Page 1 of 2 12 LastLast
Results 1 to 50 of 81
Like Tree87Likes
Thread: Soggy wet puck that's hard to knock out?
    Mar 2013
    Perth
    87
    Hey fellow CS,
    I have been using my new Diadema Jnr semi auto machine now for a few months, and I'm still getting the hang of it.
    I recently did a barista course and was able to pull a good shot on their commercial machine 2 x 30ml in 30 secs with a fairly firm dryish puck.
    On my machine at home the extraction is still 60ml in 30 secs but its not as good. I cant get that "drippy" start and the flow seems a little more watery. but the biggest difference is when I remove the PF the top of the puck is really wet (almost soggy) and is hard to knock out...
    any ideas what is causing a very wet puck?
    thanks.
    Senior Member summercrema's Avatar
    Mar 2008
    266
    Under dose or too coarse ?
    Mar 2013
    1,281
    Try a lighter tamp and adjust the grind to compensate.
    I find that if I tamp too hard (and therefore use a coarser grind) I get a soggy puck and slight doughtnutting (small dead spot in the centre of the basket).
    Mar 2004
    Internet
    17,515
    Tips for getting a base-line.
    1 Use the same dose the same each time.
    (overfill the basket and level flush with the top of the basket)
    2. Tamp consistent.
    (tamp as hard as you can, it will be more repeatable with less variation shot to shot)
    3. Adjust the grind as your ONLY variable
    (courser for a faster pour, finer for a slower pour).
    If you dose and tamp on a really fine grind and "choke" the pour so you only get a few drips you can then make adjustments to the grind to speed-up the pour until you are happy.
    I suspect you are introducing too many different variables to your routine, dose and tamp the same every time then adjust the grind to suit is the quickest and easiest way to get a good shot. You can later get more creative with under and over doses, lighter tamp etc when you understand your equipment and it's quirks better.
    Salgar, SpiceBean and Jiimiw like this.
    Mar 2013
    1,281
    Sounds like his pours are alright the only issue is a soggy puck?
    Mar 2004
    Internet
    17,515
    ...and the soggy puck could also be caused by too fine a grind (which is the inverse of what you said) or too coarse or too much water pressure or.... you get the idea!
    This is one of the gotchas with remote diagnosis without enough information or tactile "feel".
    I read the question as "I don't really understand what I'm doing yet" and ergo a baseline is needed first.
    BangalowBarista and lukeap69 like this.
    Mar 2013
    1,281
    True enough. FWIW I wasn't saying that a finer grind results in a drier puck; just that in my experience the combination of lighter tamp and correct grind had resulted in that.
    May 2009
    78
    How does it taste? (Serious question).
    How much coffee in grams are you putting in to the basket and how much does the resulting double or single espresso weigh?
    How long did it take to pour?
    Dragunov21 likes this.
    Mar 2013
    Perth
    87
    Quote Originally Posted by Andy View Post
    Thanks Andy. Yes I am pretty much a beginner so having a baseline is helpful.
    What other information should I be posting?
    Mar 2013
    Perth
    87
    Quote Originally Posted by Dragunov21 View Post
    Thanks Dragunov, I will try that and see what happens.
    Mar 2013
    Perth
    87
    Quote Originally Posted by EspressoSchool View Post
    hi, thanks for the reply.
    To answer your questions, the taste is ok but I know it could be and has been better.
    the dose method I use is fill the chamber to a mound then one knock down on the forks of the grinder, then I use a flat knife to scrape off the coffee grinds level. Then I tamp. I do not weigh.
    Mar 2013
    1,281
    Quote Originally Posted by 13bob View Post
    I do not weigh.
    Point scales are five bucks on eBay. If you're trying to diagnose shots as a home user then there's no reason not to weigh.
    Mar 2013
    Perth
    87
    Ok, what weight should I be aiming for?
    Mar 2013
    Perth
    87
    ...or too coarse or too much water pressure or....
    Andy, my gauge needle always sits just over 1 bar when fully warmed up.... Is that too high?
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Noosa, Qld
    823
    The golden mean as I understand it is 30mls from 30secs from a double baskets (I assume you're using a double / triple basket coz if not there's your problem right there!
    Try fining you grind to slow your extraction down
    Also are you purging your machine after each extraction?
    It's good practise to put your empty handle back in the group head after the extraction, place a cup underneath, and run some water through it whilst giggling your handle back and forth to add / break tension
    This is more of a regular maintenance thing, as opposed to shot quality, but if you're not doing it and back washing with a blind filter once per month, you'll be surprised how much gunk gets stuck in there - and over time this will definitely impact on shot quality ...
    Feb 2012
    Central Coast NSW
    702
    Zero out the scales with the filter basket. Then dose as you normally would and then weigh what you have in the basket. Note this weight as a starting point.
    You want the tamped bed of coffee just below the shower screen, have a search for the 5 cent piece test. Basically you want the gap between coffee and shower screen to be thickness of the 5 cent piece. Once you have your ideal dose weight, it will generally only change within a couple of grams depending on the type of coffee its age and the grind.
    Anyway the point is, once you have eliminated the dose weight variable, you can confidently adjust your grind finer or coarser to get the pour you want - CONSISTENTLY.
    Obviously its not viable in a commercial situation, but as Dragunov said, in the home why not?
    Jul 2007
    75
    At MICE, and at some shops down in Melbourne I have seen baristas weighing each dose before extraction. Coffeesnob/coffeegeek/home-barista techniques are infiltrating the commercial environment as people strive to create better (or just more consistent) espresso.
    I also believe in weighing shots, especially if you are only making 1-2 coffees a day. It's not too hard to incorporate this extra step into your routine and the information it conveys is very valuable, especially when you are trying to problem solve your coffee online.
    Steve82 likes this.
    Dec 2011
    PRL
    2,804
    Quote Originally Posted by askthecoffeeguy View Post
    Wouldn't that make it closer to a ristretto (assuming a double basket)?
    Mar 2013
    Perth
    87
    Quote Originally Posted by Steve82 View Post
    Thanks Steve, I will do this. What weight is ideal for a double basket of coffee?
    Apr 2008
    Victoria, Australia
    2,103
    I have an opinion about weighing espresso doses but.....each to their own...... :-)
    There is no 'ideal weight' and if you want to go down that path (of weighing doses) then you have to find the dose weight that gives you your ideal shot.
    You will have to weigh each dose until you find the one that works.
    Then you use that weight for repeatability. Your particular dose weight will vary, according to your filter size, grind, tamp pressure, coffee roast and age, machine pump pressure.
    I don't weigh my ( espresso ) doses but rely on consistent technique and a timed dose off the grinder.
    I only weigh for pour over, plunger and cupping.
    Re-read Andy's post #4 above, it contains everything you need to do.
    Andy and BangalowBarista like this.
    Feb 2012
    Central Coast NSW
    702
    So many variables, machine type, brand / type of double basket, the type of coffee and most importantly the type of extraction YOU are after, which you will only find with much experimentation, depends how far down the rabbit hole you want to go.....
    Somebody who has the same machine as you may be able to help give you a ballpark figure. It could be anywhere between 14 and 20g for a double basket.
    Try searching for threads on your machine and see what comes up.
    As I said, I would suggest following normal dosing routine, slightly overfill basket, level off and then weigh what you have and use that as a starting point for future reference.
    Dec 2004
    Earth!
    16,331
    For a standard espresso 30ml in 30 seconds is what you get using a single shot basket. For a double shot basket the standard is 60ml in 30 seconds.
    Java "Sipping away" phile
    Toys! I must have new toys!!!
  23. #23
    Mar 2013
    1,281
    The same one every time; that's the important bit.
    I dose mine at 17.5, generally, but different coffees, baskets and machines will work better/worse with different doses.
    I find it easiest to weigh the beans before they go in the hopper (ie the grinder only has 17.5g of coffee in it at any one time). It's not ideal, but it's less faffing around than weighing grinds (possibly less consistent if a bean gets stuck, but I've not had any trouble).
    I grind straight into a spare 300ml jug then shake it about to break up any clumps then dose - makes for a perfect distribution and fixed some big problems for me.
  24. #24
    May 2009
    78
    Quote Originally Posted by chokkidog View Post
    I agree with most things you say.
    Timed grinders do 90% of the work for you but are far from consistent. A great dosing technique will get you closer 100% of the time. Weighing doses and resulting espresso is useful for diagnostic work and dialing-in in a commercial setting especially if you already know what your esoresso brew formula percentage is. I personally always brew between 55-60%. At work the ridgeless baskets can take up to 25+ grams but my target dose is always 21.0 grams +/- 0.3 g with a resulting double espresso weighing around 35 grams in 27-32 seconds. This is very close to 30 mL per single.
  25. #25
    Apr 2008
    Victoria, Australia
    2,103
    Yeah, as I said, I rely on consistent technique first.
    You're quite right about timers being inconsistent. My Robur-e varies by as much as 1.8 gms but mostly
    by only 0.2-0.4 gms (over a spread of 20 or so doses, or 500gms of beans).
    Consistent dose and tamp technique will pretty much eliminate this variation.
    If I weigh what I brush off the basket when levelling, guess what...... the same variation appears, almost every time .
    The timed dose gets me in the zone, without having to weigh my doses and interfere with my zen.
    I'm definitely not bothered by a potential 1% or 2% variation in doses.
    I'm just not that anal ;-)
    Cheers.
  26. #26
    Mar 2013
    Perth
    87
    .....I grind straight into a spare 300ml jug then shake it about to break up any clumps then dose - makes for a perfect distribution and fixed some big problems for me.
    I have a doserless grinder that spits out pretty clumpy grinds, so this may be a really good way of getting a consistent dose. Thanks!
  27. #27
    Junior Member Salgar's Avatar
    Mar 2013
    Kiama Downs, NSW
    24
    My puck is usually firm but wet on top so I read this thread - Andy's baseline tips have made a huge difference. I've stopped weighing and put away the bathroom scales for tamping, stopped toothpick distributing and I get that 60 ml double in 25-30 seconds more easily, just ground a step courser. Probably a temperment thing. Once I understand the process more I might go back to weighing for fine tuning but it's working better for me right now.
    Andy likes this.
  28. #28
    Mar 2004
    Internet
    17,515
    Quote Originally Posted by Salgar View Post
    My puck is usually firm but wet on top so I read this thread - Andy's baseline tips have made a huge difference. I've stopped weighing and put away the bathroom scales for tamping, stopped toothpick distributing and I get that 60 ml double in 25-30 seconds more easily, just ground a step courser. Probably a temperament thing. Once I understand the process more I might go back to weighing for fine tuning but it's working better for me right now.
    That's excellent news.
    I was really hoping that someone reading this thread would go back to basics and start making great coffee without the need for dose weights and counting beans. While I understand that being accurate to a fault might result in closer to scientific consistency it's important to understand that it can also lead to complete frustration... and great coffee CAN be had with a fairly basic routine.
    With a basic routine you can jump on any espresso machine, make a grind adjustment to suit the output and be producing pretty damn fine coffee within a couple of shots.
    Please then adjust to suit your time and taste.
  29. #29
    May 2009
    78
    Good news indeed. FWIW when I make coffee I get soggy pucks all the time - do I care? Not really, because the coffee tastes great.
    Andy likes this.
  30. #30
    Mar 2013
    Perth
    87
    Thanks for all the great responses.
    I started weighing my doses to get an idea of where I was at, and then I went back to basics as per Andys suggestions and now I have only a mildly wet puck and a consistent 60mls in 30 secs after adjusting the grind appropriately and I am happy with the taste so far.
    Thanks again for all the advice.
  31. #31
    Oct 2013
    19
    Quote Originally Posted by Javaphile View Post
    What I don't understand is if for a double shot basket (more grounds = higher resistance), how can 60ml/30secs (faster extraction) be achieved unless we grind the beans coarser? Or put it another way, variables that go into a shot (as I understand it) are grind_size, grind_amount, tamp_pressure, basket_size; which gets you the extraction rate. So to get a faster extraction rate and the basket size is increased, shouldn't that mean other variables needs to also be adjusted?
    Thanks.
  32. #32
    Dec 2011
    PRL
    2,804
    Quote Originally Posted by Brenchen View Post
    Thanks.
    The double basket is not simply a single basket scaled up by 100%. The shape of the basket (the single basket 'tapers' in such that the base of the basket is of lesser diameter than the open end, the number of holes, the ratio of the area of those holes to the basic dimensions of the basket are all different etc.
  33. #33
    Oct 2013
    19
    Quote Originally Posted by Barry O'Speedwagon View Post
    So am I right to expect that if I can get the double basket to hit 60ml in 30secs, using the same grind size, technique etc. (obviously the amount of grounds will differ), I can generally get 30ml using the single basket?
    Also I was reading through my machine (EM7000)'s manual (please let me know if this is deviating and hijacking this thread), it said not to extract more than 30mls? Does this sound like it's the bottomline or that only applies to a single basket condition (which I can't seemed to see if mentioned)?
  34. #34
    Dec 2011
    PRL
    2,804
    Yep, basically, but you'll have less margin for error with the single basket. Small variations in technique will have a greater effect effect on the outcome.
    That sounds like a condition referring to the assumed use of a single basket.
    This doesn't mean that you *have* to extract a full 60mls when using the double (or the full 30mls)....Many people prefer a slightly shorter pour for at least some beans (e.g 25mls/50 mls or so).
    An alternate equivalent metric is that a 'normal' espresso produces approx 2 x the mass of brewed coffee to ground coffee (e.g. 30g of brewed coffee from 15g of ground coffee, 30g of brewed coffee represents approximately 60mls of brewed coffee *including crema*).
  35. #35
    Aug 2013
    Rockingham W.A.
    1,505
    G'day Brenchen
    As BOS said so well - holes sizes etc vary so "all things being equal" a double will extract at twice the speed, a triple at three times the speed etc. Reality check - it usually will get you close enough to dial it in unless you are using VST / LM baskets, and even then some CSr's claim it it not 100% accurate. As usual, Javaphile is 100% correct - a single is 30ml in 30 seconds, a triple is 90ml in 30 seconds (all figures counting preinfusion, which is crazy in itself). Unfortunately, among a large number of other confounding factors, grind size affects the surface area to volume ratio which affects the extraction speed. That makes the "30 seconds timing" rather a rough approximation. If the coffee is good, you must be getting closer to the setup your gear prefers.
    As 6910 & 7000 owner, the SB single is close to my VST single - which is a 7g shot IF dosed to the rated capacity (most CSr's don't). The VST double is 15g, the SB double is nominally 16g. I suspect it is 16.5+g really, it is almost exactly halfway between a VST 15g and a VST 18g in size. That means it is more than twice the size of a single in the first place, and it should be extracting a little more than 60ml in the "30 seconds"...
    The other issue - wet puck - every late 6910 (post 2010) and 7000 I have encountered places a small amount of water at low pressure in the basket after the shot is pulled. AFAIAC, this help to prevent the grouphead clogging up with grounds, other CSrs dispute that. Regardless, your 7000 will always have a layer of water on the top of the puck. FWIW, I reckon the only use in examining the 7000's pucks is to tell whether you are getting channelling.
    Hope this helps
    TampIt
    Peej and Brenchen like this.
  36. #36
    17,570
    Quote Originally Posted by TampIt View Post
    It's a Notional Capacity mate, not a rated capacity...
    Dec 2006
    Warragul, Vic
    471
    Agreed Dimal. I put nearly 15gms in a VST 7gm single and dial that in to deliver a great ristretto. It passes the coin test believe it or not and is my favourite drink. I think the VST manufacturers would be horrified!!! There are no rules with coffee making, only guidelines.
    Dimal likes this.
  38. #38
    Aug 2013
    Rockingham W.A.
    1,505
    G'day Mal
    VST rate their baskets at +/-1.0 g. Notional capacity is a very different concept. Given the need to use some sort of reference as a starting point to explain recommended shot timings without quoting a mass of links, I reckon it is fair enough.
    VST themselves state in one of their FAQs "Use the recommended dose of coffee for a given basket (i.e. 20g +/- 1g in the 20g basket). If you err, it is best to do so on the low side (down to 19g). Do not use more than the recommended (21g) dose, doing so will force a coarser grind, which reduces the extraction yield as much as 1 - 2%, producing sour taste defects". In my experience, every gram after that drops the extraction ratio even more.
    As a side note, the rest of the 5 pages probably have more intelligent comments on preparing espresso than anything else I have seen except my Illy "Espresso Coffee" which takes over 350 pages of fairly heavy going to provide a lot more testing data and reaches most of the same conclusions (clearly the VSTs higher flow rate & the resulting issues are not in the Illy book as it was written before VSTs were developed).
    Quote Originally Posted by barri View Post
    Barri, there may be no rules, however after VST and LM pooled a few million dollars together to develop their baskets, they may know what they are talking about regarding their use...
    IMO, the "5 cent test" is probably responsible for destroying more good beans in a VST than any other factor. By traditional standards, a VST requires:-
    1) a massively finer grind (about 30% "below standard espresso"). Most traditional grinders struggle to achieve that without generating excess fines - which leads to extreme bitterness.
    2) a severe underdose (about 4mm of space from the top of the basket is a good starting point).
    3) Preinfusion can make a huge difference to a VST shot compared to trad setups. Some roasts like a preinfusion time of up to 40 seconds (makes the "30 seconds including preinfusion concept" a complete farce). My personal refractometer readings showed clear differences directly related to preinfusion, so it was affecting both the quality AND quantity of flavour in the cup.
    Scales are a really good idea to dial them in. Just weigh some grounds consistently at some figure near their rated dose and then adjust the grind to get the shot timing.
    If your grinder is not up to it, you will know instantly ("mouthful of quinine" effect). Try cleaning and recalibrating the grinder and try again. If no joy, try to get hold of a really good "finer than espresso grinder" and you may be startled at the result. I use Mahlkonig Vario gen2's, however an HG One or even my old (secondhand in the late '70's) Turkish hand grinder works as well (at its second coarsest setting...).
    I did a fair bit of refraction testing a while back - 7g dialled in @ say 21% to 23% extraction (as measured) would be a much stronger, sweeter & balanced cup than your 15g @ 12% extraction* cut short to stop it running bitter...
    12% extraction* - if you are lucky, I actually measured between 8% and 10% consistently in a similar dosage setup.
    Anyway, something worth playing with if you feel the urge.
    TampIt
  39. #39
    17,570
    Tampit....
    All I can really think of to say to you mate, is Bullsh!t...
    barri, MrJack, TC and 2 others like this.
  40. #40
    Dec 2006
    Warragul, Vic
    471
    I always use the 5c test or equivalent. Many that dose by volume use it as a reference and dial in from there. I really don't give a rats arse how much money's been used to develop these baskets. I have found a way to make a great ristrettos for my palate and my friends and relatives agree. Many say that I make the best coffee in my home town. Not once did you mention that I may like the coffees I make. Your refraction testing is irrelevant to me.
  41. #41
    14,665
    So if LM are all about LM to the exclusion of all others and VST are all about VST to the exclusion of all others, all other shots, machines and baskets must surely then be rubbish.
    It's about maximising bucks and it's sad to see science and spiel attempt to exclude the palate. You can extract 1000% and still have rubbish in the cup and there is plenty of it out there including that produced by many disciples of the two brands.
    Way too much attempted brainwashing- too frequently from the paid marketers and the arrogant and egotistical.
    Last edited by TC; 13th February 2015 at 05:03 PM. Reason: added more lest I get brainwashed as well
    barri, Dimal, Vinitasse and 1 others like this.
  42. #42
    May 2014
    54
    I often change my beans but I never Change my Baskets !! - If You know what I Mean.
    [QUOTE=Talk_Coffee;551526]So if LM are all about LM to the exclusion of all others and VST are all about VST !!
    Whilst I understand the intent of this post I can't necessarily agree.
    I am often trying new beans, roasts and blends at home.
    To me that's the major benefit of having a good home setup - different flavours / cups when I want.
    And just like my brand of oil - I have found once I've found a great setup, then stick to it.
    Less variables makes it easier to get a repeatable quality shot in the cup - and that suits my diet.
    That's why when I found an excellent dble filter - The HQ 14g ( exceptional production quality IMHumbleO) that I dose to to suit my machine, And a Synesso Single - both be can dosed at or near the true and traditional Italian Espresso Recipe.
    They are both very stable and therefore repeatable good quality shots are easy to quickly dial in.
    I intentionally moved away from the Australian scene of updosing (14+ g for a single shot, 20+ g for a dble shot)
    baskets as I am concerned about the overall amount of Acid intake in my diet from my daily
    2-3 cups (Coffee can be highly ?? Acidic).
    And I am yet to be fully convinced that the Australian coffee scene of dble / triple updosing to overcome other unnecessary shortcomings in the espresso shot / setup is of a healthy longterm position for my healthy diet.
    I would however be very tempted to try one of those HQ single baskets - if as I suspect there as good as the 14g
    Basket it should be a cracker.
  43. #43
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,355
    Tampit....
    Very succinct Mal, they reckon it baffles brains.
    It never ceases to surprise me how after wading through a 600 word ramble you realise your being spun a line.
    Dimal and topshot like this.
  44. #44
    Senior Member topshot's Avatar
    Jul 2007
    Currans Hill, NSW
    369
    [QUOTE=Dimal] Tampit....
    It never ceases to surprise me how after reading through a 600 word ramble you realise your being spun a line.
    I'm with you two.
    Too many people read too much instead of practicing making coffee.
    A few try to "buy better" extractions, eg, VST baskets, scales, etc.
    Forget all the BS about the science of making great coffee, just practice as much as you can, yes it will cost you in beans, but it will be cheaper in the end.
    TampIt wrote "(clearly the VSTs higher flow rate & the resulting issues are not in the Illy book as it was written before VSTs were developed)." Really you think VST baskets have a higher flow rate than other baskets?
    Flow rate is determined by grind, dose and tamp pressure, not the holes in the basket!
    As for the OP, just take in what Andy said and practice as much as you can, it will get there, it just might take a little time.
    Dimal, TC and Yelta like this.
  45. #45
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Hopefully still on topic:
    Yesterday I had my Breville twin spout PF with Breville factory basket and along side it Brevilles naked PF and a 20gm VST.
    I was making affogatos for the family and wanted single shots for my young daughters and a double for my adult Son.
    Same grind and same prep tecnique albeit 18gm vs 21gm (eyeball not weighed) and behold both poured almost identically and wonderful results.
    No grinder adjustment at all. I agree with Topshot.
    Dimal likes this.
  46. #46
    Dec 2011
    PRL
    2,804
    Quote Originally Posted by topshot View Post
    While I'm also of the 'keep it simple' camp, the fact that grind, dose and tamp pressure affect the flow rate does not mean that the number/pattern/size of holes in the basket doesn't affect the flow rate. I have used VSTs and similarly sized EP / Synesso / whatever baskets, and without a skerick of a doubt they have a faster rate of flow all other things held equal. Doesn't make em better or worse. They'll suit some personalities and not others. I don't use mine very often but every now and then give them a go with a beaan that I'm otherwise not happy with. All in good fun.
    Dimal, kwantfm, MrJack and 2 others like this.
  47. #47
    May 2010
    Sydney North Shore
    1,327
    Just compare the flow of water through the portafilter with and without coffee in it. I think that the size of the holes in the filters are largely designed allow coffee flow while stopping coffee grounds going through into your cup. With single walled filters it is the amount of dose and fineness of grind and tamp that mainly determines the flow rate, not the hole size.
    Maybe the more expensive gadgets you buy for making your coffee the better you think your coffee tastes to justify the expence to yourself. Taste is such a subjective thing.
    Barry
  48. #48
    Jul 2007
    Currans Hill, NSW
    369
    While I'm also of the 'keep it simple' camp, the fact that grind, dose and tamp pressure affect the flow rate does not mean that the number/pattern/size of holes in the basket doesn't affect the flow rate. I have used VSTs and similarly sized EP / Synesso / whatever baskets, and without a skerick of a doubt they have a faster rate of flow all other things held equal. Doesn't make em better or worse. They'll suit some personalities and not others. I don't use mine very often but every now and then give them a go with a bean that I'm otherwise not happy with. All in good fun.
    So true, it is fun trying the different baskets available.
    I have used the baskets which came with my Izzo, VST, other brands. My goto basket for the last 18 months or so is the Precision filter basket, this is not to say I won't change the baskets I use.
    Everyone will eventually get a basket (brand) which suits their technique.
    Everyone are all trying to get that "Godshot", which is great if all you drink is a straight shot.
    Most of the coffees I have at home are with milk, so a "Godshot" is not required, but a very good shot is still required.
    We all have to remember we are playing with an organic product, so there will never be two pieces of ground coffee grains the same size or shape.
    Therefore, there will never be a puck being loaded into a machine that will be exactly the same as another (all our tamps, regardless of how good you are will vary by 100 or more grams), the amount of coffee in the filter will vary a little as well.
    We all will however should be getting the most consistent dose and tamp as our technique will allow us.
    I remember when I first started out years ago, I thought I would never get any consistent coffee. Now after how many thousand coffees later, I think my technique is fairly good (all my friends and family say I make the best coffee they have ever had). (I would bet London to a brick, just about everyone on this forum get the same complements from their family and friends).
    The main thing for all of us is to have fun with making your coffee, as you all know, the coffee you make at home is better than most cafés and equal to the best!
    So for 13bob, just keep practicing and as Andy said in post #4 dose the same every time and only change the grind, of that does not work, start again with a slightly larger of smaller dose and only change the grind, you will find what works for you and your particular machine.
    Remember Roger Federer did not win Wimbledon numerous times and become one of the worlds greatest tennis players by hitting only 10 tennis balls!
  49. #49
    17,570
    Very well stated "topshot"...
    Aug 2013
    Rockingham W.A.
    1,505
    Tampit....
    Hi Mal
    ... and which part(s) do you take issue with? AFAICSee, you have just started yet another flame war with not a single fact to back your comment. Whilst I fully expect that from a couple of web bullies (posts below yours - without a single data item or testable idea seems to be their SOP), I admit your post is both a surprise & a disappointment.
    Anyway - please i/d the facts you disagree with and I will provide the info (when I get time to scratch myself).
    TampIt
  1. Build your own knock box (knock tube)
    By Groggles in forum Brewing Equipment (non-machine specific)
    Last Post: 9th December 2014, 11:26 AM
  2. Hard Beans
    By smokeydeck in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 22nd February 2009, 08:21 PM
  3. Its a hard life...
    By gregpullman in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 14th October 2008, 09:12 PM
