Results 1 to 20 of 20
Like Tree33Likes
  • 19 Post By Hypergear
  • 1 Post By simonko
  • 1 Post By thebookfreak58
  • 1 Post By Hypergear
  • 1 Post By Dimal
  • 3 Post By Hypergear
  • 1 Post By Mrlizard
Thread: My Home Coffee Cart Build
    Junior Member Hypergear's Avatar
    Aug 2014
    19
    Hi All,
    Iíve been a coffee enthusiast for over 10 years and been lurking around the Coffee Snobs site for a couple of years. Iíve recently updated my Vibiemme Domobar Super Lever which has served me well for just under 10 years with a Profitec Pro 700 espresso machine and a Profitec Pro T64 Grinder purchased from Charlie from Jetblack Espresso. Having had a water tank setup with my previous machine I decided plumbing in my new setup was the only option moving forward.
    Not having permission from my other half to use any bench space in her kitchen I decided it was time to look around for a new bench. After searching eBay and Gumtree (for a second hand bargain) I quickly realised what I wanted wasnít something I can just buy with a click of a button.
    So I decided to build my own Coffee Cart.
    Next step was to get some ideas by searching Google and other image sharing sites like Pinterest and Instagram. Although I had seen some nice Coffee Carts/Bars on various sites I started to note down some of the features and setups that would be suitable for my needs.
    My checklist consisted of the following ďmust havesĒ
    1. Plumbed in coffee machine setup with water filter running to my Profitec Pro 700 and to my tap (to supply filtered drinking water)
    2. Milk Jug Rinser
    3. Built in Knock Box
    4. Something unique!
    Welding the frame and wheels
    After welding everything together we finally had an idea on what it would look like.
    Powder Coating Frame
    Re-sprayed the frame and castor wheels in hammer-finish spray and polished base of wheels
    Timber panels
    It was now time to clothe the frame with Tasmanian Oak timber.
    Bench top frame design and preparation
    The frame consisted of 2 parts. The bench top and the smaller concrete insert for the cut out on the front panel. I decided to have the knock box bar and the handle for the cart embedded into the concrete.
    The concrete pour
    My concrete mix consisted of a ratio of 1:3 (1 concrete to 3 sand/rock). I decided to try a product I stumbled across on the internet instead of using the traditional reinforced steel. Instead of inserting reinforced steel into my concrete I used a product called Helix Micro Rebar. The purpose of the Helix Micro Rebar is to bond to all areas of the concrete Ė including the areas with minimum concrete and the curved cutout points.
    Sealing the concrete and varnishing the timber
    The concrete required two coats of sealing of Dry-Treat Intensifia and the timber panels also required two coats of Feast Watson Clear Varnish
    Fitting off sink, tap and milk rinser on bench top and plumbing inside cart
    The Result | More images can be seen on my Pinterest page.
    Iíd like to take this opportunity to thank my friends who spent countless hours in being part of the building process.
    Feb 2013
    280
    Love it, especially the concrete top. A juggler milk dispenser and refrigeration would be cool on it too!
    matth3wh likes this.
    Sep 2011
    Brisbane
    171
    This is awesome! Well done
    10ett likes this.
    Aug 2008
    70
    Looks great, top effort that!
    Senior Member gonzob's Avatar
    Aug 2011
    232
    Your attention to detail is great. My attention to detail says "how is it connected to water, sewer, and power?".
    Gonzo
    Aug 2014
    19
    Thank you all for the positive comments.
    Gonzo,
    Images attached.
    The power points inside the cart are powered by the grey cable plugged into an existing power point on my wall. The white cable is the water supply and the black is the drainage.
    Hus
    Dimal likes this.
    May 2014
    12
    Quote Originally Posted by gonzob View Post
    Gonzo
    Haha, I was thinking exactly the same thing :what:
    Nov 2009
    Altona, Melbourne
    1,584
    That's freaken ridiculous. Can you build one for me?
    Please?
    Aug 2014
    19
    Quote Originally Posted by K_Bean_Coffee View Post
    This could be a new side business venture for you.
    Thanks dodgy x. Not really interested in doing it as a business though. It was a once off project to satisfy my needs
    Dimal likes this.
    Aug 2008
    Millthorpe NSW
    2,047
    Great job Hypergear
    Just out of interest - where did the awesome retro looking castors come from?
    Matt
    17,409
    Reckon this mob would have something to suit Matt...
    DesigningByCoffee likes this.
    Aug 2014
    19
    Hi Matt,
    Castors were purchased from BJ Bearings on Hume Highway, Campbellfield . They're 8" and from memory were around the $30 mark (each) - give or take $5.
    Hus.
    Aug 2011
    232
    Why is it on castors if it has to be plumbed in? Doesn't it stay put? Nice castors, though.
    Gonzo
    Aug 2014
    19
    Gonzo,
    Yes it is staying put. Castors purely for looks.
    Dimal likes this.
    Aug 2014
    19
    Installed a couple of pendant lights to finish off the look.
    artman, Dimal and sprezzatura like this.
    17,409
    That would have to be about the most pimped out home-based Coffee Cart I've ever seen mate...
    Love it...
    Senior Member sprezzatura's Avatar
    Dec 2013
    Toogoom, QLD
    931
    That's boss!
    Aug 2012
    Margaret River
    80
    That's amazing! Great job.
    Apprentice Coffee snob
    Feb 2016
    Queensland
    320
    Love that cart!
    Well done
    Jul 2016
    21
    That is some serious work you have done there. Need to add more of the making process to your Pinterest account.
    Smee likes this.
