Results 1 to 20 of 20
Like Tree9Likes
  • 1 Post By Andy
  • 1 Post By Melbroaster
  • 2 Post By Dimal
  • 1 Post By toorakwa
  • 1 Post By degaulle
Thread: Brew temp measurement
    Jul 2012
    721
    Can anyone recommend an inexpensive way to rent/buy a device to accurately measure brew water temp in the portafilter? A digital display would be fine and logging the temps to a laptop would be better.
    Mar 2004
    Internet
    17,101
    That's easy to answer.
    HeatSnob!
    CoffeeSnobs - BeanBay - Other Stuff - HeatSnob Temperature Data Logger
    ...with a bead probe...
    CoffeeSnobs - BeanBay - Other Stuff - Spare Thermocouple Bead
    You can set the temperature scale and time to suit, see it live and save/log it too.
    Dimal likes this.
    Jul 2012
    721
    Thanks Andy! Fyi the links were off but I get what you mean. Would probably drill a filter basket and feed the probe in from underneath.
    Member Aido's Avatar
    Apr 2016
    Brighton QLD & Lennox Head NSW
    41
    You can get a digital thermometer that goes into an e61 group where the little nut is on the front. Temperature should be pretty close to portafilter temp +-a couple of degrees. Easy non destructive way to get an accurate temp and still be able to pull shots.
    Jul 2012
    721
    Thanks, but combined cost of the digital thermometer and the engineering involved in getting an e61 group installed on my breville dual boiler would be cost prohibitive....😨
    Aido likes this.
    Apr 2016
    41
    Quote Originally Posted by Melbroaster View Post
    Agreed!!
    What Andy said then!!!
    Mar 2004
    Internet
    17,101
    (Hmmm.. the links work here okay!?!?)
    If you notched the top of the group handle you could still get a basket on flush... and yeah, then come up under the basket.
    Would be interesting to see the results.
    Jul 2012
    721
    Funniest thing. Those links go to different threads when viewed from Tapatalk vs a browser. Viewed in a browser it comes up correct. Not worth spending any time on - probably just a tapatalk bug.
    Andy likes this.
    17,215
    Well...
    Given that this procedure isn't required to be done every day, why not just feed a "Bead Thermocouple" on to the top of a coffee puck just before you lock the Group Handle in place. Connect the other end to your Heatsnob or Datalogger DMM and Bob's your uncle. Record the results using the method described by Andy above for future reference...
    No need to modify or butcher a Group Handle, unless you're an Espresso Tech. who like to tinker and DIY...
    kbc and TC like this.
    Nov 2014
    112
    Hey mate, where did you get the strip?
    Sep 2011
    Brisbane
    171
    +1 would also like a source. Assuming they can be removed without leaving residue.
    Jul 2012
    721
    I bought mine from orphan espresso
    Sep 2015
    Perth WA
    41
    Do you mean squash the thermocouple cable between the machine's gasket and the basket/portafilter?
    I think the idea is to log the temp and any variation during a brew/pour with the water under pressure.
    14,665
    Bead thermocouple or Scace device is the go. Need to be mindful that a temp strip on the outside of the group measures the outside of the group...
    17,215
    Quote Originally Posted by toorakwa View Post
    Indeed I do...
    Been doing it this way for many years. Might have to cinch the Group Handle up a little more, but not much. Even easier with the Silicone Gasket I bought from Andy - More give in it...
    Sep 2015
    Perth WA
    41
    Indeed I do...
    I might just give it a try once I receive my thermocouple and logger.
    Dimal likes this.
    Sep 2015
    Perth WA
    41
    Well, I finally did this today - with very disappointing results.
    Measured my Sunbeam EM7000 brew temp under normal brew conditions (Pressure and flow) and..
    Victor 86B meter, thermocouple on top of coffee puck, 20 second "pour".
    1 - 4 seconds in showed 84 degrees
    4 - 10 seconds gradually went from 84 down to 75 degrees
    10 - 20 seconds from 75 down to 65 degrees - then I stopped and gave up.
    My office of finance (wife) has given me the go ahead to get a new HX machine. Time to go shopping!
    degaulle likes this.
    17,215
    Hmmm...
    Sounds like the Thermoblock isn't doing a good job. Starts out low and gradually gets lower and lower...
    Is your SB7000 still under warranty? If so, you should be able to use the data to back your claim for a new t/block or a replacement machine. It is plainly not fit for service as it currently performs...
    May 2005
    Perth
    1,239
    An HX machine would be a great choice. It is tempting to always buy new but I would consider a better machine second hand if money is an issue.
    Dec 2016
    Netherlands
    100
    ... and as an accessory get the E61 grouphead thermometer after all !!!
    matth3wh likes this.
