Results 1 to 7 of 7
Like Tree8Likes
  • 1 Post By skidquinn
  • 5 Post By trentski
  • 1 Post By b430m
  • 1 Post By Magic_Matt
Thread: Machine cleaning - external
    Jun 2016
    64
    I'm sure this must have been already answered somewhere, but I tried searching and couldn't find much (happy to be pointed to another thread).
    What do you guys use to clean the outside of your espresso machines? Just warm water and dry with a cloth? Windex? My new Profitec is almost like a mirror, but already getting a little dirty from splashes etc. I'm wanting to try and avoid scratching it when cleaning.
    Thanks,
    Paul
    Feb 2016
    180
    I use a damp cloth to get rid of any splash marks, then finish with a dry microfibre cloth. For brushed stainless steel I often add a tiny amount of wd40 onto the cloth to give the machine it a very thin coating as it hides any imperfections and provides a barrier for easy cleaning next time. Always wipe in the direction of the grain!
    Mirror finish metal is usually entertaining to keep clean and oils will often leave a streak.
    Senior Member skidquinn's Avatar
    Oct 2015
    Brisbane
    145
    Yep similar here. I use two microfibre cloths. One wet and then dry straight away with the other.
    Dimal likes this.
    Aug 2015
    Perth WA
    461
    If you want to stop the drip tray from getting all scratched up, I use a sushi mat.
    Nov 2009
    Altona, Melbourne
    1,584
    What does that do for the flavour of the sushi?
    Member b430m's Avatar
    Dec 2013
    Adelaide
    37
    Window cleaner with microfibre cloth.
    Magic_Matt likes this.
    Sep 2007
    Northlandia
    1,363
    Always use a clean microfiber cloth and you shouldn't have to worry about scratching unless you get dirt or sand onto the machine itself somehow
    I use window cleaner once a week; have found its better to do this with the machine cold to avoid streaking. Day to day I just use a damp microfiber to clean around the front of the machine if it's looking a bit grubby.
    Stan likes this.
