Results 1 to 3 of 3
Thread: Re building an E61 two group machine
    Dec 2012
    Balgownie
    23
    Hi coffee people
    well my next project is starting to take shape, I'm planing to open a small coffee shop at the end of the year and to this end I have been looking at many different machines but as I have both the resources and the ability I have decide to re build and re skin a machine . I got very lucky and have been given a 2 group E61 leaver machine in very good nick, this will be the base for my new machine. My question is about moving the group heads away from the boiler . My new design will move the group heads about 150mm further away from the boilers thermal couple unit . Does any one know if this would have a adverse affect on the water temp reaching the group heads or are there ways to increase the temperature from the boiler . Any info would be much appreciated .
    Mar 2012
    1,276
    for certain it will make a difference, but how much is difficult to guess.
    Remember the group is heated by the thermosyphon effect from the boiler, so distance, and relative height will both play a part as well as tubing size, routing and any restrictor /regulator valve system that may or may not be installed.
    I suspect you will need to do a bit of testing !
    Dec 2012
    Balgownie
    23
    Quote Originally Posted by blend52 View Post
    Thanks blend52 I figured that would be the case . I'm looking at maby fitting a secondary boiler with PID for each group head but ill have to see how it behaves. As u say a bit of testing and experimenting
  1. A few questions for building a new roasting machine
    By brettryan in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 11th October 2012, 08:35 PM
  2. Building my own roaster
    By shsdarwin in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 28th September 2009, 08:06 AM
  3. building a breville 800
    By fauxhenrys in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 22nd January 2009, 02:27 PM
  4. Reduced H2O flow on one group of a 2 group machine
    By Paolo in forum Brewing Equipment (non-machine specific)
    Last Post: 14th December 2006, 07:53 PM
