Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Javaphile
Thread: How much to extract
    Mar 2011
    60
    How much to extract
    Most sites recommend extracting around 30 ml from a 7 gm shot.
    I bought some New Guinea coffee and the instructions suggest for best results extract 20 ml per gram of beans.
    Well for a 14 gm double shot that is more than a small cup, can't see how that is going to work.
    Does anyone pull this much extract from their grind and if so what is it like?
    You would have to take your coffee black.
    Jun 2011
    721
    20 mL per gram of beans is way off the spectrum. I suggest you Google the concept of brew ratio for espresso... that should provide some good benchmarks. I'm at the other end of the spectrum and regularly extract 15-20 g of espresso from 22 g of beans.
    For pour over, however, I tend to use 16 g of water per 1 g of coffee, although I'm not exactly sure how much brewed coffee that actually produces.
    Dec 2011
    PRL
    2,615
    Quote Originally Posted by nutfarmer View Post
    Are you sure that the 'per 1 gram' isn't actually 'per 7 gm'? ( 1 an 7 can look similar). Or, it may be a misprint, where the number of grams has failed to be visible.
    7g to 20mls is plausible (and possibly quite nice).
    Dec 2004
    Earth!
    15,582
    Maybe for some kind of a drip/filter/pour over brew, but no way for espresso.
    Java "Ristretto anyone?" phile
    MrFreddofrog likes this.
    Toys! I must have new toys!!!
    Aug 2015
    Perth WA
    461
    I'd give up on any volumetric based decision making if I were you, that was my biggest hinderance to getting a good shot.
    Stop the shot when it starts to turn a lighter yellow (blonde), regardless of volume. Should take 25-30sec. If not adjust grind and/or tamping till it does.
    Apr 2013
    11
    Quote Originally Posted by MrFreddofrog View Post
    Totally agree with MFF above -watch for the colour change
    For novices like myself, throw away the shot timer for now, and watch the extraction… and count in your head. Best done with a naked PF so you can see the consistency/draw through of water, but not essential… and adjust grind/tamp from there!
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    930
    It's vary varied: I'm pretty happy with about 17-18g in a 15g basket and (out of one machine) getting 25ml in 33-38 seconds (8 seconds until espresso oozes out of the portafiltre).
    Mar 2011
    60
    Yes
    I just rechecked the tag and obviously mis-read it - don't know what I was thinking about.
    Senior Member tobeanornottobean's Avatar
    Oct 2015
    101
    So what was it supposed to be?
    Dec 2015
    4
    20 ml per gram
    kbc
    kbc is offline
    Apr 2008
    2,960
    Spot on. Extract by colour.
    kbc
    kbc is offline
    Apr 2008
    2,960
    For me it's 22g to approx 30ml in 25 seconds. .....roughly. That's a thick, gloopy ristretto
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    I work on 30 to 40ml from 20g over 30sec - I'm sure it changes from machine to machine but this ratio has never failed me !
