Results 1 to 4 of 4
Thread: Brew Pressure Dilemma
    Member SunnyCoastDazza's Avatar
    Mar 2019
    35
    Hi all, Iím fairly new to all this so I am seeking advice please. I decided to do my own full descale which tock a heck of a long time flushing and flushing as I let the solution sit in the tank for at least an hour as I wasnít sure how long it had been since my new to me second hand machine had been de scaled.
    After I was finished I noticed the brew pressure was down by using a blind as I was flushing the exit tube into a second container to dump as I was introducing fresh water and dumping what came out. This mad sense as I removed quite a bit of nasty stuff and thought the internals must have more volume?
    So I reset the brew pressure on the gauge at 10 bar to expect around 9 at the group head.
    i now find extraction is indicating high around 13 with a 2oz extraction taking about 25sec. The creme looks good and the coffee tastes good. Should I be concerned about the high brew pressure indication?
    Nov 2017
    Maddington, Perth. Wa
    1,067
    Might taste better if you back it off again!
    Mar 2019
    35
    I’m just confused on how it can change. I adjusted the brew pressure live with a blind in the portafilter and ran it at that pressure for 10sec to ensure it was stable. Do you think I have used the wrong technique. Love to here everyone’s thoughts
    Nov 2013
    1,809
    Do you have another blind filter could try?
