Results 1 to 14 of 14
Like Tree6Likes
  • 1 Post By Yelta
  • 1 Post By Yelta
  • 1 Post By JojoS
  • 1 Post By magnafunk
  • 2 Post By magnafunk
Thread: Portafilter baked on grime - how to clean?
    Aug 2016
    19
    Hi Folks - I've got a second hand machine and when I bought it, it was obvious that one of the portafilters was used 100% of the time. The problem is, it's got a serious build up of oil/coffee/grime.
    I've been trying to gradually chip away at cleaning it by wiping it out with a cloth or scorer and soaking in machine cleaner for an hour every week. It's gotten me a way, but it's still not as clean as I'd like it.
    What are the suggestions on speeding up this process? I have thought about steel wool etc but have been apprehensive for risk of permanently damaging the handle.
    For reference: double left, single right...
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,122
    Cafetto EVO is an excellent product, follow directions your PF will emerge spotless.
    Cafetto evo organic espresso clean, 1kg - Cafetto | Coffee Parts
    Dimal likes this.
    Feb 2016
    180
    It looks like the chrome has been stripped off the base so being worried about permenantly damaging the portafilter is a bit late? To my eyes there doesn't appear to be a lot of baked on crud anymore. It might be easier to swap the pouring spouts?
    17,209
    If you follow Yelta's advice, they will be spotless and shiny in no time...
    Aug 2016
    19
    Thanks guys. I've been using Cafetto Espresso Clean, though the non EVO version, and that seems to have hit its limit. Is there some magic dust in the EVO that will make it all better?
    Wondering if the horse has bolted on this one...
    Jun 2009
    Moonta SA.
    7,122
    Quote Originally Posted by andbrews View Post
    As Timmy suggested, looks like the chrome has disappeared, not uncommon, not sure about the EVO doing a better job, looks like the only area's needing attention are around the lettering, have you tried a tooth brush or similar, don't think I would worry too much, overall it looks pretty clean to me.
    Dimal likes this.
    Jan 2014
    Discovery Bay, HK
    268
    Perfect candidate for bottomless conversion.
    artman likes this.
    14,665
    They're both looking pretty good.
    Steel wool will not do any harm. You could try a less abrasive scourer if you wish.
    Aug 2016
    19
    Geez that's a (surprising) relief. I'll give it a bit more elbow grease and then call it a day. Cheers!
    Aug 2013
    Rockingham W.A.
    1,435
    CLR and Silvo both work wonders on brass p/f chrome.
    Senior Member magnafunk's Avatar
    May 2014
    Preston, vic
    554
    Quote Originally Posted by TampIt View Post
    It says right there on the back of the bottle DO NOT USE ON BRASS
    Dimal likes this.
    Aug 2013
    Rockingham W.A.
    1,435
    Quote Originally Posted by magnafunk View Post
    I stated brass p/f CHROME, not the brass itself. They would say that, they also make brasso... and within reason "either works on either" as long as you clean it off properly.
    TampIt
    May 2014
    Preston, vic
    554
    I normally wouldn't bother getting into a dialogue with you as I know you have an answer for everything, but in this case, since you're giving advice which could damage the man's parts I'll make an exception.
    It is obvious from the photo that the brass is exposed from wear to the chrome. Sure, it probably isn't a big deal if the CLR etches the brass since it's not exactly on display, but it is not recommended by Jelmar, the company that makes CLR (Brasso is made by Reckitt Benckiser).
    Anyway op, most would agree that your portafilter doesn't look too bad and if you're that concerned you can always swap the spouts as timmyjj21 suggested above. I also liked the idea of converting it to bottomless
    Dimal and Yelta like this.
    Aug 2013
    Rockingham W.A.
    1,435
    Another occasion I agree with TC - it happens quite often in these cases. The p/f looks fine, just covered with grime. No reason for the chrome to be missing anywhere (you can even see it is raised compared to the other p/f).
    +1 to the "convert to naked" suggestions if the chrome is worn.
    TampIt
