Results 1 to 17 of 17
Like Tree9Likes
  • 5 Post By Yelta
  • 2 Post By Yelta
  • 2 Post By Yelta
Thread: Yemen Matari Al - Hamdani
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,866
    After a disparaging comment I made re my experience with green beans from the Yemen, Chris from Talk Coffee took me to task and sent me a sample of Yemen Matari Al - Hamdani, along with strict instructions not to open them until 14 days after roast, what I did notice while they were sitting on my desk over the past week is they continued to off gas, the bag was barely inflated when I received it however by day 10 it was like a balloon, I expelled the gas via the valve and by this morning it had blown up again, though not as much as previously.
    They were roasted on 23/9/14 (roast date printed, not hand written on the Vacpak) so today was the day, on opening, the beans looked pretty much as I expected, small and quite rustic looking, far from impressive, similar in fact to a couple of other Yemeni beans I have roasted, they looked to have been roasted to about CS 9 and taken to approx SC, just a few tiny spots of surface oil showing on some of the beans.
    Gave the grinder a good brush out, weighed out 18 grams of Chris's sample, I had the grinder set up for some beans I had roasted a few days ago to pull a Lungo of approx 100ml (my morning drink) this shot proved to be way too tight, only produced about 40ml in 30 seconds, the stream its self when it started was very viscous, thick, syrupy, quite dark with lots of crema, the taste was very very intense, more so than anything I have previously tasted.
    I adjusted the Mazzer Mini by a notch and a half, ground another 18 grams and attempted my second Lungo, this time, (in the words of Borat) great success, got the required 100ml which started to flow, or I should say gloop from the spout of the Bezzera in approx 7 seconds, and I do mean gloop a bit like a stream of pulsing molasses, with an enormous amount of red brown crema.
    Now the taste test, this is where my lack of coffee education fails me, suffice to say at the moment, exceptional, big, bold and chocolatey, I'm going to pull a few of more shots over the next few days and try to describe the taste sensation in more detail.
    A big thank you to Chris for his generous sample.
    This post/thread, like Neighbors, is to be continued.
    Jun 2009
    Moonta SA.
    6,866
    Well, this little review may just never reach a conclusion, prepared for my late afternoon brew a while ago and my much loved Bezzera Galatea let me down, not sure but suspect the pump may have failed.
    Unless I can diagnose and fix the problem myself I suspect I may be without coffee for a while.
    14,665
    Sorry to hear that Yelta.
    Are you getting flow to the group? Pump sound like it's stalling? Another possibility on SA water might be a grotty solenoid- probably coupled with boiler overfill if the pump sounds to be operating.
    I'm glad to hear that you may have at least approached some of what great Yemen can offer.
    Ho hum....
    Jun 2009
    Moonta SA.
    6,866
    Ho hum....
    Evening Chris,
    No flow to the group, pump running flat out, not stalling and rattling like a spoon in a jam tin.
    Steam is good as is hot water.
    It all happened after I locked the PF into the GH and lifted the lever, the pump went hyper and not a drop of water made it through the puck.
    I sent you a PM a while ago have you picked it up yet?
    14,665
    G'day Yelta- Yes- got it. Thanks...
    Any evidence of a boiler overfill? If so, I reckon pull the solenoid down and see how you go.
    Jun 2009
    Moonta SA.
    6,866
    Thanks Chris, no evidence of boiler overfill.
    Had enough for today, will look into it in the am.
    Dec 2011
    PRL
    2,615
    Best of luck with tomorrow's discoveries Yelta.
    Jun 2009
    Moonta SA.
    6,866
    Thanks Barry.
    Aug 2008
    Millthorpe NSW
    2,038
    Bummer. Sorry to hear that. Hope it's a simple fix.
    Better pull out the Aeropress before that Yemen goes stale!
    Jun 2009
    Moonta SA.
    6,866
    Switched the machine on again this morning in the hope the problem had resolved its self over night, no such luck, bugger.
    Unplugged it and moved it to a table where I laid it on its back (makes accessing the cover screws easy) removed the cover, everything looked fine and I must say for a five year old machine very clean and tidy, stood it on its feet, replaced the water tank and couple litres of water, plugged it in and turned the power on, bingo, after heating up it pumped water through the GH exactly as it should.
    So, replaced the cover, tidied up, and for the time being I'm in business again.
    What did I do to fix it? guess I could make up some cock and bull story about cleaning out the wigwam just above the gooses bridle, sadly, the truth is I have no idea like all intermittent faults I'm sure it will recur.
    Perhaps simply moving it and laying it on its back dislodged a bit of crap in the system and got things moving again, had a bit of a chat with Chris this morning and he feels pretty much like I do, would prefer to see a component fail completely than this hide and seek rubbish, at least a failed part can be repaired/replaced with some confidence that the fault has been rectified.
    So that's where we are.
    After hijacking my own thread, normal programming will, hopefully continue.
    Dimal and saroadie like this.
    Dec 2011
    PRL
    2,615
    Sounds like those Yemeni beans mate
    More seriously....I've had the same thing happen when fixing a lawnmower that wouldnt start for it's first job of the spring.
    Senior Member noonar's Avatar
    Aug 2013
    MortalCoil
    451
    You have that majic touch Yelta or the machine thought it was going to get mouth to mouth when you laid it on it's back. :-)
    Jun 2009
    Moonta SA.
    6,866
    Could well be Barry.
    To get back on topic.
    Made myself another Lungo a while ago, once again very very nice, lovely syrupy mouthfeel, took my time drinking/tasting/savoring it, I think the best way I can describe it is akin to drinking a liqueur Muscat, chocolatey overtones with a little acidity, would have to say the nicest SO I have ever had.
    Just to qualify my version of a Lungo, have been estimating the extraction to be approx 100ml through 18 grams of ground coffee in 30 seconds, today I measured what I'm getting in the cup, bit of a surprise here, more like 70ml including crema, much tighter than a Lungo and a little longer than an espresso, regardless a drink I enjoy.
    Next up will pull a couple of espresso's, must say I'm thoroughly enjoying this experience.
    Dimal and TC like this.
    Jun 2009
    Moonta SA.
    6,866
    Quote Originally Posted by noonar View Post
    Was thinking of something a little more sensual as I typed the reply Noonar, however because I'm not that type of person decided not to go there.
    Jun 2011
    721
    If it had been a bicycle though!
    14,665
    So, did I change your mind?
    Jun 2009
    Moonta SA.
    6,866
    You certainly did Chris, my review pretty much says it all.
    Have done some research on availability and price, sadly its a case of champagne tastes with a beer pocket, at approx $30 kg green they are out of my price range, perhaps I will order a couple of kg and roast a small batch now and again as a treat.
