Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By ozscott
  • 1 Post By coffeechris
Thread: Grind setting for drip filter coffee machine?
    Mar 2013
    Perth
    87
    Hi folks,
    is the grind setting the same for drip filter machines as it is for espresso machines? Or do you need the grind to be much coarser like for a plunger?
    thanks,
    Senior Member coffeechris's Avatar
    Jul 2011
    726
    Hi bob,
    Inbetween plunger and espresso. There is also a variable in my opinion if you are using a paper filter or a metal filter. A paper filter you can go a finer grind which would be similar to if not a little finer than a stove top grind. A metal filter requires a slightly coarser grind. All this also comes down to your taste.
    Cheers chris.
    Mar 2013
    Perth
    87
    Ok. Thanks Chris.
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    930
    Concur - I have a metal filter and go coarser. Tip: after brewing a pot as you empty the pot check to see how much residual fines are left at the bottom. If there are a lot go coarser. Use this method to adjust grind setting.
    Mar 2013
    Perth
    87
    Quote Originally Posted by sprezzatura View Post
    Great, thanks for the tip!
    Jun 2006
    BRISBANE
    1,998
    Underrated and forgotten method of brewing. I love a good drip filter.
    sprezzatura likes this.
    Jul 2011
    726
    I have about 8 different types of brewers which i have collected over the time. It provides coffee for the guys at work. Its a step away from espresso sometimes. The only bad thing is that its easy to drink too much.
