Results 1 to 9 of 9
Like Tree6Likes
  • 1 Post By sprezzatura
  • 2 Post By Casa Espresso
  • 1 Post By scho047
Thread: Coffee Pressure Question
    Dec 2016
    Melbourne, VIC
    36
    quick question....
    i have been using my new HX espresso machine for a week and a half... and it has been working really well. But i have noticed that when I am doing the backflush, the pressure is at 12 bar which has been where it was since the beginning. However when I put coffee into my pseudo 20g basket with correct dose and been tamping to the usual method and then start the brewing process, it only goes up to 4 bar. Previously I had been getting consistent 9 - 10bar pressure during extraction. So I had initially thought this was due to bad quality beans and when I switched it back to the good beans - ones I was getting good consistent 9 to 10bar whilst extracting, it was still at 4 bar (and therefore poor espresso).
    what am i doing wrong? or something wrong with the machine? (i hardly doubt...and hope not!) but when I do a blind basket and do a test, then it goes back up to 10 to 12 again...
    any tips please???
    Senior Member sprezzatura's Avatar
    Dec 2013
    Toogoom, QLD
    931
    What sort of HX machine do you have and do you grind whole bean just prior to dosing the basket?
    Dec 2013
    Toogoom, QLD
    931
    If so, what kind of grinder do you have?
    Jul 2012
    143
    First off adjust your grind and try to get back to 9 bars or so. Your blind test would suggest there's no machine issue present.
    Dec 2016
    Melbourne, VIC
    36
    Hi, thanks for the responses!
    The machine I have is - La Pavoni Cellini Premium and Quamar Q50P all new from dodgy x.
    The situation was that, I was using the beans that I was given with from dodgy x (which was awesome by the way!) and then bought a bag from Five Senses from Cheltenham here in Melbourne. Both beans I was able to get good consistent 9 bars with. Then I was given a bag of beans (was told it was freshly roasted on that day from Cisco in Prahran) and when using that, it all went down hill from there. As I was not able to find any good pressure with it. And since then I have tossed all of the poor beans from Cisco and back onto Five Senses but still not getting the right pressure nor rate. I am thinking it is down to the grind... but was just wanting to know if the machine was playing up...
    Dec 2013
    Toogoom, QLD
    931
    Your machine is fine - if it reads 10-12 bar on the blind filter the pump and bypass/over pressure are doing what they're supposed to. Adjust your grind and dose out 10-15g, throw it out, and dose out another and pull a shot.
    scho047 likes this.
    Site Sponsor Casa Espresso's Avatar
    Dec 2008
    Australia
    772
    Hi Sho,
    It almost certainly sounds like a grind and dose issue.
    We added the optional group head pressure gauge to assist in getting true group head pressure, not just the pump pressure at the pump gauge.
    The fact that you are getting 10 plus bar with the blind filter shows that the pump, opv etc are all working as normal.
    Please give me a call directly and I can go over it with you.
    Regards
    Antony
    Dimal and scho047 like this.
    Dec 2016
    Melbourne, VIC
    36
    Quote Originally Posted by K_Bean_Coffee View Post
    Work through the 20 steps we ran though during training.
    The 20 steps and the video are here: https://www.kbean.com.au/training/
    If you need more training drop in and see me any time
    I have realised that I was a complete newbie for sure! as I was going backwards with the grind setting.... and therefore what I thought was making the grind to be finer, was in fact making it coarser and hence low pressure and quick extract and sour tasting coffee!!!
    All has returned to normality and making great espressos again on my new shiny toy!
    Lesson learnt - use good quality fresh beans and when swapping out the beans, grind and throw some out and before panic sets in, learn to check which way I need to turn the grind dials for finer grind or coarser for that matter!
    Dec 2016
    Melbourne, VIC
    36
    Quote Originally Posted by Casa Espresso View Post
    Hi Sho,
    Regards
    Antony
    Thanks Anthony! I have realised that I was being a complete newbie (as you will read below). But most importantly, thank you for the tips and advise; good to know that you look after products you import and the owners
    Casa Espresso likes this.
