Results 1 to 3 of 3
Like Tree6Likes
  • 5 Post By Yelta
  • 1 Post By slugga
Thread: Advice needed
    Feb 2019
    Adelaide
    3
    Advice needed
    Hey all. Bit of advice needed as I'm new to this. I bought a sunbeam em6910 and had it serviced.. new group head seals etc. The grinder I bought is just a sunbeam cafe series so not best quality. Anyway when making coffee this morning the water hardly gets through and the coffee ends up almost like mud in the handle.. am I grinding the coffee too fine? Sorry if this is a silly question
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,355
    Sounds like it Mick, try grinding a little coarser, just a touch, if still choking the pour, coarser again, may take a few tries, you will get there in the end.
    Once you establish a grind setting that suits you, away you go.
    PS Make sure your using fresh, quality beans, not supermarket stuff.
    No, it's not a silly question, we all had to start somewhere.
    ajayro57, Dimal, greenman and 2 others like this.
    May 2017
    8
    Hi Mick,
    I used to have *exactly* the same setup and can tell you that Yelta is right. I started at the mid-point on the grind setting and worked my way finer until I got a good extraction. That grinder is perfectly fine for home and is well-matched to the machine. And as Yelta quite rightly said, get yourself some good beans from a reputable roaster. We started with beans that a cafe we really liked used and went from there.
    Good luck!
    Dimal likes this.
