Results 1 to 13 of 13
Like Tree7Likes
  • 1 Post By Superman
  • 1 Post By Lyrebird
  • 2 Post By woodhouse
  • 1 Post By Jackster
Thread: Mixing (Perth) tap water with distilled water
    Jun 2019
    14
    I've been doing lots of research on this and it seems the best /taste /cost way to do this for my low usage (4 espressos /wk) is to mix tap and distilled water.
    I'm planning to dilute it till I get a TDS between 50-70. What do you people think?
    rossross likes this.
    Dec 2018
    Perth / Lombok
    21
    What part of perth cause water quality and taste vary across perth, i know my water is very good when i had it tested
    Jun 2019
    14
    All of Perth water is very bad for espresso machines.
    Average tds is around 300! https://www.watercorporation.com.au/...eport-2017.pdf
    May 2018
    60
    Hi.
    I'm distilling water in my house and I then pass it through brita filter. The taste is sweet water that is amazing.
    I then reminerlise using ConcenTrace mineral drops that has hight magnesium contents.
    Aug 2016
    Sunshine Coast QLD
    107
    Impressed..... when I read some of these posts I really wonder if I'm taking my hobby seriously enough.
    Jun 2018
    625
    Quote Originally Posted by Gil80 View Post
    Hi.
    Why are you passing distilled water through a resin bed?
    Dimal likes this.
    Senior Member woodhouse's Avatar
    Dec 2016
    391
    if you already have distilled water, you can go buy some epsom salts and bicarb and make concentrates for mineralisation.
    https://baristahustle.com/blog/diy-w...n-two-bottles/
    recipe 7 seems to be geared towards espresso.
    Dimal and Gil80 like this.
    May 2018
    60
    Quote Originally Posted by Lyrebird View Post
    The brita filter (carbon filter) improves the taste of the water in a noticeable way.
    The distiller I have is a cheap one and doesn't get rid of VOC (volatile organic compounds) well enough, this means that the water has some very minor after taste that will go away with time, but the brita filter does the overall finish quite quickly.
    We use it as drinking water. Hence I reminerlise it.
    Obviously, no scaling issues whatsoever.
    The gunk that is left in the distiller is very smelly and looks bad. Fluoride and chlorine smell.
    I live in Sydney.
    Jun 2018
    625
    OK, carbon I understand.
    You and I will have to agree to disagree on remineralisation.
    Dimal likes this.
    May 2018
    60
    Care to explain yourself? I don't claim to be right, but I don't think I had a conversation where we had a disagreement.
    I'm more than happy to learn and open for constructive feedback.
    Jun 2018
    625
    I made too general a statement, I specifically meant the remineralisation of drinking water, which is not what we were discussing on a coffee forum.
    Nov 2017
    Maddington, Perth. Wa
    1,108
    I was of the understanding that Perth water was getting softer. With the bringing online of the desalination plants (their output is stored in out hills dams), and pretty sure our dams are quite a bit fuller than has been the case several years ago, so reducing the need to draw groundwater that is quite hard.
    I also think the southern suburbs have softer water than the northern suburbs.
    Jun 2019
    14
    Quote Originally Posted by Jackster View Post
    Water Corp water quality report here. Start at page 50 for the details.
    https://www.watercorporation.com.au/...eport-2018.pdf
    greenman likes this.
