Results 1 to 9 of 9
Thread: Boiler for a La Cimbali M22 Plus Machine
    Nov 2006
    1,077
    Hi All
    Anyone know where i might source a boiler for a La Cimbali M22 Plus model 2 group machine?
    We had someone in the office decide to froth milk and hot chocolate together after the machine had been turned off and was cooling down, you guessed it, it all went into the boiler.
    Vinegar has been flushed through by someone however there is still the smell and taint in the machine.
    Mal
    Senior Member artman's Avatar
    Jun 2006
    2,418
    If you are going to replace the boiler wouldn't it all be apart to flush / clean sufficiently the old one?
    Mar 2012
    Bathurst
    1,144
    Vinegar won't clean it out, you can clean it with milk frother cleaner though. Cafetto sells it (can purchase through Coffee Parts) and they have instructions on their site for how to clean out a milk contaminated boiler.
    If, however, you do decide to replace the boiler and are looking for what to do with the old one, I need a two group boiler for a project. Let me know.
    Nov 2006
    1,077
    Thanks Noidle22, i do have some containers of the "Clean-Machine" equivalent to the cafetto, i assume thats the same sort of stuff?
    Nov 2006
    1,077
    Potentially although i am not keen on the pulling out process due to time constraints but will give it a go i guess
    Nov 2006
    1,077
    Quote Originally Posted by noidle22 View Post
    You wouldnt have that link handy? Searching the site and cant see an area for it.
    Mar 2012
    Bathurst
    1,144
    Quote Originally Posted by bolb View Post
    https://www.coffeeparts.com.au/acces...r-1lt?___SID=U
    Also, here's the link to cleaning the boiler: http://www.cafetto.com.au/pdf/cafett...ted-boiler.pdf
    It says to use the Pulatte powdered cleaner but I've had success with the liquid before. It's always good to have the liquid on hand anyway for cleaning other milk related things.
    Dec 2004
    Earth!
    15,661
    I believe this is what noidle22 is talking about: https://www.coffeeparts.com.au/acces...ng-cleaner-1lt
    Java "Bingo!" phile
    Toys! I must have new toys!!!
    Nov 2006
    1,077
    Thanks noidle22 and Java, much appreciated.
    I was thinking there were instructions on the page itself for cleaning the boiler, i can only see the milk frother instructions on that page.
    Looks like i will have to remove the bloiler and soak in the solution a couple of times to get it clean
    Mal
