Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By lilTanker
Thread: Citric acid to soften water
    Senior Member Alexpid's Avatar
    Mar 2016
    Denmark
    110
    Has anyone tried to add a small pinch of citric acid to your water in your kettle or coffee machine to soften the water?
    We have pretty "hard" water where I live so I have to take some of the calcium/carbonate out of the water to make the coffee taste better and protect the equipment from scale buildup.
    Oct 2011
    1,376
    It *might* prevent scale, but it doesn't take any of the minerals out of the water and thus is not "softening" it - buffering maybe.
    Mar 2016
    Denmark
    110
    A pinch of citric acid seems to take som of the chalky taste out of the tap water. Makes it more vibrant to drink.
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    930
    There's a recipe for 'sweetening' water which involves bicarbonate soda and magnesium sulphate. I'll see if I can dig up the ratios. The biggest issue for taste where we are is the chlorinated water - I aggressively filter that out as much as possible. I've had tremendous taste difference after installing this filter which produces absolutely fantastic drinking/brewing water.
    Jun 2009
    34
    It's acidifying the water and dissolving calcium back into the water. Your better off with an RO filter it will produce nicer water and improve the life of the boiler.
    kbc and sprezzatura like this.
