Results 1 to 7 of 7
Thread: Decaf and grinding/grinder questions
    Apr 2005
    168
    Long time no post - but much time much coffee!!
    My partner has a health issue and has been advised to move to decaf.
    Can't share my ECM Best and I am going to buy a new grinder and am considering one of the Breville or Sunbeam models in the $200 + or - range/
    My question is - is there anything about decaf beans (that I will roast myself from beans purchased here) - that will pose grinding issues?
    In other words - do you HAVE to use a better quality grinder? She doesn't drink espresso, basically cappucino and flat whites.
    Will a Breville BCG800 or Sunbeam EM0480 (or whatever they are) be up to the job?
    Will move to a Rocky if I have to, but am guessing I won't need to.
    Thanks in advance!!
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    848
    I was using a BCG 800 smart grinder for my home roasted decaf and had no issues at all with it. I don't know what long term effects using it only for decaf would be (I think there's less oil in the beans), but it should be fine and I imagine replacement burrs aren't very expensive.
    I wish your partner well with their health issue.
    Steve.
    Apr 2005
    168
    Thanks Lovey.
    I have purchased a BCG800 and it seems like a nice unit. Reviews are certainly strong.
    Nov 2006
    Brisbane Northside
    356
    Hi el_espressio. My Missus has a health issue too and must drink decaff. We roast our own from CS .WOW decaff is always so enjoyable. Just perfect every time and everyday. We have a BCG 800 and we have no issues at all with the WOW beans. We change from decaff to caffeined twice a day using only the BCG 800. Enjoy.
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    I find with decaf that it seems to hold less moisture possibly due to the caffeine extraction process and I tend to get the best results by fining the grind (prob a bit finer than I would for regular coffee) and then down dosing a little bit, for a tighter extraction...
    May 2009
    Bendigo
    1,029
    Good thread and timely - my wife has a caffeine sensitivity & I'm under instruction to get her some decaf as she loves the smell of coffee and even the taste - just bounces off the walls with it and if mixed with alcohol, becomes a sobbing mess at the bar. [img]http://l.yimg.com/us.yimg.com/i/mesg/emoticons7/24.gif[/img]
    I have a spare grinder I can use so that's all good as well.
    Nov 2012
    Gold Coast
    63
    Haven't tried the decaf wow but have roasted various decaf beans for night time affogatii. Try some of the brazillian opus 1 beans ( non-sponsor) . They are a naturally low caffeine bean ( @1% ) . They accordingly behave more like a normal bean(roasting and grinding). Have used them straight, in a blend of mocca/java to make a lower caffeine drink and blended with other decaff.
  1. Sunbeam EM0480 Grinding Questions
    By bigwalker in forum Grinders
    Last Post: 5th May 2013, 02:29 PM
  2. Replies: 2
    Last Post: 21st March 2012, 01:17 PM
  3. Decaf grinder needed around $300
    By Vinitasse in forum Grinders
    Last Post: 27th June 2011, 08:19 AM
  4. Seperate grinder for Decaf
    By JD in forum General Coffee Related...
    Last Post: 19th June 2005, 03:41 PM
