Results 1 to 7 of 7
Thread: Espresso Machine Maintenance
    May 2010
    14
    I regulary backflush my machine, however what this doesn't do is descale the inside of boiler. Is there a product out there that can do this and how often should it be done?
    May 2008
    4,188
    Yes, there are products that can do this but there are pitfalls.
    What machine do you have?
    How long have you had it?
    What part of Aus do live in? (ie what is water quality like. Some water supplies are 'harder' than others)
    Do you use filtered water?
    May 2010
    14
    Rancilio Silvia
    18 months
    Sunshine Coast
    Yes, Qld
    May 2008
    4,188
    OK. I've used Clean Machine Triple Action in the past without problems (following the directions). Try a search on CS of 'descale silvia' for others' experiences.
    Is there a problem with your Silvia, suggesting a descale is required? Some, with better knowledge than me, say that a descale is a remedial action rather than maintenance.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,241
    Quote Originally Posted by flynnaus View Post
    Not suggesting my knowledge is any better than yours Flynn, however, had a Silvia for almost 10 years, replaced it 2.5 years ago with a Bezzera machine.
    I don't run a water filter of any kind and have religiously descaled both machines every 8 weeks with Cafetto Restore, have never experienced a scale or boiler related problem with either machine.
    So as far as I'm concerned descaling is part of my maintenance routine and never has been a remedial action.
    May 2010
    14
    No, no problems with it, just a thought it may have to be routinely done. If I look into my kettle, I see no evidence of calcium build up over the last 5 yrs, therefore suggesting that there should be nothing in the boiler I suppose.
    Aug 2012
    21
    How often it is needed depends greatly on how hard the water is in your area. For instance the water in Queensland is known to be a lot harder than in Melbourne.
  1. Espresso: What Cleaning, Maintenance, and Brewing Accessories?
    By SlowRain in forum Brewing Equipment (non-machine specific)
    Last Post: 18th June 2009, 10:18 PM
  2. Espresso machine maintenance
    By kohi in forum General Coffee Related...
    Last Post: 15th August 2008, 09:26 AM
  3. Maintenance of Commercial Espresso Machines
    By ozscott in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 3rd May 2008, 08:15 AM
  4. Machine maintenance
    By Fulcrum in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 20th June 2007, 07:09 AM
