Results 1 to 11 of 11
Like Tree8Likes
  • 1 Post By jksniper
  • 1 Post By Dimal
  • 1 Post By level3ninja
  • 1 Post By Erimus
  • 1 Post By noonar
Thread: How does this extraction look?
    Jul 2019
    26
    Do you see any problems with this extraction?
    https://www.youtube.com/watch?v=DyO5YnQzAXU
    noonar likes this.
    17,415
    Looks good to me...
    More important though, is how did it taste?
    jksniper likes this.
    Jul 2019
    26
    Looks good to me...
    Tastes great as can be with my usual Darkhorse blend
    Dimal likes this.
    Nov 2013
    1,832
    Overall looks pretty good. It might be the camera angle, but it looks like it's flowing slightly faster out of the side basket closer to the machine. If so it suggests that distribution could be improved. 27s total shot time is on the shorter end but if it's a darker roast they tend to do better with shorter shot times. If you have tried it I would suggest trying a few shots at 29s and a few at 31s just to see how they compare and what you prefer.
    Jul 2019
    26
    Good observation! Yes I noticed it wasn't dropping from direct center of the basket so I will try to tamp a bit better next time.
    It is running slightly faster than I would like but grinding it finer seems to make it taste slightly on the bitter side.
    Dimal likes this.
    Senior Member Erimus's Avatar
    Mar 2014
    Kippa-Ring Qld
    406
    Quote Originally Posted by jksniper View Post
    You've just answered your own problem, you need a better grinder. You can only get so far with a Breville.
    Jul 2019
    26
    Quote Originally Posted by Erimus View Post
    It always helps to get a second opinion to find anything I've missed
    I agree about the grinder, but I'll need to save up for an upgrade.
    Nov 2013
    1,832
    It may or may not be your tamping causing the flow imbalance. Yes perfectly evenly distributed and flat ground coffee that is tamped unevenly will produce uneven flow, but by the same token unevenly distributed ground coffee that is tamped perfectly well also produce uneven flow. Uneven can mean clumped, more densely packed on one side than the other even when flat prior to tamping, etc.
    If grinding finer brings bitter flavours it can mean it's causing channelling. Increased distribution may be required. I have a BCG820 (unused these days) and at espresso settings it clumps quite a bit. If you grind into the container and then break up the clumps you should have better results. Alternatively add a dosing funnel to the portafilter / basket after grinding and then use a toothpick to break up clumps prior to tamping.
    Jul 2019
    26
    thank you for your detailed suggestion!
    I will definitely try it out!
    Senior Member noonar's Avatar
    Aug 2013
    MortalCoil
    513
    Unevenness can also be because the machine itself is uneven due to the surface it sits on or a similar reason. Sticking a spirit level on it to confirm may be worthwhile.
    Jul 2019
    26
    Quote Originally Posted by noonar View Post
    interesting pov, i've never considered that, will take a look tonight thank you!
