Results 1 to 24 of 24
Thread: Overextraction.... um... what is it?
    Dec 2006
    113
    Im still on my first star so Im forgiving myself for asking what might APPEAR to be a silly question... * :-[
    Im confused as to exactly what overextraction is/means. I know it has something to do with time (30sec?) and volume (30mls?) but people seem to use the term with careless abandon (Im being dramatic I know) and now Im confused.
    I dont know whether its too much water through the coffee, water taking too long to get through the coffee or something else like just weak coffee? :-/
    So once Ive worked out the exact definition (yes Ive done a search)... what are the variables that might cause it (I need lists peoples)? And why might these variables cause it.
    Also, is it all the same for a double shot - just double?
    hmm, I think thats it. thanks in advance!
    If there is a thread out there that deals with this Id love to read it. I couldnt find it though.
    Meg
    p.s. I couldnt work out what topic this question should go under sorry if its in the wrong place.
    3,498
    Re: Overextraction.... um... what is it?
    meg-e
    Not a silly question at all (IMHO the only silly question is one which is not asked! ;))
    This is actually a difficult question to answer.... but Ill have a go..
    Over extraction occurs when the flavours, coffee oils, and other "good bits" which we want have been removed from the coffee grounds.... you then get bitter, unpleasant tasting liquid going into your espresso which spoils the flavour and texture.
    The first thing to realise is water is lazy - it always takes the shortest path through the coffee puck..... so if the grind isnt evenly tamped (not flat or not tamped at the edges properly - thats where the water will go - and pretty quickly remove the wanted bits in those relatively small areas.... so you rapidly over extract the grounds in those areas..... (and extract nothing from the rest of the puck)...
    If the coffee grinds are too coarse.... you extract the wanted bits from the outer layers of each bit of coffee.... and nothing from the inside - again the coffee is over extracted quite quickly....
    If you have a deeper basket- therefore more coffee grounds- you can extract more before you start to extract only the nasty stuff.
    If you want a flat black.....and you have tamped correctly and the grind is the correct size.... but you continue to pass water through the puck... you will get coffee which is over extracted...
    So what has all this to do with 30ml in 30 seconds (some say 25 seconds)?
    Well, assuming the coffee is the correct grind size, and you are tamping correctly (flat top on the puck, tamped right to the edge with 13.5 Kg of force).... you should get 30ml of beautiful tasting espresso in 30 seconds from a single basket or 60ml in the same time from a double...... and that is what you aim for.....
    However there is a tell tale sign of overextraction..... instead of the nice dark crema you will get when the bits you want are being extracted, it will turn light in colour - usually referred to as "blonding" - at that point stop the extraction or you will get the bitter unwanted flavours....
    Blonding might occur at 20ml.... (too early- but stop the extraction anyhow)... most of the flavour you want is in the first and second third of the extraction - you will still make a vey nice coffee- but it wont be quite as strong.
    If you keep going - you will get over extraction - and nasty tastes....
    Always aim for the 30ml in 30 seconds.... but as soon as you get blonding - stop the flow and you will avoid over extraction....
    If it comes out blond almost from the start.... you havent got even water flow (tamping problem) or the grind is too coarse - and you will be over extracting straight away...
    I hope that isnt as "clear as mud"....
    EDIT: I forgot there is another type of over extraction (just in case I havent confused you too much already)
    If the water passing through the coffee is too hot (not normally a problem) it also extracts too much of the bitter, unpleasant coffee oils which normally are extracted after the ones you want in your espresso.... its sort of normal extraction and over extraction occurring at the same time ::).
    Nov 2005
    54
    Recently I tried pouring off the first half of a mocha-pot brew, then letting the rest gurgle though in the normal way. The first half was nice, a superior brew. The second half was truly foul. It tasted downright unhealthy. Thats one way to get an idea of over-extraction. (The thought that most people with mocha-pots drink the entire through-put is a bit disturbing).
    Dec 2006
    118
    Ok, before this thread gets overextracted, heres my 2 cents worth, as I understand it:
    To put it simply:
    1. Overextraction: When the grind is too fine or tamped too hard, the coffee takes longer to come through the puck and when it does come out it drips from the portafilter (PF), rather than flowing in the shape of a mouses tail, and is black in colour. Taste is bitter.
    2. Underextraction: When the grind is too course or tamped too light, the coffee comes through the puck too quickly and gushes out of PF. Is light or blonde in colour. Taste is weak.
    So the variables are, primarily:
    A) Grind
    B) Tamping pressure
    A double shot is usually one shot pulled and then another separate shot pulled and added to the first. So, if the first shot is good and both shots are done the same, there should be no diff to doing a double shot to doing a single. But it would of course be possible to pull the first shot
    correctly, tamp too hard on the second shot and get the second shot overextracted. Or tamp too lightly and get it underextracted.
    The alternative to a double shot is what some people call a "strong" coffee. Which usually means they just let the pour go a bit longer on a standard shot. I find this a poor substitute for a double shot!
    You can also have a Ristretto -- just the first half of the pour -- by stopping a normal shot early. Dont go the full 30mls in 25 secs, stop at about 15mls in 15 secs. This also gives a fairly strong coffee because it contains higher concentrations of the coffee oils in the liquid. (The longer the pour, the weaker the pour gets). A double ristretto is another strong coffee choice and is the same as a double shot (ie, two separate shots pulled and then combined in the one glass), but with 15 sec pours instead of 25 sec pours.
    Hope that confuses matters up! ;)
    3,498
    meg-e
    Now I said it wasnt easy..... you now have two different views....
    To add to your confusion.... Ristretto is italian for restricted.... the other way of making a ristretto is to reduce the grind size.... and so reducing (restricting) the amount of water which can flow through the puck..
    The grind is chosen so that you get 15 ml in 30 seconds (single basket) or 30ml in 30 seconds (double basket) the resultant coffees being a single ristretto and a double ristretto respectively.
    Both methods are used..... ( half time pour and finer grind pour) but the flavour produced is different in each case - the half time pour is easier for the barrista (he/she doesnt have to alter the grinder!!)
    Now you are really confused :-/
    Apr 2006
    1,562
    Quote Originally Posted by JavaB link=1170933141/0#1 date=1170936251
    meg-e
    I would have considered this as "Under extracted" ??
    Where as when blonding occurs after the initial 30mil/\/30sec has passed then yes, over extraction... If it happs earlier, then some adjusting of the grind a tab finer OR - updose more...(this would depend of you have a nice puck or not)
    Marc
    Apr 2006
    1,562
    Now, you can pull a "tighter" espresso pour using something like "25mil in 40sec" then Id refer that as a ristretto... anything tighter you may have a "over" extracted and youll get bitter espresso....
    This is a very good discussion - thanks for asking the question Meg-e ... (Im sounding like a politician answering a question from his fellow party member - I thank the honourable member for there question... etc etc)
    Further to this, every espresso machine is different... some updose well, some dont etc etc...
    Marc
    Apr 2006
    1,562
    JavaB - you beat me to the ristretto part
    Marc
    3,498
    Quote Originally Posted by marcstolk link=1170933141/0#5 date=1170971411
    meg-e
    Marc
    Marc...
    Yep it is a very interesting question from Meg (and sure isnt easy to answer)
    I guess it depends whether we are looking at the product (whats in the cup) or whats left in the coffee puck..... a fast pour is taking the oils etc from the surface of the coffee grounds..... and pretty soon it has removed the wanted ones and then the bitter oils start to appear in the cup (over extracted)....
    but most of the good oils remain in the coffee grounds in the basket - they have been under extracted......
    Kind of a glass half empty / glass half full discussion ;D
    Apr 2006
    1,562
    So true JavaB.. so true....
    Dec 2006
    118
    Ok, I got caught out. *:( Trying to dish out knowledge i didnt have *::). Stuffed up the ristretto thing *:P.
    Youre right, you adjust the grind or the tamping so the flow is restricted and you only get 15ml in 20-25 secs (not 15 secs, as i was thinking).
    I stand by what i said about overextraction. But you are right also. Its all to do with how much of the oils are extracted by the flow of hot water. Too fine a grind or too heavy tamping will choke the flow and cause it to leech too much of the oils out of the grounds by the time it gets through the puck. Overextracted and bitter. So in this scenario, overextraction is in process even before the coffee starts to drip out of the PF.
    But I can now see what you were saying, JavaB, about the extra-long pour also leading to overextraction. I wonder, is it due to different oils (more bitter in taste) being extracted, or a difference in surface oil and oil deep within the grounds (if there can be deep within a coffee ground!) or a difference in what happens to the flavour of the oil if exposed to boiling hot water for too long (gets burned)?
    Likewise, in my scenario above, do you agree that it leeches too much of the oils or do you think it is that the oils get burned by the hot water not flowing and thereby spending more time (and presumably applying more heat) to the puck and its trapped oils?
    Oct 2006
    203
    This is the way I look at it, and I may be wrong, but this is the way my logical brain works:
    The over / under extraction refers to the coffee grounds left in the basket, after the shot has been poured.
    If the coffee grounds have "good bits" (Ill leave the pros to define the good bits) left in them, then they are underextracted. *If the coffee grounds have all the "good bits" extracted, plus some of the "not so good bits", then the coffee is over-extracted. Then theres the bit in the middle of the two extremes where the coffee is good.
    My brain is also a tad scientific, and I have found a few articles over time that explain what actually gives coffee its taste:
    http://cosmicvariance.com/2006/08/07...ence-of-coffee
    http://www.coffeeresearch.org/science/aromamain.htm
    http://www.coffeeresearch.org/science/bittermain.htm
    It may or may not help you to make a better coffee, but it sure is some interesting reading, and puts a bit of scientific explanation around extraction.
    Aug 2005
    1,530
    I like the non-scientific version better. Over-extracted = crap, under-extracted = crap.
    You can over-extract a shot and still have the required volume. Same with under-extraction. Brew temperature in this case is the culprit. Bitter shot vs. sour shot.
    3,498
    Quote Originally Posted by nunu link=1170933141/0#12 date=1170983624
    ;D ;D ;D ;D
    nunu...
    Ive got to agree with that statement..... if all the good bits are in the cup and the bad bits are in the puck - we have correct extraction...... the rest is down to semantics... but you have defined it very accurately as cf@p coffee!!!
    Now onto the meaning of life?- easy answer- to get the least cr@p during whatever time we have ;) ;D ;D ;D
    Dec 2006
    113
    Gawd!
    Thank you so much for spending so much time answering this! Im sure you had other things to do - I appreciate it! * :)
    And I guess Im glad I asked! :-/
    Ill need to read it all through a few times but Im sure Ill get there. Im using a presso and its all a bit manual and inconsistent at the moment so Im looking to narrow down the variables. I suspect grind size might be my issue but Id rather work through it systematically.
    Thanks again, I hope this has also helped anyone else who was wondering the same thing.
    Meg
    3,498
    Quote Originally Posted by mean bean link=1170933141/0#10 date=1170980815
    mean bean.....
    A sort of non technical explanation (which works for me)...
    Remember the sugar coated nasty tasting pills you give to children.....
    Well if you swallow them fairly quickly - before the sugar coating is dissolved- they leave a sweet taste in your mouth...... extract the flavour for too long - by sucking on the sweet coating and then yuck!!!
    Chew the tablet up so it is smaller..... and the nasty taste starts sooner....... and if the pill is too large to swallow.... you have to chew it first.....
    The more technical explanation goes into the volatility of the various oils, the temperature which these oils are extracted, their depth below the surface of the coffee grain etc......
    Even correctly extracted coffee has different components during an ideal 30 ml shot..... Next time you make an espresso.... collect it into 3 shot glasses - 10 ml in each.
    Taste the first 10 ml...... rich smooth and sweet
    2nd 10 ml.... not as rich or as smooth and the sweetness will be a lot lower.
    3rd 10 ml... starting to get bitter and unpleasant... no smoothness left...
    Combined together they taste fine..... but continue extraction and the quality gets less and less causing the overall taste to rapidly deteriorate.....
    The 30 ml volume is a good compromise..... you could just extract 10 ml which would be wonderful..... but you would require a lot more coffee (plus some people actually like a little of the bitter taste).
    Jan 2007
    27
    Quote Originally Posted by Kaffee Schnüffler link=1170933141/0#11 date=1170983339
    The article by Illy linked from the above that Kaffe gave is a fantastic read. In there he goes into quite a bit of technical detail about what makes up the shot and the differences in under/over extraction.
    Great for people like me that like to understand such things at a deeper level 8-)
    10,496
    Quote Originally Posted by JavaB link=1170933141/0#8 date=1170972253
    Everyone keeps forgetting the third option........the glass is the wrong size.
    16,680
    Hi All,
    And heres a link to an explanation about the finer points of coffee extraction, in a practical sense, from Home Barista. The relevant info is found towards the latter half of the page,
    Dec 2006
    118
    Quote Originally Posted by meg-e link=1170933141/0#14 date=1170999548
    I dont know what gave u that strange idea. Other things to do?!!
    Are u kidding!! Were Coffee Snobs. What else is there in life besides talking coffee?!! ;D
    Apr 2006
    4,126
    Quote Originally Posted by mean bean link=1170933141/15#19 date=1171065799
    Im sure you had other things to do - I appreciate it! :)
    Exactly! Since a certain event in my life, it comes to pass that some of my local friends are finding out what I do with some of my spare time! Any way, some were having a chuckle at the fact that there is a whole forum dedicated to all things coffee! Like, their point being "Its only a cup of coffee!". I started to rattle off the different forums we have for discussing coffee and their mouths dropped open in amazement. When I got to the part about roasting at home that really floored them! I had a laugh! :D
    Aug 2006
    1,588
    Meg-e as a presso user myself, grind size, good tamping and pre-heating the presso and group head have been the three biggies for me. I always pull the shot early too.
  23. #23
    162
    JavaB, your explanation is great. I would just summarise by saying that, if your temperature and pressure are correct, then other factors can cause local overextraction at the surface of the coffee grain, but global underextraction of the puck. This is why I would say that even early blonding is usually over - not under - extraction, as you said. It is interesting, is it not, that coffee snobs can still have lots to discuss about even the most basic of (coffee) lifes questions?
    Quote Originally Posted by JavaB link=1170933141/15#15 date=1171000974
    Yes, but that would assume that you only want a rich, smooth, sweet taste in your cup - a bit two dimensional, isnt it? You know, if you let the pour go for a few seconds into the blond, you can add a few high notes to the flavour which are not at all unpleasant. It is all about balance; too much of the smooth, and it is a little dull. Too much of the harsh, and it is undrinkable. A balance of different tastes produces a well-rounded cup, much like a balanced wine, with the right proportion of tannins, acids, sugars and fruits. At least, this is what I prefer. This is perhaps why true doubles are harder to pour, and harder to appreciate, but in the end are more complex and satisfying.
    I think you have made it much easier for Meg-e and others to understand this very important concept.
    Matt
  24. #24
    Dec 2006
    113
    Quote Originally Posted by grendel link=1170933141/15#21 date=1171102158
    thanks Grendel
    Does pulling the shot early mean not letting the puck get too wet before pushing the arms down? or does it mean cutting the shot short after it starts pouring?
    That is... I hold the arms up for 10 seconds after pouring the water in before I pump the arms. Do you do this for less time? and I wait until Ive squeezed the last drop of water out of the machine (Ive been doing a double pump as thats what I saw Cam do).
    Im playing around with grind size at the moment (variable numero uno). I would have thought it is best to start coarser and gradually go finer or is it the other way around?
    I practiced tamping on the bathroom scales much to the amusement of significant other. Cant seem to do 14kg (is that right?). So *Sigh*... now I just HAVE to get a Pullman Tamper! *;D
    Thanks again everyone for the discussion
    Meg
