Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By Melbroaster
  • 1 Post By gonzo89
  • 1 Post By Dimal
Thread: Brew temp for darker roasted coffee
    Jul 2012
    721
    Bought some great beans that were very darkly roasted. Certainly past 2nd crack, and would have been the darkest roast level that most roasters would produce (just to give you an idea of roast level). Tried extracting 19g in and around 26g out at 3 different temps : 87c, 93c and 96c keeping everything else the same. The sweetest shot by far was at 96c. Tasted like i had stirred in a teaspoon of sugar with some caramel syrup compared to the first 2 shots.
    Had always subscribed to the "darker roast needs lighter temp to avoid a bitter shot" idea so sharing in case it helps anyone else have a delicious morning.
    gonzo89 likes this.
    Senior Member gonzo89's Avatar
    Nov 2012
    Brisbane
    296
    Hi melbroaster, the beans sound like my worst nightmare but that's just me. I appreciate the post as I once had the opportunity to also test this out with some beans that were too far beyond second crack for my liking.
    In most cases, I have had success with lower temps on darker beans, not too low though. On one bag of dark beans I received I was much happier with the results of 96 degrees and I too was surprised. You are extracting more at that temp so that also means tapping into the sweetness.
    We can't neglect the overall roast profile to understand how those beans were developed or if that particular bean is just a crazy battler that protects its integrity even at darker roasters.
    Glad you extracted some enjoyment out of what might have been a bad bag
    pyrmontboy200 likes this.
    17,395
    Quote Originally Posted by Melbroaster View Post
    How sure are you that these are the temperatures being delivered to the top of the puck?
    Just sounds a bit odd is all...
    Jul 2012
    721
    Thanks mate, am referring to the preset brew temp on a Breville dual boiler.
    17,395
    Might pay to do a check using a bead t/couple on top of a puck, using the CS DMM Data-logger and verify what is actually being delivered. Mightn't be what you are being led to believe...
    Jul 2012
    721
    ie 96 degrees doesnt sound right for a dark roasted coffee?
    17,395
    Not for me, anyway...
    I'd prefer it down at around 91-92C. Lighter roasted coffee seems to taste sweeter, fruitier, etc to me when it is up around 94-ish. We're all different of course but it may be that your brew water, actual delivery temperature, is a bit lower than what is being indicated...
    Magic_Matt likes this.
    May 2013
    19
    It's useful to appreciate the interaction of all the variables that produced your espresso, rather than assessing them in isolation.
    All else being equal, increasing brew temperature should increase the espresso's extraction. However, the brew ratio you are using (19:26) is relative low compared to prevailing standards (closer to 1:2), which has the effect of reducing extraction percentage. As a whole, the higher brew temperature helps get your extraction back to the sweet spot. It'd be interesting to see how increasing your yield and reverting to a lower temperature affected the espresso's flavour.
    Barista Hustle has a few useful articles on the relationship between yield, strength, and extraction percentage that I am using as the basis for this.
    Glad you managed to get the best out of what sounds like a challenging coffee!
    Sep 2009
    134
    I had the same experience as melbroaster , temps in the range of 94-96 (as measured by my trusted Eric termometer in the grouphead) get the best out of dark roasts. A while ago I got some roasted coffee from a roaster that I was not familiar with and I got an Italian type of roast. The coffee was Sumatra BlueBatak, a pretty good coffee otherwise. I found that by extracting at 94-96 I get a sweeter shot with some almonds/marzipan notes at the end. A shot extracted at my normal 90-92 range and below tasted bland. My thinking is that a dark roast kills whatever more complex fruity/floral/spicy notes the coffee offers so there's no point extracting at lower temps trying to preserve those.
    17,395
    And of course, unless we all have an Agtron Scale handy, one person's light roast is another person's burnt and ashy...
