Results 1 to 6 of 6
Thread: Safe to check in Smart Grinder at the airport?
    Senior Member brokenvase's Avatar
    Aug 2012
    Chapel Hill, QLD
    273
    I'm buying it for a friend. Do you think it is ok? Even if we say its fragile? Anything I can do to secure its transport better?
    Dec 2011
    Toowoomba, QLD
    133
    Put it in a Pelican or Otterbox case? Otherwise, well padded in the middle of a larger suitcase.
    It's probably light enough for carry-on if that's not inconvenient for you.
    Jun 2011
    297
    check it as fragile. I do with my fishing rods and they don't go on the conveyor belt thing.
    Mar 2009
    56
    if you really wanted to make sure it's taken care of, you can take it as carry-on luggage.
    http://coffeesnobs.com.au/grinders/3...der-plane.html
    Senior Member Mariner's Avatar
    Jan 2012
    218
    Take it on as carry on luggage. It well within size and weight restrictions - don't know about the box size, you may have to carry it without its box.
    Or, you could send it as a special item and pick it up from a separate baggage claim area (not the carousel). Means you also have to check it separately as well.
    Or, if it is in its original packaging you would probably be OK to just put it in as checked luggage.
    Best option if you're really worried is to de-box it and carry it on with you.
    Aug 2012
    Chapel Hill, QLD
    273
    Thanks all for the input. Will let you know if it survives
  1. Replies: 33
    Last Post: 29th January 2013, 10:46 PM
  2. Replies: 4
    Last Post: 7th May 2011, 06:00 AM
  3. Eureka Mignon Grinder or Brevilles Smart Grinder
    By Golden_Brew in forum Grinders
    Last Post: 6th May 2011, 09:59 PM
