Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By level3ninja
Thread: French Press - why does extraction stop once grounds sink to the bottom
    Jan 2017
    6
    Currently reading The world atlas of coffee (James Hoffman)
    p77 French Press
    A couple of different things here compared to what you read elsewhere
    - medium grind rather than coarse
    - after 4 mins break the crust so it drops to the bottom, and then wait 5 mins so the finer particles sink to the bottom (then pour without plunging)
    It says:
    "Many people recommend pouring out the entire pot once the brew is done, to prevent grounds continuing to steep and start to overextract. If you follow the instructions above the coffee should not continue to brew or add negative flavours, so this is not necessary"
    Question
    Why do the grounds stop extracting once the crust is broken and the grounds sink to the bottom?
    What is the difference, in relation to extraction, if the grounds are at the top or at the bottom?
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,373
    Quote Originally Posted by johntropea View Post
    p77 French Press
    It says:
    Question
    It's not necessarily specific to where the grounds are, however the grounds sinking to the bottom could be an indication that they've reached or are close to reaching maximum extraction. There's only so much of the good stuff that you can get out of ground coffee so extraction will hit a ceiling at a certain point. Depending on the brewing method once you've reached that point you either get nothing more, or just negative flavour attributes.
    Feb 2017
    5
    The more contact the grounds have with the water the more they will extract. There is an optimal point of time to let any beans brew which will depend on time, temp and grind coursness - at a certain point in time you begin extracting the flavored you don't want to!
    May 2014
    Brisbane
    279
    I followed the process in this video -https://youtu.be/eDasYv-IsiE
    and first try it gave very good results. So if what you're doing tastes good, keep doing it, or experiment with different ways.
    Nov 2009
    Altona, Melbourne
    1,584
    Well he certainly looks authentic
    Jan 2017
    6
    This is mentioned again on p66 of the same book, in relation to "cupping":
    "To end the brewing process, the layer of floating grounds on top of the bowl, called the crust, is stirred. This causes almost all of the coffee grounds to fall to the bottom of the bowl where they stop extracting. Any grounds and foam that remain on top can be skimmed off and the coffee is ready to taste [..] coffee tasters use a spoon to get a small sample of coffee...."
    Jul 2016
    29
    Keen to give this brewing process a shot rather than just a normal espresso
    Nov 2013
    1,896
    Here is the same information in video form, by the man himself. https://youtu.be/st571DYYTR8
    johntropea likes this.
