Results 1 to 11 of 11
Like Tree6Likes
  • 1 Post By mjoyce
  • 1 Post By beensean
  • 2 Post By flynnaus
  • 1 Post By Jackster
Thread: How to filter out coffee grounds for disposal?
    Sep 2010
    Melbourne, Victoria
    262
    I managed to block my sink pipe by being lazy with disposing my coffee grounds. I had the plumber around yesterday and one thing he did was to clear my pipes.
    I've got a coffee plunger. Is there some kind of disposable porous bag I can buy that I can filter the coffee grounds into after I rinse my coffee plunger? What are other suggestions? Anything I can buy from KMart or some other place like that?
    I don't have a garden that I can put the coffee grounds into. I tried using my metal sieve to catch the coffee grounds in but it's a bit of a pain getting the coffee grounds out of the sieve, unless there is some trick to it I don't know of.
    Thanks.
    338
    338 is online now
    Mar 2017
    991
    Quote Originally Posted by pamount View Post
    Thanks.
    If you don't have a garden or large plant on the balcony, your toilet has much larger pipes, probably 100mm not 50mm like your sink. Garden or large plant would be my first choice.
    Feb 2015
    Melbourne, Australia
    109
    Thatís the thing I hate most about plunger coffee... cleaning them! I always scrape most of the grounds into the bin first but there will always be some in the sink. One reason I prefer aero press or drip filter - zero mess!
    Jackster likes this.
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,173
    Agreed, the grounds from Plunger coffee are messy. I used to knock them out of the plunger on to my rubber Tamp-mat as best I could and then run a long thin plastic spatula around the inside of the glass to remove the remaining ones. The plunger then got rinsed under the tap and what was left went down the drain. I guess you could wipe out the plunger bowl with paper towel as well which would leave very little to flush down the sink.
    Lets face it, sinks accumulate a lot of gunge even if you are meticulous with what you send down them.
    Sep 2010
    Melbourne, Victoria
    262
    Quote Originally Posted by Rocky View Post
    I remember a friend bought some product from Bunnings that helps to clear blockages from the pipe under the sink (I forget what the product is called). Maybe I should look at buying that to keep aside.
    Nov 2018
    Qld
    88
    Drano. From Coles or Woolies and it goes under the Mr Muscle brand now.
    Be very careful not to inhale it because it is potent.
    It is about $11 or $12 from memory. Cheaper than a plumber..........
    I’ve removed complete blockages in about 10/15 minutes with the gel version, but mostly the powdered form works well.
    Great for maintaining shower wastes (several long haired females here).
    Click to enlarge image below.
    Jul 2018
    fairly static
    197
    You can also try Actizyme from Woollies and other places; cheaper at Coles I think but not available in Bunnings. Costs more, but no worries about toxic inhalation. Use last thing before you go to bed so it has time to work. We use it mainly for the shower waste. I am well acquainted with a long haired female also.
    EZCFlair likes this.
    May 2008
    4,219
    These are the go. Help keep grounds outof your cup too.
    Large: https://beanbay.coffeesnobs.com.au/V...-large-special
    Small: https://beanbay.coffeesnobs.com.au/V...-small-special
    Dimal and 338 like this.
    Nov 2017
    Maddington, Perth. Wa
    1,076
    Under sink blockage is a easy job, just undo the P trap and clean it. Even a plunger would have fixed it.
    I'm going with the aeropress suggestion. Easier cleanup by far. The paper filters would be less mess that the metal filter
    338 likes this.
    Oct 2009
    Geelong
    1,198
    Yep, plungers are tricky :P.
    I just use a long enough spoon and scoop them out. It's inevitable that a few will go down the sink, otherwise fill with a bit of water and pour onto a small tea strainer.
    Nov 2017
    1,076
    The baggies that Flynn has linked look the goods too. I didn't know they existed
    Dimal likes this.
