Results 1 to 23 of 23
Thread: Coffee cup grate to protect machine?
    GMG
    GMG is offline
    Jul 2012
    44
    When I was in the UK, it was easy to get plastic cup grid from catering supply shops and cut it to size to put in the cup tray on top of a coffee machine, to protect the stainless steel from scratches. The stuff was used in bars, with the grid separated into roughly 1cm squares. I can't seem to find it in Australia. I'm looking for this, or any other alternatives to lay in the cup tray. I saw a silicone mat awhile back and can't find it again. That's another alternative...if I could only find it. Can anyone help?
    Senior Member David8's Avatar
    Oct 2011
    Annerley, QLD
    559
    Quote Originally Posted by GMG View Post
    Like these? Talk Coffee — Espresso Skinz
    10,496
    I don't care a bout a few scratches on top of the machine.
    Shows it's been used and loved.
    Each to their own.
    GMG
    GMG is offline
    Jul 2012
    44
    David8 - That's the mat! Thanks for this. I see the size isn't square, so not quite what I'm after. Attached are pics of the stuff I currently use. I'm planning ahead as I'm thinking of upgrading and thought I'd let the grid that I've got with my current machine go and cut to whatever size I'd need for the new machine.
    Senior Member MeanzBeanz's Avatar
    Apr 2008
    Perth
    111
    I found a solution at the kitchenware section of the Reject Shop about 12 months ago. It is a grid design in a woven material similar to thick cotton. It is heat resistant and can be washed. From memory I think it can go in the dishwasher. I just cut mine with scissors to fit the top of my Giotto PP. About $5.00.
    caffeinated lemoo's Avatar
    Oct 2011
    Perth, WA
    332
    hey meanz would you be able to get a pic of that up?
    Oct 2011
    Annerley, QLD
    559
    Meanz, does it allow enough heat through to effectively heat the cups?
    Apr 2008
    Perth
    111
    It lets the heat through and gives total protection to the surface of my machine. It is some kind of heavy cotton-like material. Evey now and then I throw it in the sink and give it a wash.
    I am in Perth cbd today so will swing by the shop I bought it from and see if they still have them and post more details.
    Oct 2011
    Perth, WA
    332
    I had a laugh get me some too and i'll come collect it from you haha
    I'm in perth too :P
    Apr 2008
    Perth
    111
    lemoo check your PM's.
    Oct 2011
    Perth, WA
    332
    GMG
    GMG is offline
    Jul 2012
    44
    Quote Originally Posted by Thundergod View Post
    Each to their own.
    I've been accused of being a bit of a maniac about care and maintenance!
    Senior Member DavidW1960's Avatar
    Jan 2012
    Kariong NSW
    546
    It's funny how people don't care yet if you browse the 'for sale' section people always like to say no scratches etc. I'm by no means paranoid but I did get the silicon skin linked above. A bit expensive but nice to stop machine getting scratched IMO.
    Oct 2011
    Perth, WA
    332
    i got silver polish to polish my giotto :S
    I had a laugh
    GMG
    GMG is offline
    Jul 2012
    44
    Quote Originally Posted by DavidW1960 View Post
    True! And one of the unintended benefits of the plastic grid (aside from protecting the SS) is that it's easy to slide the grid out, with cups on top and access the water tank. That way I don't have to lift the cups off when topping up the reservoir.
    Apr 2008
    Perth
    111
    Just returned from the Reject Shop and they don't have them in stock. I will check from time to time and post here if they come back in.
    Senior Member GrahamK's Avatar
    Jun 2009
    Ormiston - Brisbane
    554
    I use that non-slip style PVC Matting you can buy from almost anywhere these days. Comes in rolls and various colours, and just cut to size. Its possibly similar to the cotton one mentioned, so you do have to lift it to fill resevoir, but may suffice until you find exactly what you want.
    Mar 2012
    1,276
    I used a piece of clear self adhesive plastic book protector material.
    a little like an oversize Iphone screen protector !
    Simple to cut to size, peel and stick.
    cut out vent hole patterns too. It peels off easy leaving no trace of adhesive
    Machine looks as original, easy to wipe clean, not affected by the heat, and the added advantage of being non slip to the cups.
    Cost is probably 0.1 $ or less if you kids have some lying about.
    you could try some funky colors or patterns if you were so inclined !
    ST
    ST is offline
    Member ST's Avatar
    Dec 2009
    Murray Bridge
    63
    +1 to the non-slip material. I placed mine on top of the machine temporarily after I opened a jar some months ago and haven't moved since
    Senior Member brokenvase's Avatar
    Aug 2012
    Chapel Hill, QLD
    273
    Quote Originally Posted by ST View Post
    Can those take the heat? Wouldn't melt?
    Senior Member Vinitasse's Avatar
    Aug 2010
    Mornington Peninsula VIC
    1,251
    Quote Originally Posted by brokenvase View Post
    Most non-slip materials will leach oils even at room temperature and will probably stain the stanless steel it comes in contact with over time. High temp silicone is a far better solution and can be sourced from any decent kitchenware shop... look in the baking/pastry section for silicone sheets
    ST
    ST is offline
    Member ST's Avatar
    Dec 2009
    Murray Bridge
    63
    Possible, although I haven't seen anything yet on mine yet. I've also still only got an EM6910 which I leave on for really only an hour per day - the high-temp silicone should also do quite well.
  23. #23
    Jun 2009
    Ormiston - Brisbane
    554
    Quote Originally Posted by Vinitasse View Post
    will probably stain the stainless steel it comes in contact with over time
    It does not stain the SS, and can take the heat, although I agree it leaves a slight smudge after some time which cleans off easily. However it will prevent the scratching you are concerned about until such time as you find suitable silicone or similar which I also agree would be a better solution.
    GrahamK
  1. Can caffeine protect against Alzheimers?
    By Javaphile in forum General News
    Last Post: 23rd April 2013, 09:12 AM
  2. Coffee and tea protect against heart disease
    By Javaphile in forum General Coffee Related...
    Last Post: 23rd June 2010, 01:37 PM
  3. Warning to others - protect your Brita jug ...
    By Myrtle in forum Off Topic
    Last Post: 28th April 2007, 10:16 AM
