Results 1 to 10 of 10
Thread: HELP!! extraction channeling issue
    Sep 2012
    73
    Need some advice to fix channeling issue.
    Machine: Giotto
    Grinder: Compak K3
    20g VST basket, in a naked portafilter
    So lately, my shots have been getting channeling towards the end of the shot. My tamping technique hasn’t changed and always use fresh beans. The shot starts of nice then halfway/end of the shot, it starts to channel, spitting in all directions. What should I look at first to fix this problem? TIA
    Nelson
    Nov 2013
    1,457
    Hi Nelson, how long have you been using this exact set up? Has it been fine until recently? How many grams of ground coffee are you dosing into the 20g basket?
    Sep 2012
    73
    hi, i’ve been using this setup for like 2 years. I’ve been dosing 21gs into the VST
    Jan 2014
    Sweden/Germany
    141
    WME
    WME is offline
    Member WME's Avatar
    Feb 2015
    Perth
    50
    Pulled the shower screen out and made sure it doesn’t have build up of muck behind it?
    May 2008
    4,077
    Have you recently changed the beans you usually use or have you tried using a different bean?
    When was the last time you gave your grinder a good clean?
    Sep 2009
    301
    Change one thing at a time
    1/ Beans
    2/ Grinder Blades...they degrade ever so slowly.
    Could Fit with the background info you gave.
    3/ Puck being distrubed by hitting shower screen as PF locks in.
    Things you could experiment with -
    Varying space above puck to allow more (or less) water to saturate the puck to slow (speed up) the pre-infusion.
    IIRC - VST state something like 1.5mm above puck for water saturation.
    Sep 2012
    73
    Quote Originally Posted by EspressoAdventurer View Post
    1/ Beans
    Always use fresh beans from local roaster, i’ve had the grinder for about 5 years and it’s been recently cleaned, the blades seemed ok to me, but maybe need changing.
    Dec 2011
    PRL
    2,611
    I'd start by reducing the dose to the exact amount that the VST is rated for (i.e. 20g), which should also eliminate the possibility that the puck is being fractured by contact with shower screen.
    I suspect the blades do also need changing, but try the 'easy outs' first.
    Sep 2012
    73
    Quote Originally Posted by Barry O'Speedwagon View Post
    Yep i’m beginning to think it’s time to replace the blades, cheers.
