Results 1 to 13 of 13
Like Tree6Likes
  • 1 Post By richard_m_h
  • 1 Post By TC
  • 1 Post By Yelta
  • 2 Post By Yelta
  • 1 Post By blend52
Thread: Cost difference between short and long black.
    Mar 2014
    23
    I've never worked in a cafe but would like to appeal to anyone who has to shed some light on a niggling query. It's not a big deal but would like any insight anyone has.
    Recently I have realised that at some cafes (in Syd) are charging different amounts ($0.30 - 0.50 difference) for their short and long blacks. I've tried asking why this is but their responses have been underwhelming.
    For the record the order has always been a small takeaway LB or a have in SB.
    The only thing I could attribute it to is the extra cup and potentially the cup size difference=cost difference being passed onto the consumer but for the long black hasn't always come in the 2 cups so not 100% on it.
    I have started to prefer the LB as it isn't as potent and helps me find the flavours of the coffee but not super keen on the price difference when i could rock up with my cup and hot water in tow and ask for a SB.
    The best answer I've been given is that it's due to the extra water but i find this hard to believe.
    Col
    Senior Member speleomike's Avatar
    Nov 2005
    927
    In addition to the extra water you have to add the electrical power to heat it to 100 C in the boiler. Water does take quite a bit of power to boil it. Gone are the days of cheap electricity.
    Jun 2011
    297
    Isn't a long black based on a double and a short black is a single? Often 30c or so difference between a single and a double shot.
    Vinitasse likes this.
    Apr 2010
    558
    If the LB is priced above a SB but below a latte then that makes sense to me.
    Obviously the milk costs quite a bit, along with the time to steam, so the latte should cost more.
    And arguably there's more effort in producing a LB than a SB.
    My gripe with cafes is when they charge the same for a LB as a latte, that just doesn't make sense to me.
    Mar 2012
    1,275
    Since when was a long black a double shot ? ..or needed 2 cups ?
    ..maybe if you ask for a large one ?
    as for the cost of the extra water !...really ?
    in reality, a good short black is probably harder to make as extra attention is needed to ensure a quality result. The shot doesn't hide any mistakes, whilst a LB will at least dilute a problem !
    14,665
    Quote Originally Posted by blend52 View Post
    In Melbourne at least, since pretty much always!
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,866
    Since when was a long black a double shot ? !
    Perhaps this is the reason why the majority of cafe's around OZ serve such a crappy short black, a cappuccino cup 3/4 full of hot water with 30mls of espresso floating on top ------YUK.
    Mar 2012
    1,275
    Really ?... And is a short black also a double shot ?
    i only ever use a single for a LB , unless someone asks for a strong one.
    and no, a LB should not be in a cappachino cup,...let alone 2 cups !
    120 ml or so of water.
    if you are getting a double shot, then yes, you can expect to pay more.
    Jun 2009
    Moonta SA.
    6,866
    An espresso is a single shot, a doppio espresso a double and a long black is a drink peculiar to the Antipodes, ask for one in Italy and they will think you've gone stark raving mad.
    According to Wikipedia, and I agree "A long black is made by pouring a double-shot of espresso or ristretto over hot water.
    Long black - Wikipedia, the free encyclopedia
    chokkidog and Vinitasse like this.
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,090
    I often drink Long Blacks and for me the ideal is a single shot over no more than 100ml of water in a smaller cup.
    I prefer the single shot/smaller cup because when doing coffee with friends we often do three cups over a couple of hours and after three shots I'm bouncing off the ceiling.
    If they only have big cups - 200ml+ - then I certainly want two shots in it.
    Mar 2012
    1,275
    i guess it depends who you chose as the reference.
    Oxford english dictionary has..
    Definition of long black in English:
    noun
    Australian /NZ A type of coffee made by adding a shot of espresso to hot water:
    and some would say it should be a double ristretto !
    Either way, its the ratio of water to coffee that is key to success
    chokkidog likes this.
    Mar 2014
    23
    ah there seems to be some confusion about the two cups. What I meant was for a take away most places i have bought a LB from provide a second take cup in which the first one sits. This provides an insulative barrier and stops the scolding coffe from burning your hands before you burn your mouth.
    I hadn't thought about the extra shot...but fair call if that is the case. I always make doubles at home. So do they change baskets or just dump half a shot?
    I did see one place today (charges the same for milk based and long blacks) increase the price by .50 for each size increase...
    Thanks for the responses.
    Apr 2012
    497
    Quote Originally Posted by Col3 View Post
    No cafe in their right mind would swap baskets, they'll pour a double and either dump half of it (cup under one spout of two-spout PF) or they'll stick the next person's cup under the other spout.
