside of the wand. As for any milk inside the wand, that would have been forced out pretty quickly with the first few blasts of steam.
  1. Does steaming milk negatively affect the nutritional value of milk?
    By Dragunov21 in forum Milk Froth and Bubbles
    Last Post: 27th October 2013, 07:40 PM
  2. Please advice on Full Cream Milk and Skinny Milk
    By raja_kopi in forum Milk Froth and Bubbles
    Last Post: 31st August 2011, 12:40 PM
  3. Replies: 5
    Last Post: 28th June 2011, 05:40 PM
  4. Smallest boiler for great milk
    By dane5431 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th May 2011, 11:49 AM
  5. Milk taint in boiler
    By Dimal in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 15th June 2007, 09:33 PM
