Results 1 to 9 of 9
Thread: Grind settings for plunger???
    Sep 2006
    13
    Hi guys,
    Im trying to help a friend grind beans for plunger use.
    As I have a cimbali cadet grinder, and have never ground for plunger before, how much coarser will I need to go? My setting is usually around the 6-8 mark for espresso.
    I.e. should i double or triple the courseness?
    Can someone with a cimbali cadet or similar please let me know?
    Thanks!
    Zach
    14,665
    Re: Grind settings for plunger???
    Hi Zach- go for something which looks like its all grit rather than powder. Numerical settings dont mean too much as individual grinders will differ dramatically. Plungers are not that sensitive to grind. If its too hard to plunge, go a little coarser next time....
    Good luck ;)
    2mcm
    Sep 2006
    13
    Thanks 2mcm.
    Looks like theres alot of knob turning to do!
    Zach
    Feb 2006
    2,334
    Yes...one of the beautiful things about the Cadet is the worm driven stepless adjustment....infinite!....But very unfriendly to non-espresso based drinks when you need to change settings.
    Dec 2006
    83
    I dont grind for plunger but if I did I think I would try and do something clever with a rechargable screwdriver to whizz up the other end of the scale quickly - not quite sure how I would hook it up but the idea has potential.
    Mar 2005
    2,165
    Not exactly the same idea, but last time I dropped back to Adelaide to visit my parents I discovered how my dad uses his hand grinder for his grounds in jug, pour through sieve setup after finding the hand crank too slow... :o The results were actually quite drinkable, though particle size was all over the place as youd expect from a cheap burr grinder. No shortage of intuition from those who have tinkered for years!
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    hmmm...I think it would be so much fun trying to explain some of our setups if there were a police raid...
    "oh no officer, those 30 kilos of beans are for my own private use, really!"
    10,496
    My kids asked where I was going tonight and when I told them I was going to Newtown to buy some plants...I got very strange looks.
    Jan 2007
    Perth, Western Australia, Australia
    791
    Quote Originally Posted by Greg Pullman link=1173336141/0#5 date=1173863754
    I too have this grind / cannister combo, might have to take this into work and use this setup with the drill. I like it.
    I have the EM0480 grinder for home so can easily dial in and out of espresso and plunger grinds but due to 5 kg ofroasted beans landing on my door step last week I decided to take some coffee into work but with no means of grinding the beans.
    The manual grinder and drill combo might do the trick.
    Cheers Greg, See you tomorrow at Epic for the bean pickup.
  1. EM 0480 grind settings?
    By Zaneus in forum Grinders
    Last Post: 18th December 2010, 10:14 PM
  2. Grind settings for different beans?
    By redzone121 in forum Grinders
    Last Post: 16th December 2009, 07:42 PM
  3. Different grind settings
    By mmmcoffee in forum Grinders
    Last Post: 14th July 2009, 02:32 PM
  4. EM0480 Espresso to plunger settings
    By PhilMac in forum Grinders
    Last Post: 15th October 2008, 01:02 PM
  5. [m]: Grind settings for plunger???
    By Dimal in forum Grinders
    Last Post: 15th March 2007, 10:19 AM
