Results 1 to 6 of 6
Thread: What ground coffee weight is right?
    Jul 2009
    32
    Hi
    All I have a new Mazzer mini and seem to be having some issues with what is the correct weight to use. I see a lot of folks reckon 14-15 grams of ground coffee. This seems to be a little as I usually use about 20-21grams. Can someone set me right as if 15 is the go i need to make my grind finder
    Noel
    May 2007
    Perth, Western Australia
    3,168
    Hi Noel, if you have been using 20-21g and getting good results there is no reason to change your dose, you may have to set the Mini finer or coarser depending on the quality of your shots. Enjoy your new grinder
    cheers Trevor
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    The amount of coffee also depends on the basket that you are using. If you are using a single, double or triple basket. Even between a single basket you can get 7gm (useless) and 12gm baskets etc.
    Dec 2011
    PRL
    2,729
    There's a thread on another site where a bloke has taken a number of commonly used double baskets which have notional weights of 14-15g, and then filled each one level to the top (with out tamping / settling). All of them take b/w 18-20g (IIRC), even without settling, re-filling etc. So don't worry. If I follow Fresh Coffee's dosing advice using the standard basket that came with my Diadema, it typically results in a 21g dose...and tastes pretty good. If I put that much in my Synesso / VST double baskets it doesn't taste so good (for these I use a lower dose / finer grind).
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,247
    Noel, you asked a similar question 1 week ago here How much ground coffee for a double shot and received some excellent advice, time to start experimenting and forming your own opinions/preferences.
    As Attilio said in the other thread "if the question is "How much ground coffee for a double shot" the answer from my point of view will have to be: whatever amount fills that filter to the correct level for the espresso principle to work effectively."
    We still don't know what type of machine you are using!
    The Mazzer Mini is a pretty good grinder so you should have no problems in that department.
    Mar 2012
    1,276
    you are asking the wrong question.,,Dose weight will vary depending on..machine in use, basket size , bean/roast, etc etc
    You should be asking..
    " where can i learn how to set my dose and grind correctly for my machine"
  1. Accurate scales for measuring coffee weight
    By oneday in forum General Coffee Related...
    Last Post: 28th October 2009, 05:18 PM
  2. Does bean weight = ground weight
    By argon in forum Grinders
    Last Post: 8th September 2008, 12:56 PM
  3. Green Coffee Promotes Weight Loss?
    By TEPIN in forum General News
    Last Post: 7th May 2006, 10:17 PM
  4. Weight of a bag of coffee beans
    By Robster in forum General Coffee Related...
    Last Post: 6th December 2005, 07:48 AM
