Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By brettreaby
Thread: My DIY Scace
    Senior Member brettreaby's Avatar
    Oct 2011
    267
    My DIY Scace
    for a bit of fun and because i scored a suitable pressure gauge for free , i have made up my own scace.
    The scace is built onto a backflush disk which fits into a blind portafilter: it can be removed from the portafilter when done and easily re fitted.
    The hardest part was making a bleed system; in the end i have a 1/4" bolt drilled and tapped with a 3mm bolt which can be loosened or tightened to allow the required flow.
    I adjusted it to give 30ml in 20 seconds ( flow rate 1/2 way between a single and double shot)
    I also have access to calibration so calibrated the gauge to 135psi (9 bar) so i know its accurate to about 1%.
    I've used it to calibrate my Izzo Alex and the good news is the gauge on the Izzo is exactly on 9 bar after calibration. I needed to do this becuase Chris calibrates them using tank water feed and in the plumbed in setup you have additional pressure.
    Interested in any feedback- have i missed anything?
    Andy likes this.
    Jun 2011
    684
    Temperature! Without a temp probe of some sort this is not a 'scace' or anything resembling one, but its a bloody nice pressure test device. Love that huge calibrated gauge!
    Oct 2011
    267
    yeah its a Wika 0-500psi reference Gauge which they had to give us when they shipped us some dodgy transducers ( long time ago mind you- good product). Straight out of Batman's Batcave. full NATA certification.
    Temp sensing i might address later but it aint that simple as bunging a probe in there.
    Jun 2011
    684
    Incidentally and slightly OT, sorry, I've been trying to find a source for Wika gauges in melbourne / Oz generally. Any ideas?
    Jan 2013
    16
    Quote Originally Posted by coffee_machinist View Post
    ->>> Buy Analogue Positive Pressure Gauges Pressure,gauge,50mm,bottom entry,R1/8,1.6 bar/psi WIKA 7833926 online from RS for next day delivery.
    edit
    and here ->>>http://www.wika.com.au/contact_distr...ActiveID=22922
    Jan 2013
    16
    just posted a couple of links for you and they were there for a while and now have disappeared??????
    google Wika aus and you'll find the info you need or RS electronics and Blackwoods sell their gauges - no association with either/any/nada
    this thread and a little more reading got motivated to do the volumetric check on my Silvia Ver 1 and find that on volume the pressure is way too high 150ml/min or 12 bar!!
    just put in a copper washer and got 280ml - now to re-learn everything all over again - always wondered why my grind was near the bottom limit of the Rocky
    Oct 2011
    267
    We have an oem deal with wika they do have a Melbourne office , but their sales contact is in sydney. See their website in contacts section.
    They have an amazing range of stuff it's cherman so it must be gut!
    Jun 2011
    684
    so good even the Swiss use German gauges! Thanks all, Blackwoods seem to have what I want. 40 mm side entry plastic housing in a range of kPA. Win.
  1. Scace Wanted To Hire
    By vicroamer in forum Brewing Equipment (non-machine specific)
    Last Post: 10th November 2011, 05:41 AM
  2. The Science and Use of Scace Devices...
    By Apple in forum Brewing Equipment (non-machine specific)
    Last Post: 23rd June 2011, 10:39 AM
  3. Anyone with a Scace in Adelaide?
    By borat123 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 4th July 2009, 08:32 PM
  4. Scace Device Clone- Where?
    By Paolo in forum General Coffee Related...
    Last Post: 13th May 2009, 04:55 PM
  5. scace device?
    By tanghy in forum General Coffee Related...
    Last Post: 23rd April 2007, 11:39 PM
