Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By WarrenK
  • 1 Post By level3ninja
  • 2 Post By level3ninja
Thread: Eject puck problem
    Apr 2017
    107
    Smile Eject puck problem
    I have one filter that I can knock the puck out of and works as it should but the other filter comes out of the portafilter with the puck still in it, so I then retrieve it from the bin and dig the puck out, which is messy. I have tried crimping the edge of the filter with multi grips to sit in tighter but maybe have to crimp more? Any suggestions?
    Aug 2016
    Sunshine Coast QLD
    47
    Eject puck problem
    Quote Originally Posted by WarrenK View Post
    Common issue with my Cremina- just hold one edge of the basket with your thumb while you give it a tap on whatever you’re using to catch the puck.
    Gets easier with practice.
    Good luck.
    16,533
    G'day Warren...
    What brand of machine/group-handles do you have and are you using a ridgeless basket?
    Apr 2017
    107
    G'day Warren...
    Mal, they are the Breville Bes870 supplied ones. I think I am being too gentle with the multi grips. Thanks.
    Dimal likes this.
    Nov 2013
    1,187
    Put the multi grips down! We can solve this peacefully, I'm sure!
    Dimal likes this.
    Nov 2013
    1,187
    When you bang the puck out of the portafilter, I assume you're banging it out on a knock box? Are you hitting the portafilter on the handle or near the edge of the basket like this photo:
    Or are you banging it part way up the basket like this photo:
    Apr 2017
    107
    Not using a knock box but a plastic kitchen bin on the corner which has been strong enough to handle about 6K of strikes so far. Picture one is the closest, about where the steel neck meets the handle. The dual wall one in the photo is the problem one.
    Nov 2013
    1,187
    That's going to be the biggest issue. Change to picture two and you shouldn't have any issues.
    Dimal and Barry O'Speedwagon like this.
