Results 1 to 4 of 4
Thread: grinder setting for different brew
    Senior Member summercrema's Avatar
    Mar 2008
    266
    I have a Mazzer Mini Electric and it is set to one or two step before 4 as I mostly drink latte, recently I have collected few more toys , a Hario woodneck, a Hario Syphon and a french press it would be a waste just having them sitting in the cupboard I want to put them to use but no sure what grind setting is right for them, someone might post the same question before on this forum can someone point me to the right direction. Thanks
    enjoy black coffee JamesM's Avatar
    Nov 2008
    Perth
    672
    a setting (number) isn't really going to help you. You need to adjust, grind a small portion out, and inspect it in your hand for coarseness for brew method. Aim for a medium coarseness for filter brewing (syphon, woodneck, etc). Experiment!
    Senior Member David8's Avatar
    Oct 2011
    Annerley, QLD
    559
    Quote Originally Posted by JamesM View Post
    I wonder if anyone has posted a photo comparing espresso to plunger to aeropress to syphon to cold brew etc. Of course there will be variations in each, but surely it'd be helpful.
    May 2008
    4,215
    Quote Originally Posted by David8 View Post
    I'm sure you might find a pic somewhere but I don't think such a pic will help.
    Just like JamesM's comment about not relying on a number, it really is only experience that will get you there. Pick a starting point on your grinder and work from there. Then adjust the grind and/or hone your technique. If you find a sweetspot for a bean you will use often for that technique, you could record it for future reference. eg. keep a notebook or stickytape a piece of paper to the grinder body with a list of favourite beans and your settings for the brew of choice.
  1. Anfim/ECA BEST grinder setting
    By Dazzler24 in forum Grinders
    Last Post: 11th September 2009, 05:37 PM
  2. grinder setting
    By summercrema in forum Grinders
    Last Post: 9th November 2008, 09:17 PM
  3. Aeropress Grinder setting
    By argon in forum Brewing Equipment (non-machine specific)
    Last Post: 16th June 2008, 09:44 PM
  4. EM0480 grinder setting not working
    By Not_Perfect in forum Grinders
    Last Post: 20th April 2008, 01:09 PM
