Results 1 to 4 of 4
Like Tree3Likes
  • 1 Post By LeroyC
  • 2 Post By MrJack
Thread: Watery extraction and low pressure on a coarser grind for older beans
    Dec 2016
    2
    I get a few bags of beans delivered once a month usually about 1-2 weeks old by that stage.
    All seems good for the first bag and the first week or two. But by the second or third bag, where I've just opened it but they're now 3 or 4 weeks old, I get poor coffee.
    At a normal grind I get 9 bar pressure. On an older grind I won't get any extraction. But if I coarsen up the grind then I get a watery extraction AND fail to achieve pressure (it only reaches 5/6/7 if I'm lucky).
    Sometimes with slightly older beans (after a few days) I also fail to achieve pressure but get it right by coarsening up a little. But my observation for much older beans (though fresh in the packet) this doesn't work.
    Is is it possible to get anything useful out of month old beans still in the unopened pressure packet? I'd like to know if I'm doing something wrong.
    May 2010
    Sydney North Shore
    1,327
    Welcome to CoffeeSnobs,
    However you store your beans, they will be stale after about a month.
    Either buy smaller ammounts or get some green beans from BeanBay here and roast small ammounts in a popcorn popper like I do. That way I always have freshly roasted beans.
    I find that as my beans get older I have to grind them finer to get the pour between 25 to 30 seconds.
    Barry.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,402
    Unopened or not they're still starting to get a bit old at 4 weeks. There's plenty of coffees out there that are perfectly fine at 4 weeks after roasting, but you don't usually get much more than that. The problem is that as soon as you open that bag they will stale a lot faster than when they were only 1-2 weeks old. It sounds like this is what's happening here so if it's causing problems you'll be better off buying smaller amounts of coffee more often.
    Generally most coffees are at their best between 7 and 20 or so days after roasting. There are exceptions to this rule obviously and storage plays a part, but this is a good basic rule to follow.
    Dimal likes this.
    Oct 2011
    1,376
    Quote Originally Posted by Cody View Post
    I tend to find that even if you can get a reasonable looking pour out of beans >2 weeks old, the flavour just isn't the same and there is very little or no crema. They also seem to be much more prone to channelling.
    To shed some light on your observations - pressure and flow are both dependent on the resistance provided by the puck. Less resistance = more flow and a lower pressure. The resistance is dependent not only on grind size, but also on the viscosity (which depends on what/how much is extracted from the coffee) and probably also how much carbon dioxide there is.
    As the coffee ages, there are various chemical reactions occurring which impact the composition / concentration of the extracted material and thus the viscosity. There is also an off-gassing of CO2, which is why you get less crema.
    As the others have said, fresher is better (to a point).
    DesigningByCoffee and Dimal like this.
