Results 1 to 2 of 2
Thread: What am I doing wrong?
    Dec 2012
    Brisbane
    38
    Sunbeam EM5600, holding pressure somehow in the group head so even after steaming the milk etc, it will "blow off" and splatter the grinds when I release the handle from the machine.
    The puck will be very wet and muddy, splatters everywhere if you use the knock box.
    I have been experimenting with packing/tamping methods as the crema is still flowing too fast.
    Nov 2006
    979
    your coffee machine has a dual wall filter basket otherwise known a creme enhancement etc. If you pull the filter basket out and have a look you will see that there is only a single small hole in the bottom. It's designed to give acceptable pours when you are using store bought pre-ground and stale coffee. I may be wrong but I don't think your machine has a pressure release valve either. So when you finish your pours there is nowhere for the pressure to go as it is not released until you unlock your portafilter.
  1. What could be wrong ?
    By blaggon in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2012, 07:47 AM
  2. what am I doing wrong?
    By tonym1 in forum General Coffee Related...
    Last Post: 6th June 2011, 03:47 PM
  3. What am I doing wrong?
    By RobatFarrer in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th December 2010, 08:53 PM
  4. What am I doing wrong???
    By thomm0 in forum Milk Froth and Bubbles
    Last Post: 17th July 2008, 08:10 AM
  5. What can wrong will
    By Stan in forum Roasters
    Last Post: 14th June 2008, 07:38 PM
