Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By chokkidog
Thread: Pale crema ..... Why?
    Jun 2013
    Melbourne (Vic)
    25
    This may be a basic question, but why am I struggling with getting a nice dark rich crema? Dosing is all good, coffee is fresh, if I grind finer then I restrict the flow, what's the best way to adjust to get a nice dark crema. I want to practice my latte art and is difficult with pale crema. Coffee tastes nice no problem there, shot time of 30 seconds all good too? Do some beans produce a better darker crema than others?
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    930
    What brand and type of machine do you have?
    Dec 2013
    Hervey Bay, QLD
    930
    Sometimes low pump pressure and water temperature can be a factor.
    Jun 2013
    Melbourne (Vic)
    25
    I have a VBM Jnr only couple months old, and Dimattina coffee ... bought fresh from their outlet at reservoir (Colombian light)
    Apr 2008
    Victoria, Australia
    2,095
    Colombian 'light'?? .........Try a darker roast.
    Caffeinated kopigeek's Avatar
    Feb 2015
    156
    hi mate, is the flow watery and pale? is it pale from the get go or does it get pale (and watery? soon after).
    could be channeling if its a watery flow too early on...
    Jun 2013
    Melbourne (Vic)
    25
    It is pale from the get go, slightly darker for the first few seconds, flow looks watery, puck has a little water on it after the shot but not sloppy by any means ...... What are you thinking here?
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,247
    Should be almost black at the start. You'll have to use a process of elimination. The easiest variable to change is the beans so try some different types and try blends rather than origins. Even grabbing something from the supermarket could be worth it to save on the cost of trying a few varieties. Other than that the next two things are definitely brew temp and pressure, probably in that order. Pale crema is what you get from auto machines or little pretend manuals machines. And that would usually be due to low brew temp, or pressure, or both. Good luck.
