Results 1 to 30 of 30
Like Tree51Likes
  • 2 Post By Yelta
  • 1 Post By SanderP
  • 3 Post By robusto
  • 1 Post By Yelta
  • 3 Post By simonsk8r
  • 1 Post By simonsk8r
  • 6 Post By Dimal
  • 1 Post By flashpixx
  • 2 Post By flashpixx
  • 2 Post By Yelta
  • 2 Post By simonsk8r
  • 2 Post By Yelta
  • 4 Post By Barry O'Speedwagon
  • 3 Post By flashpixx
  • 2 Post By Dimal
  • 5 Post By TampIt
  • 1 Post By CafeLotta
  • 1 Post By Yelta
  • 4 Post By CafeLotta
Thread: Wet Puck
    Senior Member flashpixx's Avatar
    Dec 2013
    Perth Western Australia
    319
    Wet Puck
    This morning noted a quite wet, almost sloppy pucks.
    99% humidity
    two different bean blends from local roasters in date (within two weeks of roasting)
    both extracted exactly as per recipe for the blend (grind, dosing weight, tamp, water temp, extraction weight)
    pour was *slightly* watery
    taste was a little weak
    The basket was unusually wet when removed from the machine for the first shot
    Is humidity my problem?
    Gordon
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,368
    Quote Originally Posted by flashpixx View Post
    99% humidity
    Gordon
    Probably not Gordon, about the only affect I find humidity has is when grinding, very low humidity sees grinds sticking to grinder surfaces.
    Have you contemplated using an Espresso Parts HQ Filter Baskets? excellent baskets, very easy to use and come to terms with, I certainly don't have a problem with wet pucks.
    Over the years I've tried a couple of the more exotic baskets, have always finished up back using the EP offering, easy to use, not in the least bit finicky and produces excellent espresso.
    I have the 14 to 18 gram, dosed to 18 grams, $20 from Talk Coffee in Northcote, Victoria.
    Dimal and flashpixx like this.
    Aug 2016
    Sunshine Coast QLD
    108
    Agree, I'm in QLD and don't notice any impacts from humidity in the puck.
    More likely to be the grind, head into Turkish territory and you can get soggy pucks.
    flashpixx likes this.
    Feb 2005
    3,098
    Ninety nine percent humidity????
    Where are you brewing, outoors in the tropics during a monsoon?
    Dimal, simonsk8r and flashpixx like this.
    Dec 2013
    319
    I haven't, and thanks for the tip. I will get one and give it a try, a small investment for a potentially good return.
    Dec 2013
    319
    Quote Originally Posted by robusto View Post
    Perth Hills. one of those weather events when hot air is trapped from the day before and mixes with moist air from an approaching front. clears by 8am when the sun burns the clouds away
    Jun 2009
    Moonta SA.
    7,368
    I suspect you will like the result.
    Oct 2009
    Geelong
    1,226
    99% humidity
    Gordon
    Hey Gordon!
    It's possible that you're underdosing a tad bit.. alot of recipes don't take into account your setup and basket size specifically, so you may be going by their dose recommendation but it may be a bit shallow still with whatever basket you're using.
    Just going by wet puck, watery pour, weak taste, it sounds to me you need to up the dose (and consequently a tad bit coarser grind). But you can still stick to the recipe ratio they recommend (eg if it asks you to dose 19g in for 38g out, try 20g in for 40g out within the same time period).
    Experimenting is the fun part, enjoy
    dan77, Dimal and CafeLotta like this.
    Dec 2013
    319
    Quote Originally Posted by simonsk8r View Post
    Hey Gordon!
    Hi Simon
    Thanks mate, yes I do enjoy the experimenting.
    I dose the Pullman 19-22g basket to 22g and aim for 36g out. This is per the recipe
    I've been playing with my dosing and tamping. After filling the basket I smooth the grind with my finger, lightly tap and tamp.
    I've eased up on my tamping pressure which doesn't seem to impact on the extraction weight, but has reduced the wetness.
    I haven't tried running a toothpick through the grinds. I have just received a tiamo dosing cup so I'll see if that improves the distribution in the filter.
    I reckon if I can get the Pullman basket to work well, then my technique "might" be up to par
    Oct 2009
    Geelong
    1,226
    Hi Simon
    Ah yep cool, I guess what I meant was that the basket rating (its dosing range eg 19-22g) is a generic guideline and doesn't suit all coffees, it really depends on a few factors, as a darker roasted coffee will take up "more room" in volume compared to a lighter roast. Shower screen depth on your machine too is a consideration, but the coffee itself will take up different amounts of "room" depending on its roast depth.
    I have a 20g pesado basket, but with my current coffee I'm dosing between 22 and 23 grams, 20g would be far too shallow. So whilst your recipe calls for 22g, for your specific basket it may need a bit more. I'm really not too sure about some basket ranges, if anything it's a rough guide to tweak to suit your circumstance.
    Just some proverbial food for thought, but great that you're experimenting with your distribution
    kelvin8r likes this.
    17,587
    Dare I mention the Five Cent Test....
    Jun 2012
    Melbourne, Vic, Aust.
    1,311
    You could also try adjusting the grind a tad coarser using the original tamp pressure. How does it taste? Maybe use the ratios as a guide and let your taste buds be the final judge?
    Dec 2013
    319
    This?
    Grind and tamp, load 5 cent piece... *Lock in...
    Unlock, remove 5 cent piece..
    Have a look and what do you see.
    1: Coin has been embedded in puck - Massive Overdose *: *(Or ya have a bloody big nut from the shower screen pushing down - change it fpo
    2: No imprint what so ever - Under dose ???
    3: Slight imprint of the coin in the puck ??
    Number 3 could be a good place to start pulling shots and inspecting the result.
    Remember different beans will expand differently and be dependant on the grind and tamp as well.
    Dimal likes this.
    Dec 2013
    319
    OK, I get ya! I am likely underdosing based on the 5 cent test. There is not a nut protruding from the shower screen so I "could" load the basket to within 1.5mm of the shower screen?
    Dimal and simonsk8r like this.
    Dec 2013
    319
    Quote Originally Posted by CafeLotta View Post
    I do like the taste, I fear if I load any more in the basket I might find it a bit too strong for my taste. I may need a smaller basket perhaps??
    Jun 2009
    Moonta SA.
    7,368
    See reply number 2 FP, at the risk of raising the ire of the rusted on VST users, EP baskets really do take so much less messing around, VST's are renowned for being finicky, sold mine ages ago.
    PS as Mal suggested the 5 cent test is an excellent way to establish your dose.
    The 14 to 18 gram dosed to 18 should suit you well, think it will solve a lot of your problems.
    Oct 2009
    Geelong
    1,226
    Or do the $4 test! No imprint, and you're DEFINITELY underdosing!
    Dec 2013
    319
    There is an 18-21g EP triple basket on its way. Should arrive tomorrow.
    To ensure completeness there are 20g and 22g VST coming too.
    looking forward to trying them all
    Jun 2009
    Moonta SA.
    7,368
    At the risk of seeming contrary FP, I'm not a fan of the 18/22, I much prefer the 14/18 dosed close to maximum capacity.
    Dec 2011
    PRL
    2,809
    I use both VSTs and EP baskets (each are 18g nominally). I tend to use the VST more often, and I don't find it too finicky (though when my better half used to make coffee it was not an option). I'm using a spring lever machine, so that may have an influence. You can make good coffee with either. Don't worry about the state of the puck if the coffee tastes good.
    Dec 2013
    319
    Quote Originally Posted by Barry O'Speedwagon View Post
    It does taste quite good actually.
    Dimal, CafeLotta and level3ninja like this.
    17,587
    Ditto...
    Have always found that, for me, doses closer to the rated upper limit of a basket produced a much more satisfying result in the cup, rather than heading in the other direction...
    Yelta and flashpixx like this.
  23. #23
    Aug 2013
    Rockingham W.A.
    1,511
    Hi Simon
    G'day flashpixx
    If you are worried about the flavour being a bit strong, you may be going inn the wrong direction with your baskets.
    IMO, the Pullman is already a notch above the EP/HQ/EQ etc (it has over a dozen names by now - I keep running into them). The good news is that the grind and dose percentage (i.e. dosage to rated size ratio) would be pretty similar.
    Set up properly, and with a good enough grinder to cope, the VST will need a much finer grind, a more even particle spread, preferably a naked p/f and a flat based tamper. Rationale: the VST has about 50% more flow than standard(ish) baskets so you need to adjust for that. Then the VST will give you close to 50% higher extraction ratio (i.e. quantity of flavour in the cuppa). The VST is used in barista competitions because it also gives a very clean. clear flavour (so better or worse - crap technique & roasts taste just like, er, crap). So a 15g VST will give about the same flavour is your 19g Pullman when both are optimised.
    I am in WA, so if you need to "try before buying" a 15g VST you are welcome to borrow one of mine for a while.
    Enjoy your cuppa - and wet pucks have sod all to do with that directly anyway...
    TampIt
    robusto, CafeLotta, noonar and 2 others like this.
  24. #24
    Jun 2012
    1,311
    The 15g and 20g VST ridgeless are 2 of my favorites. Always fun experimenting with different baskets (and dose/grind) on whichever bean you're using.
  25. #25
    Dec 2013
    319
    Thanks TampIt for your very kind offer. Following this morning's effort (see below), I will see how the 20g VST basket goes (AusPost just advised it is coming today), and if there is any favourable difference using the 18-21g EP recommended by Yelta.
    This morning I followed the advice of Mal and Simon, loaded the Pullman basket and did the 5 cent test. Turns out 23g of my 2 favourite beans result in a very slight but discernable imprint of HRH in the dry Puck.
    The original recipe was 22g in for 36g out in 32-34 sec. With an extra 1g of coffee I went 23g in 37g out in 34 seconds.
    Result:
    Much drier puck
    Even nicer taste, the slight bitterness has gone now replaced with a lovely Plum tone with a smooth dark chocolate aftertaste.
    There has been a change in workflow also, used the Tiamo ss cup to dispense the grind from the grinder into the p/f. Visually noted less clumpiness (not that bad previously), but now just a lovely bed of untamped grinds in the p/f.
    Learning something new everyday
  26. #26
    Jun 2009
    Moonta SA.
    7,368
    I recommended the 14 to 18 EP, I'm not a fan of the 18 to 21.
  27. #27
    Dec 2013
    319
    I've trialed VST 15g, 18g, 20g and 22g baskets against the Pullman 19-22g basket.
    Unfortunately AusPost have lost the EP 18-21g basket I ordered.
    Favourites are the 18g basket dosed to 20g and the 20g basket dosed to 22g.
    I have one particular bean that is medium roast and quite strong. It was quite good in the pullman 18-21g basket dosed to 22g.
    In the 20g VST dosed to 22g WoW it knocks your socks off. a 34g shot in 150ml of milk is too strong for me, flavours were all there but bamm, knock yer socks off!!
    Dose 20g of that bean into the 18g VST, and its a game changer. Wonderful clarity of flavours, I'm not an espresso drinker but I really enjoyed a single shot. With 32g out of the 20g dose into 150ml of milk and it's coffee bliss, the chocolate aftertaste comes through and just stays with you. It really has transformed the drink!
    I have two other beans that are lighter roasts, and they are both perfect in the 20g VST basket dosed to 22g in milk.
    When I have a piccolo I use 2 x 90ml glasses, pull a 32/34 g shot, half into each, which is about 15ml, and top it up with milk.
    simonsk8r and level3ninja like this.
  28. #28
    Oct 2009
    Geelong
    1,226
    So, so cool to hear... love it!
  29. #29
    Jun 2012
    1,311
    Are you getting much sleep these days?
  30. #30
    Dec 2013
    319
    Caffeine is good for you!!
