Results 1 to 4 of 4
Like Tree4Likes
  • 1 Post By cleanCup
  • 1 Post By Caffeinator
  • 2 Post By MorganGT
Thread: One group producing a darker crema than the other ?
    Dec 2014
    Perth , Western Australia
    99
    I have a two group machine , my RH group produces a slightly darker crema than the LH,
    Same baskets,coffee etc,
    Could it be a HX problem ?,
    matth3wh likes this.
    Jul 2017
    467
    Quote Originally Posted by cleanCup View Post
    It's not uncommon for there to be some temperature variation between groups in some multi group machines. Assuming all else (including dose) is identical, it's likely something you may need to learn to manage. Alternately a good tech might be able to solve it. It's pretty easy to do in an e-61. Other machines may require different solutions. Some- not possible to tweak.
    Dimal likes this.
    Senior Member artman's Avatar
    Jun 2006
    2,473
    I would think it would be caused by differing temp/flow (assuming all else being equal), depending on the design could be a bit of scale or similar in one of the group flow paths/thromosyphon paths?
    Aug 2010
    372
    I've seen differing pours and temperatures on different groups on a HX machine in several situations - a couple due to scale buildup affecting thermosyphoning in the heat exchangers (fixed with a descale of the heat exchangers), one due to an injector tube feeding a heat exchanger breaking off inside the heat exchanger (fixed by replacing broken part), and one where mismatched restrictors had been fitted to the pipes from the heat exchangers to the heads (fixed by redrilling the smaller restrictors to match the biggest one).
    Dimal and Caffeinator like this.
