Results 1 to 15 of 15
Like Tree13Likes
  • 2 Post By level3ninja
  • 6 Post By Caffeinator
  • 1 Post By Dimal
  • 1 Post By flashpixx
  • 2 Post By CafeLotta
  • 1 Post By level3ninja
Thread: Water Filtration Perth Hills
    Senior Member flashpixx's Avatar
    Dec 2013
    Perth Western Australia
    319
    Have the following from the Water Corporation for our supply
    90 Total Alkilinity
    90 Total Hardness
    390 Total Dissolved Solids
    The boiler in our coffee machine (ECM Mechanika V Slim) is SS
    Using a Brita jug with a Maxtra carbon filter which seemed to do a good job on the Silvia.
    Should I consider upgrading to something like the C150?
    Nov 2013
    1,897
    The Brita jug will cost you money and do very little for your machine. The C150 doesn't remove all the chlorine from the water, which will eventually create pin holes in your boiler. The "C150 Finest" is designed for SS boilers. Yes if you like your machine you need to feed it good water.
    Dimal and flashpixx like this.
    Jul 2017
    453
    Firstly, get your water tested rather than relying on a number plucked from somewhere. You may well be substantially different to what your local authority has to say.
    Based on the figures you provide, you will kill it (rapidly) with that water and it's beyond the capabilities of the C150 Finest as well.
    Should you want that from a water professional, refer it to Bombora supplies. Alternately, https://techcenter.lamarzocco.com/js...calculator.jsp works well too.
    Bottled or remineralised RO I am afraid as stainless boilers are way more picky when it comes to water.
    Dimal, Yelta, CafeLotta and 3 others like this.
    Senior Member noonar's Avatar
    Aug 2013
    MortalCoil
    514
    In the northern suburbs of Perth we also get soup through our water taps. Bought a testing kit from the local Pet Shop which helped me understand our "localised" situation. Bombora recommended - and I self-installed - Claris Everpure filtration, no regrets after 7+ years of regular, plumbed in, R58 use.
    Jul 2017
    453
    Quote Originally Posted by noonar View Post
    All good. Regardless, SS boilers are a whole new ball-game and we know a lot more than filtration and stainless than we did 7 years ago. I wouldn't use the Everpure with a stainless boiler either.
    Aug 2013
    MortalCoil
    514
    Thanks Caffeinator for the heads up - time to revisit the water rabbit hole. Any tips greatly appreciated.
    Dec 2013
    319
    Thanks everyone for your replies.
    Ability to instal an undersink filter system is zero unfortunately.
    I use only 300 - 400 ml of water a day (2 - 3 piccolos), so perhaps 10 or 20 litres of filtered water stored in the second fridge.
    Where might I source this water from that might come with a label that states it's pH, TDS etc in Perth??
    I'm assuming that Woolworths isnt the right answer
    Senior Member rusty888's Avatar
    Nov 2014
    Perth
    254
    I think you will find there is no correct answer and no one is happy to answer it.
    What I mean by this is manufactures who have to carry the warranty.
    RO in some cases for home applications arenít favoured, then they speak of bladder water from the shops but donít provide a recommendation.
    Good luck.
    Dec 2013
    319
    I've asked the Aust importer of my machine for some advice....
    I suspect they will go with the best (most expensive) solution
    Maybe bottled water is the solution best suited as it is cost effective (for me) saves me having to plumb in a filter in a less than ideal place
    Has to be better than using what is coming out of the tap!
    17,457
    I think the "tip" already supplied in Post #3 is the best advice by a long way...
    level3ninja likes this.
    Dec 2013
    319
    Quote Originally Posted by Caffeinator View Post
    You are correct good Sir. Response from Bombora:
    The Brita Finest filter is a great little filter for reducing the effects of Calcium and Magnesium ions from your incoming water source. Unfortunately it will do little in the fight against Chloride. Looking at your water data below , I would suggest that your Chloride levels are well over 100 ppm and it these kind of levels your machine’s boiler will simply not cope. The solution would be to either look at a reputable bottled water supplier ( I would test TDS with a meter) or look at a Reverse osmosis system to prevent the build up of scale and corrosion.
    Dimal likes this.
    Jun 2012
    Melbourne, Vic, Aust.
    1,305
    Previous discussion re: RO systems in case you're interested - https://coffeesnobs.com.au/general-c...on-system.html
    Nov 2013
    1,897
    Or if you want to mix your own water from bottled check this out: https://youtu.be/I4SbV-UM-hQ
    flashpixx likes this.
    Dec 2013
    319
    Here’s a water recipe I’m going to try
    https://s3-ap-southeast-2.amazonaws....ter_recipe.pdf
    Dec 2013
    319
    Quote Originally Posted by CafeLotta View Post
    Ive got a source of RO water that I’m going to use to make my own brew water
