Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By kofekitt
  • 1 Post By beensean
  • 1 Post By Jackster
Thread: Shipping large espresso machine to NZ from Aussy
    Member hunty's Avatar
    Apr 2018
    63
    Has any one ever shipped a large espresso machine from Australia to New Zealand ?
    If so, could you share some details such as cost, who the shipping company was, how it was packed etc.
    Thank you in advance.
    Jul 2009
    254
    How large? i've done a few 1 group levers each way with Pack and send . I got them to do the packaging with a system where they put the machine in a box and then use those expanding foam inserts to fill the gaps . It worked great . The main things to avoid damage;
    - Make sure it is strapped to the pallet so it can't move at all
    - Make sure nothing is loose and can rattle around and damage other parts
    Cost was around $300-$400 depending on level of service/insurance etc . Like any franchise the level of service/competence may vary from store to store
    JMcCee likes this.
    Apr 2018
    63
    Quote Originally Posted by kofekitt View Post
    Thank you for the reply.
    Single group boema size, and what kind of time frames did it take?
    Jul 2009
    254
    3-5 days, probably depends on the level of service you select. From memory they had gold silver and bronze level at different costs
    Feb 2009
    128
    Interesting info here. On a related topic, can anybody advise on sending a machine interstate? This would be a regular single group HX machine.
    Jul 2018
    fairly static
    197
    Does it have its box? If not, do you have one you think appropriate? Scrunched butcher's paper works well for packing (see: every house move).
    If you have measurements and weight then there are web sites, Aus Post, PacknSend, comparison sites, which will answer your question(s).
    arcachon likes this.
    Nov 2017
    Maddington, Perth. Wa
    982
    Can use Coles bags and a can of the expander foam to make own packing. Put in the bag, and fill with foam. Hold the top shut till its finished expanding
    Feb 2009
    128
    Quote Originally Posted by beensean View Post
    No box. That is long gone
    I did come across one of those courier comparison sites a while back. It was good in that you put weight and dimensions in and it gave you the options. Unfortunately cannot seem to find it again.
    Jul 2018
    fairly static
    197
    comparecouriers or couriercomparison or freightquotes are options (all .com.au)
    Feb 2009
    128
    Thnx I'll check them out.
