Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Joe91
Thread: Help: getting more flavour from my coffee
    Dec 2013
    ACT (unfortunately)
    15
    Good morning all,
    I've had my Breville Barista Express (BES870) for about 12 months now; this is my first espresso machine. I had a barista come over and help me pull good shots, and I'm happy with what I can make at home. However, like all of us I'm looking at the next step - I'm finding my coffee lacks subtleties and flavours. The beans I'm using are from the two cafes where I exclusively eat-in/take away my coffee - so I'm directly experiencing the difference from commercial equipment to my humble BES870. Essentially what I'm trying to achieve is pulling more flavours out of my coffee, at the moment my coffee tastes good - but it has a lot of strength and not much else.
    The built in grinder on my machine is set at its finest setting, and my shots tend to pour out quicker than Iíd like. I have tried dosing & tamping more which does effect the shot time, but still doesnít get me the flavour profile. Iím tempted towards a Rancilio Rocky thinking that a finer grind would help bring out more of the coffee.
    Am I on the right track with my thought process?
    To close, I completely understand Iíll never achieve the same quality with my $700 machine as what a $20k machine paired with a $5k grinder would Ė Iím just trying to close the gap a bit!
    Joe
    May 2008
    4,079
    If your shots are pouring too fast then they may not be in contact with the grounds long enough for flavours to be infused. You can buy spacers for a Breville grinder to help enable a finer grind but not sure for an in-built one like yours.
    It is likely a higher quality grinder will improve your coffee. There's also quite a gap between your grinder and a $5k grinder with many options between. A Rocky is a good 'intermediate' grinder; so are the Compak K3 models among others. Also consider sourcing different beans eg from Bean Bay.
    Dec 2013
    ACT (unfortunately)
    15
    Thanks flynnaus - I will look into spacers but like you said, not sure what can be done with mine given the grinder is built into the machine.
    I know the Rocky seems to get a good wrap around here so that was my first thoughts in terms of upgrade. I'd rather buy a second-hand unit as I'm not a heavy user, one or two shots per day and half a dozen (max) on weekends. I just want something that like I said, will close the gap a bit and get me some more flavour. I suppose I just need some guidance on whether a 'finer grinder' is the solution.
    Would me filming me doing a shot and sharing it on here assist? Won't show the flavour obviously, but would it help?
    Senior Member Lukemc's Avatar
    Oct 2012
    MILLBROOK VIC
    696
    Where are you located Joe? I've got a HG One if your anywhere near point cook you can have a crack with. See if that changes the flavours in your coffee. If it does maybe a lido2 from Chris at talk coffee would be a good option for you
    Dec 2013
    ACT (unfortunately)
    15
    I'm in Canberra, but appreciate the offer Luke!
    Don't know anything about hand/manual grinders - would have to do a bit of homework on this.
    Dec 2011
    PRL
    2,612
    Are you drinking espressos? Or milk based coffees? Which cafe are you referring to? There's no problem mentioning their name.
    If you're only making a couple of cups a day a quality hand grinder might be the go.
    Dec 2013
    ACT (unfortunately)
    15
    I mainly have milk based coffee but recently been having espressos and long blacks.
    I'm getting my coffee from Ona and Kingston cafe in Belco.
    Not sure how I feel about a hand grinder. I think I'd prefer a normal one, but I guess my preference isn't founded upon anything.
    Feb 2010
    226
    Just ask Ona to sell you the smallest amount they are willing, pre ground.
    Take it straight home and play with the dose and tamp and see if that gets you near where you'd like to be flavour-wise.
    Then you can decide how much you're prepared to spend on a better grinder.
    Because if the grind pleases your palate, then purchase the best you can afford!
    May 2008
    4,079
    If you have the means to buy a new grinder, take your Breville to a shop that sells grinders and see if you can try out one or more shots using different grinders. Consider going for the best grinder you can afford so that when you eventually upgrade your machine, you don't have to upgrade your grinder as well.
    Dec 2013
    ACT (unfortunately)
    15
    That's a really good idea Kevo, hadn't thought of that! I take it the 20 minute odd drive won't be long enough for the ground coffee to start losing its freshness?
    Cheers flynnaus, not sure what is around here but that'd be handy if the option is available.
    One thing I've really noticed watching baristas is that the coffee in the basket looks much more spongy when they tamp and looks quite effortless. I had one barista tell me once that because they grind so fine they only do a quick, small tamp - I just can't help but feel that could be one of my limits with the current a Breville setup.
    Aug 2008
    Millthorpe NSW
    2,038
    Quote Originally Posted by Joe91 View Post
    Hi Joe
    That certainly is the case. Most commercial machines can handle a much finer grind. I've ground beans for a few friends who have Breville type machines, and have had to go a fair bit coarser than my own espresso setting for them so it doesn't choke up. That's not to say that you can't get good results from your machine with fresh beans and a more consistent grinder - but it will need adjusting to suit the capabilities of the machine.
    You do have some good places down in Canberra - ex-sponsor Cosmorex (now BeanRoasters?) in Fyshwick, just around the corner from ONA, has a good range of grinders and machines (I bought my setup from them originally and dropped in a few weeks ago, and they had a great range). Something like a Macap M2 would be a great investment - and if you then ever need to change machines, you wouldn't really need to step up from there
    Cheers Matt
    Dec 2013
    ACT (unfortunately)
    15
    Thanks Matt - I forgot completely about Cosmorex. Will give them a visit on the weekend.
    One thing I'm not sure of though is why my machine may choke with a finer grind?
    Dec 2011
    PRL
    2,612
    The magnitude and consistency of pressure at the group head, among other things.
    Dec 2013
    ACT (unfortunately)
    15
    Thanks Barry - forgive my ignorance.
    Dec 2011
    PRL
    2,612
    No worries. Cosmorex is definitely worth a look on the weekend. They sell the Macap range now, I picked up an M2M from them a year ago or so which is a great little grinder (on decaf duties now, as I luckily picked up a 2nd hand Macap M4D from a forum member).
    Hand grinders do offer great bang for buck for the right person.
    Dec 2013
    ACT (unfortunately)
    15
    Just to give an update: I got Ona to grind some beans for me and got them home, only had enough for a few shots but there was a huge difference straight away. The shots eased out instead of "pouring", and there was much more depth in the espresso.
    So now tossing up between a Macap M2 or a Rocky - I can't find anything on the net which separates the two.
    Nov 2013
    West Footscray, Melbourne
    207
    Hi Joe,
    I haven't used a Macap M2, but I do have a Rocky at work. When I compare the Rocky to my Compak K3, which i think is another comparable grinder, I find the Rocky to be a much slower grinder. This may not seem like much of an issue, but it certainly becomes noticeable if you do more than 3-4 coffees in a row. I also find sometimes that the step settings for the rocky are to big to get the right grind for a particular bean, and would be perfect if I could have gone halfway between two steps. Having said that though, the Rocky is a solid grinder that has done well in an office setting for the last 4 years without skipping a beat.
    Good luck with making your choice!
    Cheers, Dave
    14,665
    Hi Joe,
    Whilst the Rocky is a good grinder, the Macap M2 takes it to the next level with better burr location, better speed, smaller steps in adjustment and way better finish.
    It really is a no brainer in my opinion. Like Barry, I too choose an M2M as my second grinder (and I can any grinder I want )
    CosmoreX is close to you, but we're happy to assist if you'd like one delivered: Macap M2M | Talk Coffee
    Dec 2013
    ACT (unfortunately)
    15
    Thanks Dave & Chris for the input. I'm decided on an M2 now, so may be in touch soon Chris.
    Have a good weekend all.
    TC likes this.
    Jun 2015
    9
    Compak k3 works for me
