Results 1 to 3 of 3
Thread: Giotto premium problems
    Nov 2005
    52
    I recently upgraded from BZ99 with rocky grinder to Giotto premium with Anfim Best grinder (both second hand). This is the problem I'm having:
    1. Wet puck - at the end of the shot there is a little water on the puck and it is soft. A finer grind setting gets rid of water and the puck is firm but see 2.
    2. Grind is either too fine (coffee comes out in drops rather than stream) or too course (stream is too fine and early blonding with wet puck).
    3. Coffee comes out of the left spout a long time before it does out of the right spout. If I just let water pour out (without coffee) it comes out of both spouts evenly.
    My dosing is consistent (half dose, two taps, finish dose, two taps, level) and my tamp is the same for all shots.
    Boiler pressure is at 1.1.
    I roast my own beans and they are about 5-7 days old.
    I'm at a loss as to how to correct it.
    Any advice is appreciated.
    Tal
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    Quote Originally Posted by talbashan View Post
    Tal
    Hi Tal, a few questions and some answers.
    Firstly what sized basket are you using? Don't botther with the 7g basket it's hopeless.
    Secondly I don't doubt you have a consistant tamp style as you are consistantly getting coffee out of the left spout. Check that you are not consistantly slanting the tamp one way or the other.
    Is the Anfim Best a stepped adjustment grinder? Supposing that the single adjustment to coarser is causing too fast a flow the only way to compensate is to updose a little and slowing the flow that way.
    Hope that helps.
    Nov 2005
    52
    Hi Saoye,
    Thanks for your reply. I use the double basket (14g I think). As for slanted tamp, I too thought that it may be the problem but I take care to tamp evenly (Pullman tamper had level rings to help with this).
    Ill give the up dosing a go.
    Thanks,
    Tal
  1. ECM Giotto Problems
    By mattt in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 4th August 2010, 12:39 PM
  2. question - Giotto PP or giotto premium?
    By cafe_lover in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th January 2010, 12:16 PM
  3. Giotto Premium
    By panda in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 20th February 2009, 03:29 PM
  4. Differnce between Giotto Premium and Premium plus
    By patto21 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2009, 07:59 PM
  5. ECM Giotto Premium
    By Jimbo in forum Brewing Equipment (non-machine specific)
    Last Post: 24th July 2006, 01:15 PM
Tags for this Thread
