Results 1 to 8 of 8
Thread: Is this grind consistency correct for espresso?
    Aug 2015
    CQ
    139
    Hey guys
    TLDR- My question is, does this grind look fine enough for espresso?
    I just bought a new Breville Dual Boiler to pair with my Breville Dose Control Pro. Fresh beans, hard tamp, 18g dose.
    I have my dose control pro on setting 1/60 (finest), and the top bur changed to 1/10 (finest). However, my 18g shot is still extracting about 150g in 25 seconds. When I dosed up to 21g it extracted about 50g in 25 seconds, however it was pushed into the shower screen, it was burnt and the puck was wedged into the basket extremely hard.
    I am trying to figure out if it is the grinder, or something with the machine (didn't have an issue getting 32g shot from 16g grinds in 30 seconds on my sunbeam with this grinder).
    I think I need some shims, but don't want to wait 2 weeks to use my new machine :/
    Dec 2011
    PRL
    2,551
    The grind doesn't look like it should be letting 150g through in 25 seconds. When you say that you use 'fresh beans', exactly what does that mean? What is the roast date?
    Aug 2015
    CQ
    139
    Quote Originally Posted by Barry O'Speedwagon View Post
    Hey mate thanks for your help.
    They were roasted 4 days ago, they're a bit too fresh I know. The same occurred with beans about 10 months old (figured I could dial in with them).
    Any advice would be great
    Senior Member artman's Avatar
    Jun 2006
    2,357
    Hard to tell from the photo, but the best I can explain an espresso grind is that it feels like gritty flour, ie very fine.
    Sounds like you need to try grinding finer, maybe you need a shim kit installed. Use the razor to keep your dose constant and keep your tamp constant too.
    Sep 2009
    294
    Every time I 'finger' some grinds, a grind that is in the 'zone' when First touched feels like
    Talcum Powder then the more its rubbed becomes gritty like fine carborundum sandpaper.
    You mention differing dosages.
    I've found that each basket requires, or 'has' its own particular Dose Level. So that when finally tamped
    it is clear of the shower screen and remains undisturbed and as you set it up.
    Note this is different to, say randomly picking a dosing weight somehow based on the supposed
    referred to capacity of any given basket. Whether that's from the basket manufacturer or elsewhere.
    Have you checked your final tamp level against the clearance remaining at the Shower Screen?
    Aka a tricky way to say - the 5cent test! Note it is only a one off test. Record or note the results.
    Again this I reckon is a one off test where once a maximum basket height is set up, you then dump the grinds
    onto the scales and weigh. I also note how that 'height' transfers to my tamper shoulder. Bingo.
    That becomes where I tamp down to as a minimum to create the required head height clearance.
    You now should have a fairly close maximum setup recipe for that basket. Of course this is just the base setting,
    AND could vary slightly depending on bean density, roast, grind setting.
    However as you use this recipe day after day it becomes the norm and therefore easy to see, feel and repeat.
    As you mentioned in your post to different dose qty's -an 18g and a 21g dose. Was this the same Basket?
    If so if I had the correct 'recipe' for a basket that is fully dosed at say 21g's (minimal screen clearance that
    either expands into the screen during the shot, Or near to just touches it) And it was a good tasty syrupy shot.
    Then the next day same beans etc But choose to down dose to 18g's, I would by choice fine up that grind setting
    And have Tamped heavier than I did for the previous days 'recipe'.
    Hope that gives you the path your seeking.
    GL
    EA
    Aug 2015
    CQ
    139
    Quote Originally Posted by EspressoAdventurer View Post
    GL
    EA
    Hey mate thanks for yuor help
    I've found 18g to be the ideal dose so far.
    I've updated with more info here. https://coffeesnobs.com.au/general-c...-attached.html
    Thanks for any advice you can give.
    Aug 2015
    CQ
    139
    Installed 3 shims with no change :/
    Aug 2015
    CQ
    139
    Updated my post here, unsure what to do :/
