Results 1 to 8 of 8
Like Tree9Likes
  • 1 Post By Alexpid
  • 2 Post By Melbroaster
  • 2 Post By LeroyC
  • 1 Post By LeroyC
  • 2 Post By Alexpid
Thread: What kettle for aeropress?
    Senior Member Alexpid's Avatar
    Mar 2016
    Denmark
    110
    Fellow snobs!
    Which kettle do you use for aeropress?
    I looked at the bonavita and the brewista kettles, but will a good ordinary kettle with temp control do the job?
    Gavisconi007 likes this.
    Jul 2012
    721
    Brazen is a good aeropress kettle...😀
    Dimal and sprezzatura like this.
    May 2014
    Brisbane
    279
    Quote Originally Posted by Melbroaster View Post
    True that, constantly using the brazen kettle function when I feel like an aero press.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,348
    IMO 93deg is too hot for soft brew, including Aeropress. What I do at home is pour from my kettle into a milk steaming jug that I keep specially for this purpose. I do this pretty much straight after its boiled then use a thermometer of some sort to check the temp. I've got a thermapen style digital one that I've popped a clip on so it can attach to the side of the jug. I then wait until the temp hits about 85deg before making my coffee. This doesn't take very long and is usually ready by the time I've got everything else set up.
    When I was traveling recently I didn't have a thermometer so I waited about 5min after boiling the kettle then poured some water into a mug and took a very careful sip to check the temp. Not very accurate, but if the water is still uncomfortably hot then it's too hot to brew coffee.
    Dimal and Magic_Matt like this.
    Mar 2016
    Denmark
    110
    So no need for a goose neck???
    And temperature control is overrated as a kettle feature???
    Sep 2013
    2,348
    Quote Originally Posted by Alexpid View Post
    Temp control will make life a lot easier and a if you buy one with a gooseneck it'll mean you can pour direct from the kettle without making a mess. If you're planning on buying a new kettle anyway then definitely get one with these features. From what I've seen the Bonavita and the likes are cheaper than appliance brands with temp control so that's what I'd be doing. In the meantime you might be able to use equipment you already own like I do.
    Alexpid likes this.
    Jun 2011
    297
    I use my aeropress when I travel with whatever kettle is in the hotel room. To get the temperature right I tip the boiling water into a cold cup then into the aeropress.
    Mar 2016
    Denmark
    110
    Thank you for your answers. I've just bought a brewista smart kettle and am playing around with different temperatures for my aeropress. 80 degrees seems to be a sweetspot.
    Magic_Matt and sprezzatura like this.
